Flashpoint Model II 320A Monolight, 150 Watt Second Strobe, 120 Volt
#1
4.5
based on 50 reviews
Ratings Distribution
5 star
28
4 star
21
3 star
0
2 star
1
1 star
0
Category Average
4.0
$99.95 at Adorama
Find it at Amazon
Find it at Ebay
$99.95
from 1 store
More Images
Pros
  • Attach securely (36)
  • Powerful (31)
  • Durable (30)
  • Good color value (27)
  • Long-lasting (14)
  • Consistent (1)
  • Easy to use (1)
  • Full-featured (1)
  • Good solid feel (1)
  • Quick recycle (1)
See less See more
Cons
  • Flimsy (2)
  • Haven't found any so far (1)
  • Loses charge quickly (1)
  • No stands or umbrellas (1)
  • Remote sensor incorrect (1)
  • Runs hot (1)
  • Weak support for an umbre (1)
Best Uses
  • Indoor (38)
  • General purpose (36)
  • Low light (22)
  • Special events (19)
  • Night time (14)
  • Outdoors (6)
  • Fill light (1)
  • Portraits (1)
  • Product photography (1)
  • Shade light from sun (1)
Provided by Adorama
Specification Description
Power W/S Up To 200ws
Flashpoint Model II 320A Monolight, 150 Watt Second Strobe, 120 Volt Questions
Questions and Answers
Where to Buy
$99.95
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Nov 9, 2009
Flashpoint Model II 320A Monolight, 150 Watt Second Strobe, 120 Volt Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
5.0
Better than expected
"Great 1 to 2 person portrait light or fill light. Picture and description is misleading, it looks like small cheap plastic body but is metal is has rugged build, and is larger than expected. Mine does not have audible ready beeper, and modeling light is not variable, I have checked reviews on Internet the same is true for them, so I did not expect these features. I can only assume this is a typo in description...." Read Full Review »
Feb 22, 2008 by Zodjunior
See more positive Flashpoint Model II 320A Monolight, 150 Watt Second Strobe, 120 Volt reviews
2.0
Good, but...
"Test switch on back and wireless test button do not consistently fire the unit. [...] (hmmm....)Actual shooting - seems to fire better (95%)Works well with my more expensive units. My more expensive units have fired 100% for over 10 years...." Read Full Review »
Nov 02, 2009 by Don
See more negative Flashpoint Model II 320A Monolight, 150 Watt Second Strobe, 120 Volt reviews
Displaying 1 - 5 of 50 Reviews
Show
Sort by
5.0
    Pros
  • Attach Securely
  • Durable
  • Good Color Value
  • Long-Lasting
  • Powerful
    Cons
  • None
    Best Uses
  • Indoors
Picture and description is misleading, it looks like small cheap plastic body but is metal is has rugged build, and is larger than expected. Mine does not have audible ready beeper, and modeling light is not variable, I have checked reviews on Int …"  Read Full Review »
1 light portrait Flashpoint 320
  • Made with Product
Was this Camera Monolight review on the Flashpoint Model II 320A Monolight, 150 Watt Second Strobe, 120 Volt helpful to you?
 Report Abuse  (5)  (0)  0 comments
Feb 22 2008
Zodjunior
Akron, Ohio
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $99.95
I am happy with this product
4.0
    Pros
  • Attach Securely
  • Durable
  • Good Color Value
  • Powerful
    Cons
    Best Uses
  • General Use
"Remote sensor does not work at all in average lighted rooms. However because it does work in dimmed environment there is a great solution. Place any type of small cover over it (covering say 50% or so). this may be a small translucent cap or a small bent piece of cardboard 1x1 in. square or so and p …"  Read Full Review »
sensor covered with translucent cap
  • Sensor problem solved
  • Using Product
sensor covered partially by small cardboard
  • Picture of Product
Nov 3 2009
Roland the frenchman !
Stamford CT.
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $99.95
Worth every penny.
5.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Indoors
  • Low Light
  • Night Time
"I've shot several hundred photos with the 320A so far both tethered and using the optical slave function. The 320A has worked as expected every single time.
The mount (to attach it to the stand) feels a little "cheap" due to being made from stamped sheet metal and some type of synthetic material …"  Read Full Review »
Crocus in my back yard lit with the 320A.
  • Made with Product
With a white background.
  • Made with Product
Mar 30 2009
ArcLight
North Central Illinois
I am:
  • Photo Enthusiast
Reviewed at:
Price: $99.95
So far so great
4.0
    Pros
  • Consistent
  • Durable
  • Good Color Value
    Cons
  • none yet
    Best Uses
  • Indoors
  • Low Light
  • Night Time
  • Outdoors
  • Special Events
"This way exceeded my expectations. The build quality is very good for a monolight at this price. Even the dial has a nice smooth notched turn to it. I still expect it to conk out any day now but it really works well with consistent temp's. It also recycles very fast. I will be getting another one. "
single flashpoint monlight, bounced corner wall
  • Shot with flashpoint
  • Made with Product
Apr 2 2009
dmadden
jamaica
I am:
Reviewed at:
Price: $99.95
You will be very happy with this product
5.0
    Pros
  • Durable
  • Good Color Value
  • Long-Lasting
  • Powerful
    Cons
  • None
    Best Uses
  • General Use
  • Indoors
  • Low Light
  • Night Time
"I bought two of these they are a lot more powerfull they you would think they are , also added the 24 by 24 softboxes they have not missfired yet and the seem to have a great reboot time. Pic below is just using one light and needed very little adjustmets shooting in Raw. "
Ginger
Ginger
  • Made with Product
Ginger and tinell
Ginger and tinell
  • Made with Product
Feb 9 2009
damredhead
Kettering , OH
I am:
Reviewed at:
Price: $99.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
