Provided by NothingButSoftware
Connect to the world of data in so many new ways!
FileMaker Pro is the #1-selling easy-to-use database software for Windows and Mac OS that helps you manage people, projects, assets and
more - the easy way.
Get started quickly. The award-winning ease of use that is built into every
aspect of FileMaker Pro continues to be praised by millions of customers and
industry experts around the world. With its easy installation and setup,
you’ll be up and running in a matter of minutes - not hours or days.
Whether you need to manage client information, track project details, or
produce inventory reports, FileMaker Pro 9 helps you get your important
information organized in one place so it is instantly accessible.
Combining both power and simplicity, FileMaker Pro 9 gives you the tools you
need to connect to your data in more ways than ever before.
The Top 10 Things You Can Do Faster and Easier with FileMaker Pro 9:
- Manage customers, clients, and vendors
- Track inventory, products, and assets
- Organize pictures, video and other multimedia files
- Access project details and associated tasks
- Print invoices, letters and mailing labels
- Produce reports in PDF or Excel formats
- Create customized electronic forms that look just like your paper forms
- Design a custom application that works the way you do
- View live Web information associated with your data from within
FileMaker
- Share databases with Windows and Mac users simultaneously over the
network or across the Web.
Gather your information in one place
Information comes in many forms, from business cards to Microsoft Excel files,
images to SQL Server data – FileMaker Pro helps you bring it all together with
a few clicks. Convert Excel spreadsheets and other files to FileMaker Pro
databases for easier searching, sorting, reporting, and sharing. Or use powerful
productivity features designed to make data entry much faster and more accurate.
Instant access to the information you need
Use FileMaker Pro to organize, sort through, and find information from
individual contacts to large data sets. When someone calls, you will have the
contact history, the project state, or the shipment status right at hand. Bring
up records by date, location, or content. Create formulas and calculations and
summaries. You will be amazed how easy it is to be informed.
Report and communicate all your information
Transform data into useful information by creating reports and layouts that work
the way you do. FileMaker Pro comes complete with step-by-step tools that help
you create reports and then email them to your colleagues as Adobe PDF or Excel
files. Or choose from hundreds of pre-defined templates for labels and envelopes
to help get the word out with ease.
Power to take you further
Build powerful yet flexible custom applications using the FileMaker Pro
relational database management system. Design complete scalable solutions for
your organization and automate repetitive tasks with the powerful scripting
language, all without the help of a programmer.
Built-in network sharing and security
Securely sharing databases is easy with FileMaker Pro. Windows and Mac OS
FileMaker Pro users on the same network can access the same database file
simultaneously. And with the advanced security model in FileMaker Pro, you can
determine what your users can do and see.
Connect with the Web
Publishing basic web forms or web-based status updates and lists is simple with
the Instant Web Publishing feature built into FileMaker Pro. You can create web
forms for event sign-ups, customer feedback and service requests. Or setup
security privileges for your clients so they can login through their web browser
to get a status update. And you can harness the information that is available on
the Web by using the FileMaker Web Viewer to get real-time information from the
Web that is associated with your data without having to open a Web browser.
FileMaker Pro 9 also includes these new and exciting features:
- Field Level Spell Checking so you can turn on or off
visual spell-checking for individual fields.
- Multiple Undos and Redos so you can undo and redo
more than once when editing text within a field.
- Enhanced Toolbars, including the new Align Toolbar
for faster layout design and an updated Standard Toolbar that includes
buttons for PDF Maker and Excel Maker.
- 10 additional Avery labels layouts including
Shipping Labels ideal for packaging and printing postage.
New! Connect to Your FileMaker Data
On your mark, get set, connect!
Connect directly to the information you need every time you launch FileMaker Pro
9 with the new FileMaker Quick Start Screen. Whether you want to create a new
database, open an existing database or learn more about using FileMaker Pro 9,
you’ll get to where you need to go faster than ever.
At-a-glance indicators
Connect to changes in your FileMaker Pro 9 data by visually formatting fields
and objects based on parameters that you decide! New Conditional Formatting can
be applied to fields, FileMaker Web Viewer objects, text objects, or text based
buttons. Choose from a list of pre-defined conditions or create your own with a
calculation for enhanced reporting. For example, you can now set future due
dates to green and past due dates to red and bold.
Database sharing made even easier
In just a few minutes, you can be sharing your database with others 1.
Just click on Send Link and FileMaker Pro will create an email with a simple
hyperlink that when clicked on, will open your database. You can edit the email
in your email client to add any additional instructions or information about
your database for your users making it easier than ever for your users to
connect to your database.
Effortless reporting
Whether you want to create an invoice to send to a customer or publish a report
to your team, FileMaker Pro 9 makes it easy to create an Adobe PDF from your
FileMaker data directly within FileMaker using PDF Maker, a feature introduced
in FileMaker Pro 8. Now, with the new Append to PDF feature, you can combine
multiple reports into one PDF and email the PDF to the recipients you specify,
connecting them to the latest information.
Latest Updates
Stay current with the latest software with new Software Update Notification.
FileMaker Pro 9 automatically checks for software updates weekly. All it takes
is an Internet connection.
1 User must have FileMaker Pro installed on their computer and must have
access to the host computer.
New! Connect to Your SQL Data
Easy SQL reporting
Imagine that you could connect to your organization’s SQL Server, Oracle and
MySQL databases from one place and use the information without having to do any
programming. Now you can! FileMaker Pro 9 creates secure easy one-way or two-way
connections to External SQL Data Sources. The coolest thing
about it? The SQL data acts just like FileMaker data. Create custom reports, add
calculations and other fields, build relationships with existing FileMaker data
– just using the easy-to-use tools of FileMaker Pro.
New! Connect to Your Creativity
Super script organizing
The more scripts you add to automate your solution, the more important it is to
stay organized. That’s why you’ll appreciate how easy FileMaker Pro 9 makes
it to group and edit your scripts with the new Script Grouping and Editing
Tools.
Creativity at your fingertips
Connect to your creativity! Now you can design better and more creative layouts
with intuitive new layout object tools. Modify the tab sizes with the new Tab
Control options. Add a status bar or display HTML content stored in your
database with the new FileMaker Web Viewer options.
One size fits all
Design it once. Use it anywhere. Layout objects, such as portals, tab controls,
and the FileMaker Web Viewer, will scale to fit the screen or printer being
used. With the new Auto-Resize feature, layout objects that you choose will
resize or move in order to maintain a constant distance to the sides of the
window or container that they have been anchored to.
- Mac OS X 10.4.8 *
- PowerPC G3, G4, G5 or Intel-based Mac
- 256 MB of RAM
- CD-ROM drive
- Windows XP Professional, Home Edition (Service Pack 2) *
- Pentium III 500MHz or higher
- 256MB of RAM
- CD-ROM drive
- SVGA (800 x 600) or higher resolution video adapter and display
- Windows Vista Ultimate, Business, Home *
- 800 MHz 32-bit (x86) or higher
- 512 MB of RAM
- SVGA (800x600) or higher resolution video adapter and display
- CD-ROM drive
* Version stated is the minimum requirement. The software may also work with
later versions certified by FileMaker, Inc.
Additional requirements (all platforms)
- Networking: TCP/IP: limited to nine simultaneous FileMaker client
connections; each client requires a licensed copy of the software; See
FileMaker Server 9 for increased capacity.
- Any computer accessing FileMaker Pro files over a network will need to
have a licensed installation of versions 7, 8 or 9 of FileMaker Pro or
FileMaker Pro Advanced.
- Instant Web Publishing: A host computer with continuous access to the
Internet or intranet via TCP/IP (FileMaker Pro 9 can manage up to five
simultaneous Instant Web Publishing sessions. See FileMaker Server 9
Advanced for increased capacity.)
- Web browser requirements: To use a database shared with Instant Web
Publishing, Windows web users need Microsoft Internet Explorer version 6.x
or Firefox 1.x on Windows. On the Mac OS, web users need Safari 1.2.x (Mac
OS X 10.3), Safari 2.0.x (Mac OS X 10.4) or Firefox 1.x only. On both
platforms, some earlier versions of Microsoft Internet Explorer and Safari
are blocked. Other Mozilla family browsers are not blocked but are
unsupported and users will receive a dialog encouraging them to upgrade to a
supported browser. JavaScript must be enabled in the web browser.
