Fanner MassCool 8WA741 CPU Fan
#11
4.6
based on 134 reviews
Ratings Distribution
5 star
91
4 star
28
3 star
6
2 star
2
1 star
3
Category Average
4.3
Low Price:
$19.99 at CompUSA
 Trusted:
$19.99 at TigerDirect
Find it at Amazon
$19.99
from 2 stores
Fanner MassCool 8WA741 CPU Fan Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 26, 2009
Fanner MassCool 8WA741 CPU Fan Reviews
Most helpful positive review
Most helpful negative review
5.0
I was worried when I ...
"I was worried when I ordered this puppy because of its shear size. This went into my new ASUS P5Q mobo and Intel Core 2 Duo E7200 CPU setup and am I glad I got this tower. I must say pulling this out of the box and looking at where it had to fit on the mobo was a bit scary, but it worked great! You need to make sure you mount the CPU and this cooling tower first before installing your mobo into a case. There is ..." Read Full Review »
Aug 09, 2008 by Anonymous
See more positive Fanner MassCool 8WA741 CPU Fan reviews
3.0
I got this unit because ...
"I got this unit because of the reviews, and I don't know if I got a bad one or what. But basically, an E2180 chip at 2.7. This unit ran 8-9 degrees hotter than a Masscool 8W553. This was using the ''Torture Test'' with Prime95. I shut down Prime95 quickly because it shot up to 66 degrees and wasn't coming down. Idle temperature was hotter as well. I put the 8w553 back in, and ran a stress test, and got the sa..." Read Full Review »
Aug 27, 2008 by granadaCod
See more negative Fanner MassCool 8WA741 CPU Fan reviews
Displaying 1 - 5 of 134 Reviews
Show
Sort by
I built a new system last ...
5.0
"I built a new system last year and wanted a good heat sink to protect my new Q6600. I read good reviews on the 8WA741 and ordered it. The thing was huge. It went on nicely though (spring loaded screws, not cheap plastic pins). It kept my CPU below 40C under all loads, so I was very happy.
After a li …"  Read Full Review »
Was this Computer Fan & Cooling System review on the Fanner MassCool 8WA741 CPU Fan helpful to you?
Oct 30 2009
Lyonhart
Undisclosed
Been using this for 2 ...
5.0
"Been using this for 2 months now. Runs silent and keeps my 3.0 dhz duel core way cooler than the stock fan heatsink. Installation for a socket 775 does require that you remove the motherboard to replace the bracket for the screw posts but is a small price to pay for real screws, plactic pushin pins …"  Read Full Review »
Nov 5 2009
BERGFURGALER
Undisclosed
3.0
I shut down Prime95 quickly because it shot up to 66 degrees and wasn' …"  Read Full Review »
Aug 27 2008
granadaCod
Undisclosed
5.0
"I was worried when I ordered this puppy because of its shear size. This went into my new ASUS P5Q mobo and Intel Core 2 Duo E7200 CPU setup and am I glad I got this tower. I must say pulling this out of the box and looking at where it had to fit on the mobo was a bit scary, but it worked great! You …"  Read Full Review »
Aug 9 2008
Undisclosed
Bought it for my Intel ...
4.0
"Bought it for my Intel 775 Q5700...... Pros..: Good price for performance. Don't have the temperature numbers yet but it should be good. I hope. It's pretty big but, It isn't over sized...... Cons..: Opened the package to find that all the parts came out of the plastic case and was scattered about i …"  Read Full Review »
Dec 17 2008
rouge02
Undisclosed
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
