Epson P-7000 160GB Hard Drive Portable Media Player
#32
3.8
based on 19 reviews
Ratings Distribution
5 star
11
4 star
3
3 star
0
2 star
0
1 star
5
Category Average
3.7
$29.98 - $822.99
from 16 stores
Pros
  • Easy to use (16)
  • Durable (9)
  • Reliable (7)
  • Lightweight (5)
  • Clear image (3)
  • Easy photo upload (3)
  • Attractive design (2)
  • Improves product function (2)
  • Big capacity (1)
  • High quality display (1)
See less See more
Cons
  • Not durable (3)
  • Not functional (2)
  • Poor design (2)
  • Pricey (2)
  • Blurry image (1)
  • Delete mode is difficult (1)
  • Difficult to use (1)
  • Heavy / bulky (1)
  • Large (1)
  • Won't accept firmware (1)
Best Uses
  • Travel (11)
  • Macro (5)
  • Home (4)
  • Landscapes (4)
  • Everyday (3)
  • Portraits (3)
  • Studio (2)
  • Any on-location work (1)
  • Photo trips safaris (1)
  • Photography display (1)
Provided by eAngler.com
Superior image quality for professionals.
An essential tool for the on-the-go, professional photographer, the Epson P-7000 offers superior image quality, plus a high-capacity, 160GB hard drive. The perfect partner to your digital SLR camera, this powerful device makes it easier than ever to backup and view thousands of photos on the spot.
Preview both RAW and JPEG images while on location with the Photo Fine® Premia LCD, exclusively from Epson. Displaying over 16.7 million colors, this 4-inch LCD supports 94% of the Adobe® RGB color space, so you get incredible color accuracy. Zoom in to confirm focus and fine detail. Then, share your images the way they were meant to be seen - just as you captured them. With both audio and video output, it’s easy to create customized slide shows to take your digital portfolio with you wherever you go. The portable P-7000 is the perfect choice for client presentations or on-location shoots. Why transport your laptop when you can quickly store and backup images right from your memory card using this convenient, compact device? With the Epson P-7000 and its included Travel Pack, you’ve got everything you need for all your photographic assignments.
  • Exclusive 4-inch Epson Photo Fine Premia LCD
  • Displays over 16.7 million colors
  • Encompasses 94% of Adobe ® RGB color space
  • 160GB hard drive
  • Faster download speed - up to 35% faster than previous models
  • Zoom function to confirm focus/fine detail
  • JPEG and RAW file support
  • Jog dial to scroll through images
  • Long battery life for extended photo shoots
  • Audio/video output
  • Travel Pack - battery charger, car adapter & more
  • Achieve a more efficient, on-location workflow with this essential tool
  • Zoom in to confirm focus and fine detail with the large, 4-inch Epson Photo Fine Premia LCD(displays over 16.7 million colors)
  • View images with amazing color accuracy with 94% Adobe RGB color space support
  • Store thousands of RAW and JPEG files on high-capacity, 160GB hard drive
  • Save time - up to 35% faster download speed than previous Epson Multimedia Viewers
  • Back up images on the spot with built-in memory card slots (CompactFlash® and Secure Digital support)
  • Quickly scroll through images with convenient jog dial navigation
  • Create customized slide shows with both audio and video output
  • Enjoy long battery life for extended photo shoots
  • Quickly transfer files from one device to another with Hi-Speed USB 2.0
  • Get greater portability with included Travel Pack (dual battery charger, car adapter and more)
  • Specification Description
    Model B31B192002, b31b192002
    UPC 010343866829
    Select Stand Alone Storage
    Select Capacity 160 GB
    Epson P-7000 160GB Hard Drive Portable Media Player Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 1, 2009
    Epson P-7000 160GB Hard Drive Portable Media Player Reviews
    Most helpful positive review
    [1 of 1 customers found this review helpful]
    Most helpful negative review
    [4 of 7 customers found this review helpful]
    4.0
    An expensive, but useful tool
    "I purchased the Epson P-7000 so that I wouldn't have to worry about carrying around two dozen 4GB cards with me on a day or more of shooting, and for this purpose it serves its purpose well. The P-7000 is unfortunately rather large; it's comparable to large "media" players like the Archos 7. The device measures a full 6" wide, 3.5" high, and 1.6" thick. When enclosed in the included protective case, the case i..." Read Full Review »
    May 31, 2009 by N/A
    See more positive Epson P-7000 160GB Hard Drive Portable Media Player reviews
    1.0
    Do Not Buy This!!!!!
    "This is supposed to be a safe place to store your photos. Instead it crashes and your photos are lost forever. I spent 1 month shooting in Costa Rica, and presold photos to clients via preview. But then the P-70000 would not start up, instead giving an 'invalid file structure' error. Epson's technical support was completely useless, and offered only to fix the device, offering no options for data recovery. While..." Read Full Review »
    Jan 06, 2009 by leif baker
    See more negative Epson P-7000 160GB Hard Drive Portable Media Player reviews
    Displaying 1 - 5 of 19 Reviews
    Show
    Sort by
    4.0
      Pros
    • Attractive Design
    • Clear Image
    • Easy Photo Upload
    • Easy To Use
      Cons
    • Expensive
    • Large
      Best Uses
    • Photography Display
    The P-7000 is unfortunately rather large; it's comparable to large "media" players like the Archos 7. The …"  Read Full Review »
    Was this Digital Picture Frame review on the Epson P-7000 160GB Hard Drive Portable Media Player helpful to you?
     Report Abuse  (1)  (0)  0 comments
    May 31 2009
    N/A
    Los Angeles, CA
    I am:
    • Quality Oriented
    Reviewed at:
    Price: $714.95
    The No.1 Multimedia Photo Viewer
    5.0
      Pros
    • Durable
    • Easy To Use
    • Reliable
      Cons
    • None
      Best Uses
    • Everyday use
    • Home
    • Landscape Photography
    • Macro Photography
    • Portraits
    • More »
    "I have Epson P-2000 when it came out. This was a great photo viewer/storager. People compliant its so slowly than others which only download photos w/o LCD screen. Since I upgraded my camera from 20D to 40D two years ago, I need a hugh space photo storager to backup my wedding photo during the event …"  Read Full Review »
    Dec 18 2008
    NTKY
    Seattle, WA
    I am:
    • Semi-Professional
    Reviewed at:
    Price: $714.95
    Handy backup storage and image viewing
    5.0
      Pros
    • Durable
    • Easy To Use
    • Reliable
      Cons
    • None
      Best Uses
    • Traveling
    "I love my new P-7000. It has slots for both SD and CF cards and is very easy to use in the field to back up cards. I still bring along a laptop and multiple hard drives, but use the P-7000 as one of my backup drives and also as my failsafe plan in case my laptop dies or is stolen in the field. Th …"  Read Full Review »
    Feb 22 2009
    Craig
    Arlington Heights, Illinois
    I am:
    • Professional
    Reviewed at:
    Price: $714.95
    [2 of 2 customers found this review helpful]
    Quick and Easy to use
    5.0
      Pros
    • Easy To Use
    • Lightweight
    • Reliable
      Cons
    • None
      Best Uses
    • Traveling
    "I'm a pro photographer and bought the Photo Viewer for a 3 week combined holiday and photography trip abroad. It's quick and easy to backup your photos from CF or SD cards and the graphics quality for reviewing them is pin-sharp so you can already start editing before you even get back to your comp …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Jan 13 2009
    Kazzabunga
    Singapore
    I am:
    • Professional
    Reviewed at:
    Price: $714.95
    Smooth, easy and fast
    5.0
      Pros
    • Durable
    • Easy To Use
    • Improves Product Function
    • Lightweight
      Cons
    • None
      Best Uses
    • Traveling
    "I bought this item to cover my needs of storing and watching photo files at the field without using a laptop.
    P/7000 was the best choice for me because I`m shooting big RAW files and need a lot of hard disk space. This one have more than enough(160GB).
    This product is very easy to use. It`s …"  Read Full Review »
    Oct 8 2008
    diver007
    Stockholm, Sweden
    I am:
    • Semi-Professional
    Reviewed at:
    Price: $714.95
    pages: 1 2 3 4 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
