Envision 1010202 Envision L32W961 32" LCD HDTV
#507
4.5
based on 23 reviews
Ratings Distribution
5 star
11
4 star
10
3 star
1
2 star
0
1 star
0
Category Average
4.4
$349.99 at RadioShack
Find it at Amazon
Find it at Ebay
$349.99
from 1 store
More Images
Pros
  • Fast setup (16)
  • Attractive design (15)
  • Bright image (15)
  • Simple controls (15)
  • High resolution (14)
  • Reduced glare (13)
  • Good connection options (11)
  • Clear picture (3)
  • Easy setup (3)
  • Simple / intuitive controls (3)
See less See more
Cons
  • Poor sound quality (7)
  • Audio could be better (1)
  • Audio isn't amazing (1)
  • Difficult to set up (1)
  • No program guide (1)
  • Poor connection options (1)
Best Uses
  • Movies (11)
  • Bedroom (10)
  • Home (9)
  • Wall mounting (8)
  • Home theater (4)
  • Dorm room (2)
  • Great first lcd tv (1)
  • Office (1)
  • Small rooms (1)
Provided by RadioShack
This stylish, budget-friendly 32" (31.5" diagonal) LCD HDTV will brighten any room.
Specification Description
Model L32W961
16:9 Mode Yes
Benefits 32" (31.5" diagonal) LCD HDTV with 20,000:1 dynamic contrast ratioHDMI, VGA, component, S-video, composite & TV/cable inputs for grea
Brightness 500 cd/m2
Capacity UOM mAh
Closed Caption Capability Yes
Connections Composite video/LR audio (2)Component video (2)S-Video/LR audio (2)HDMI (3)Headphone out (1)Audio
Country Of Origin China
Description Header HDTV for you!
Display Catalog Number 16-919
Display Menu Language Multiple language support
Enclosure Color Black
End Product Indicator Yes
Image Aspect Ratio 16:9
Included in the Box L32W961 LDC HDTVRemote control
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Model L32W961
New Date Tue Sep 01 00:00:00 CDT 2009
Operating Temperature UOM ° F
Output Power / Total 20 watts
Pixel Response Time 6.5 ms
Power Device AC
Product Depth 9.2
Product Dimensions UOM inches
Product Height 22.2
Product Type Flat-panel TVs
Product Weight 27.1
Product Weight UOM pounds
Product Width 31.2
Reception System ATSC/NTSC
Remote Control Type Product
Screen Size Range 31-40"
Secondary Audio Program (SAP) Yes
Speaker(s) 2 built-in
Speakers Included 2 Speakers
Stereo Reception System MTS
Supported Languages English
Technology IR
TV Diagonal Size 31.5 inches
TV Image Contrast Ratio 20000:1
TV Resolution 1366x768
TV Technology LCD
V-Chip Control Yes
Viewing Angle 178 Degrees
Viewing Angle (Vertical) 178 Degrees
Voltage Required AC
Envision 1010202 Envision L32W961 32" LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
Envision 1010202 Envision L32W961 32" LCD HDTV Reviews
Most helpful positive review
[7 of 8 customers found this review helpful]
Most helpful negative review
4.0
Bright Beautiful Coloful Picture
"Most likely you will have to spend much more for a TV that has the Great Picture Quality and many new features of the Envision L32W961. When you shop for an HDTV LCD television, remember that the product name should not be your sole consideration, analyze the entire scenario. When all things are considered ,if you purchase the new Envision L32W961 you may just end up saving money for a better functioning produc..." Read Full Review »
Jul 08, 2009 by NYSOFTWAREMAN
See more positive Envision 1010202 Envision L32W961 32" LCD HDTV reviews
3.0
Audio needs some work...
"We bought this tv a few days ago and the picture quality is average; good for the price. The audio, however, is awful. We bought this tv to watch while working out or just watching movies in our room. We were hoping to enjoy our music channels, but we aren't sure about the quality. Our other main television is much better so maybe we are just used to that one...." Read Full Review »
Sep 03, 2009 by LP
See more negative Envision 1010202 Envision L32W961 32" LCD HDTV reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Clear Picture
  • Easy Controls
  • Easy To Set Up
    Cons
  • Poor Audio
    Best Uses
  • Dorm Rooms
  • Movies
  • Office
  • Small Rooms
"Most likely you will have to spend much more for a TV that has the Great Picture Quality and many new features of the Envision L32W961. When you shop for an HDTV LCD television, remember that the product name should not be your sole consideration, analyze the entire scenario. When all things are con …"  Read Full Review »
ENVISON L32W961 - In My Living Room
  • Picture of Product
  • Using Product
Was this LCD TV review on the Envision 1010202 Envision L32W961 32" LCD HDTV helpful to you?
 Report Abuse  (7)  (1)  0 comments
Jul 8 2009
NYSOFTWAREMAN
New York, NY
I am:
  • Enthusiast
[2 of 2 customers found this review helpful]
Audio is its weakest spot.
4.0
    Pros
  • Clear Picture
  • Easy Controls
  • Easy To Set Up
    Cons
  • Poor Audio
    Best Uses
  • None
"There is no startup wizard, yet accessing the menus and performing the channel scan is very easy. Also, the channel scan is relatively fast compared with other TV models. Big props to AOC for including compatibility with both digital tuners, ATSC for antenna use and ClearQAM for cable TV. This is a …"  Read Full Review »
L32W961 TV with connected peripherals.
  • Using Product
 Report Abuse  (2)  (0)  0 comments
Aug 3 2009
RCC2k8
San Juan, PR
I am:
  • Enthusiast
L32W691 Program Guide
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Connection Options
    Cons
  • None
    Best Uses
  • None
"I admit I haven't purchased my first flat-screen TV yet but after viewing many different models, on a features vs. cost basis, this appears to be a top pick in the 32 inch category.
Most sets of this type deliver a great picture when receiving an HD signal. On the other hand, lower resolution …"  Read Full Review »
Oct 24 2009
Radioman
Appleton, WI.
Best Buy for the price
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • Poor Sound
    Best Uses
  • Bedroom
  • Home
  • Movies
"This TV is displayed next the Samsung 360 in most RadioShack stores. I compared them for a half hour before I purchased it. There was no way the Samsung was worth One Hundred and Fitty Dollars more. The Envision also has more features. If you want the best picture possible. Then buy an inexpensive H …"  Read Full Review »
Aug 7 2009
STU007
Boston, Mass
I am:
  • Enthusiast
Best HDTV for the money
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • No Program Guide
  • Poor Sound
    Best Uses
  • Bedroom
  • Wall Mounting
"This is the best 32" HDTV for the money. It has almost everything, 3 HDMI, 2 Componet, 1 Composit, SVGA and VGA inputs and digital out. 20000:1 contrast more than any set in this price range. I do have one major con. There's no Program Guide, you can not see a list of programs, most HDTV's have this …"  Read Full Review »
Oct 20 2009
Troublemann
Chicago
I am:
  • Power User
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
