Envision 1010202 Envision L19W961 19" LCD HDTV
5.0
based on 3 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.2
$179.99 at RadioShack
Find it at Amazon
Find it at Ebay
$179.99
from 1 store
Pros
  • Clear picture (2)
  • Easy setup (2)
  • Attractive design (1)
  • Great sound quality (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Confusing / difficult controls (1)
  • Horizontal av inputs (1)
Best Uses
  • Small rooms (3)
  • Dorm room (1)
Provided by RadioShack
When a smaller TV meets your personal needs, make it this 19" LCD HDTV from Envision.
Specification Description
Model L19W961
16:9 Mode Yes
Audio Controls Auto Audio Mode(Standard, Movie, News or Custom), Bass, Treble, Balance, Audio Source
Benefits 19" LCD display gives you clear high-definition performance with a 15000:1 dynamic contrast ratioDigital tuner for over-the-air digit
Brightness 300 cd/m2
Capacity UOM mAh
Closed Caption Capability Yes
Color Temperature Control Yes
Connections Composit video (1)S-Video (1)Component (1)HDMO (1)VGA (1)Headphone (1)Optical audio out
Country Of Origin China
Description Header HDTV in a small package.
Display Catalog Number 16-918
Display Menu Language Multiple language support
Enclosure Color Black
End Product Indicator Yes
Image Aspect Ratio 16:9
Included in the Box L19W961 Envision 19" LCD HD TVRemote control
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Model L19W961
New Date Tue Aug 11 00:00:00 CDT 2009
Operating Temperature UOM ° F
Parental controls Yes
Power Consumption Operational 55 watts
Power Device AC
Product Depth 6.7
Product Dimensions UOM inches
Product Height 13.6
Product Type Flat-panel TVs
Product Weight 11
Product Weight UOM pounds
Product Width 18.3
Reception System ATSC/NTSC/QAM
Screen Size Range 10-20"
Secondary Audio Program (SAP) Yes
Speaker(s) Built-in
Supported Languages English
Tuner Qty 2 Tuners
TV Diagonal Size 19 inches
TV Image Contrast Ratio 15000:1
TV Resolution 1360x768
TV Technology LCD
V-Chip Control Yes
Viewing Angle 170 Degrees
Viewing Angle (Vertical) 170 Degrees
Envision 1010202 Envision L19W961 19" LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 17, 2009
Envision 1010202 Envision L19W961 19" LCD HDTV Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[3 of 3 customers found this review helpful]
Great for PS3 and 360!
5.0
    Pros
  • Clear Picture
  • Easy To Set Up
    Cons
  • Horizontal AV Inputs
    Best Uses
  • Dorm Rooms
  • Small Rooms
"1080i support with HDMI, Great for gaming, FPS looks awesome and 1080i looked better then 720p with PS3. Optical output for this low price TV is super. For a budget TV this is fully loaded and has enough to make one happy. TV also DOES tilt back and forth a lil for viewing angle adjustments. "
Was this Television review on the Envision 1010202 Envision L19W961 19" LCD HDTV helpful to you?
 Report Abuse  (3)  (0)  0 comments
Aug 30 2009
Edward M.
Virginia Beach, VA
I am:
  • Power User
[2 of 2 customers found this review helpful]
Does Exactly What I Hoped!!
5.0
    Pros
  • Clear Audio
  • Clear Picture
  • Easy Controls
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Small Rooms
"I was looking for a small flat panel HDTV for my small bedroom in my apartment. I wanted great high-def performance without the need for cable or satellite which I don't have in my bedroom. I also bought an indoor amplified HDTV antenna. I get Fox, NBC, ABC, CBS, CW, MyNetwork TV plus PBS, and a cou …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Oct 17 2009
Fraevo
Wixom, MI
I am:
  • Enthusiast
[4 of 5 customers found this review helpful]
Very good piece
5.0
    Pros
  • Attractive Design
    Cons
  • Difficult Controls
    Best Uses
  • Small Rooms
"I bought it for 1.5 months. This is a very excellent piece. I can use as TV and as monitor. Strongly recommend. "
 Report Abuse  (4)  (1)  0 comments
Aug 13 2009
Luke Chiu
Fremont, CA
I am:
  • Power User
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
