Energy RC-Micro Black 5.1-Channel Home Theater Speaker System
#869
4.3
based on 4 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
1
1 star
0
Category Average
4.4
Low Price:
$599.00 at OneCall
 Trusted:
$599.00 at Vanns.com
Find it at Amazon
$599.00 - $999.00
from 3 stores
Pros
  • Attractive design (3)
  • Crisp sound (2)
  • Easy to connect (2)
  • Great sound quality (2)
  • Powerful (1)
See less See more
Cons
  • Poor sound quality (2)
  • Not very powerful (1)
Best Uses
  • Basic systems (3)
  • Home theater (2)
  • Smaller rooms (2)
Provided by OneCall
The lowdown
RC-Micro proves beyond doubt that small can still be powerful. And, it shatters any illusions about packaged home theater systems; you won’t get better performance, or better looks, even if you buy individual pieces.
This system delivers lifelike performance from your favorite games and movies, with their screaming aluminum cone tweeters to the massive bottom end provided by the woofers and the sub, which features a Ribbed Elliptical surround for great bass extension. Keyhole slots and threaded inserts let you choose how and where to place your speakers.
Bragging rights
The RC Micro 5.1 components were developed with Energy’s audio principles in mind:
Flat On-Axis Frequency Response with Wide Bandwidth: Speakers should reproduce the entire audio range in a uniform manner. By ensuring that no one frequency dominates any other, Energy ensures that every note is the way it was intended to be—and the sound as natural as possible.
Wide and Constant Dispersion: Sound at all frequencies radiating from the speaker should be in an even pattern, in all directions throughout the room.
Low Distortion and Resonance: No speaker system is distortion- or resonance-free, but Energy has achieved a significantly lower distortion level, a clearly audible improvement.
The RC Micro 5.1 home theater system offers terrific performance and great features:
  • Ribbed Elliptical Surround woofers create high efficiency, low distortion
  • An aluminum dome tweeter for sonic accuracy
  • Magnetic shielding to eliminate interference with CRTs
  • The RC-Micro 5.1 home theater speaker system offers amazing performance in an amazingly small package. It includes a powerful 240-watt subwoofer with a down-firing port, 8-inch driver and Ribbed Elliptical surround for bass that you feel as much as hear. The .50-inch hyperbolic aluminum dome tweeter on the satellites and center channel focuses sound for clearer dialogue and stirring music. Gold plated push connectors ensure positive connection for top-flight performance.
    Maximum performance tips:
    The center channel speaker needs to be centrally located so that the dialogue appears to be coming from the center of the screen. It needs to be above or below the monitor, as closely to it as possible. If you’re using a rear projection television, the most likely option is to place it above the screen. If you have a front projection system, you have choices—stand mounting, or placement on furniture, for example. It is important, though, to place the speaker so that its front edge is even with the edge of the shelf or stand supporting it. Unwanted diffraction occurs when the center channel is too far back into a cabinet or other surface with edges that could impede sound dispersion.
    For left or right front channels, the distance between the speakers should be 6-8 feet at minimum for the best stereo imaging. The optimum room shape is rectangular, with the speakers along one of the shorter walls, facing the opposite side. If possible, do not place speakers against a wall or at rear of a bookshelf; corner placement is usually the worst option. Try to keep the speakers—especially rear vented models—at least two feet from the surface behind it, unless you use a vent plug. For best results mounting on a rear wall, position the speakers so they flank the main listening area and point toward the front of the room. They should be raised to a height of approximately six feet and should ideally have a space of six feet between them.
    The three most common subwoofer locations include corners (which can result in boomy or exaggerated low frequency response), placement along a wall, away from the corner (producing moderate bass performance with increased fidelity over corner placement), or beside a front speaker (creating a better blend with the front speaker, but sacrificing overall volume). Experimentation with subwoofer placement is highly encouraged; slight adjustments can create big differences in sound reproduction. To test subwoofer placement, install it temporarily in your main listening position and walk around the listening room while playing a familiar piece of music until you find the best sounding position.
    Specification Description
    Model RC Micro
    UPC 629303300336
    Color Black
    Crossover Frequency 3.5kHz
    Frequency Response Sat: 150Hz-23kHz
    Frequency Response Subwoofer: 36Hz-180Hz
    Impedance 8 ohms
    Magnetic Shielding Yes
    Midrange Size (Inches) 2.5
    Sensitivity 88db
    Speaker Terminals Push type
    Subwoofer 240-watt
    Subwoofer 8 Inch
    Tweeter Size (Inches) .5
    Energy RC-Micro Black 5.1-Channel Home Theater Speaker System Questions
    Questions and Answers
    Where to Buy
    $999.00
    $599.00
    BizRate Rating Outstanding 9.1
    $599.00
    BizRate Rating Outstanding 9.2
    Product Reviews
    Last update: Sep 15, 2009
    Energy RC-Micro Black 5.1-Channel Home Theater Speaker System Reviews
    Displaying 1 - 4 of 4 Reviews
    Show
    Sort by
    [5 of 5 customers found this review helpful]
    Awesome sound quality
    5.0
    "The Energy RC-Micro 5.1 surround sound speakers pack awesome sound in small and rather stylish design. I am not an audiophile, but I used to have large Infinity speakers that sat on the floor, and these Energy speakers have sound quality far superior to them.
    The powered bass rocks the house and c …"  Read Full Review »
    Was this Speaker & Subwoofer review on the Energy RC-Micro Black 5.1-Channel Home Theater Speaker System helpful to you?
     Report Abuse  (5)  (0)  0 comments
    Apr 18 2009
    D. Boisvert
    Amazon
    Reviewed at:
    Price: $999.00
    Great quality and sound
    5.0
      Pros
    • Attractive Design
    • Crisp Sound
    • Easy To Connect
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Basic Systems
    • Home Theater
    • Smaller Rooms
    "These speakers look and sound great. The only thing I didn't like was that subwoofer requires split L and R subwoofer cable. The manual claims that it needs a standard male-to-male RCA cable, but it is not the case. (Look at pictures of the back of subfooer). It does not use standard one-plug subwoo …"  Read Full Review »
    Sep 15 2009
    dimak
    Fremont, CA
    I am:
    • Movie Enthusiast
    Reviewed at:
    Price: $599.00
    Amazing design and quality
    5.0
      Pros
    • Attractive Design
    • Crisp Sound
      Cons
    • None
      Best Uses
    • Basic Systems
    • Home Theater
    • Smaller Rooms
    "These speakers look and sound great. The only thing I didn't like was that subwoofer requires split L and R cable. It does not use standard one-plug subwoofer jack. It was hard to find this non-standard 2-to-1 split subwoofer cable and I couldn't use a high-end subwoofer cable, like Moster makes. "
    Sep 15 2009
    dimak
    Fremont, CA
    Reviewed at:
    Price: $599.00
    [0 of 1 customers found this review helpful]
    not impressed
    2.0
      Pros
    • Attractive Design
    • Easy To Connect
      Cons
    • Distorted Sound
    • Not Very Powerful
    • Poor Sound Quality
      Best Uses
    • Basic Systems
    "They just don't have a very full sound. I was disapointed "
     Report Abuse  (0)  (1)  0 comments
    Aug 3 2009
    liuping
    San Diego, CA
    I am:
    • Professional
    • Tech Savvy
    Reviewed at:
    Price: $599.00
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
