Ellington Weather One Weather Broadcast Receiver - 1-Piece
#150
2.9
based on 17 reviews
Ratings Distribution
5 star
3
4 star
4
3 star
3
2 star
2
1 star
5
Category Average
3.8
$9.95 at Sierra Trading Post
Find it at Amazon
Find it at Ebay
$9.95
from 1 store
Pros
  • Lightweight (9)
  • Durable (7)
  • Great reception (3)
  • Great sound quality (3)
  • Compact (2)
  • Easy to use (1)
  • External antenna jack (1)
  • Good battery life (1)
  • Small easy to pack (1)
See less See more
Cons
  • Poor sound quality (4)
  • A bit on the cheap side (1)
  • Does not receive (1)
  • Flimsy (1)
  • Low volume (1)
  • Made cheaplynot good qua (1)
  • Only 3 of 7 nws stations (1)
  • Poor reception / weak antenna (1)
  • Static filled reception (1)
Best Uses
  • Travel (5)
  • Home use (4)
  • Good for commuting (2)
  • Camping (1)
  • Car camping (1)
  • Day trip (1)
  • Everyday (1)
  • Fishing (1)
  • Hurricane kit (1)
  • Ocean kayaking and island (1)
Provided by Sierra Trading Post
Closeouts . Ellington's Weather One weather broadcast receiver is tuned to NOAA/National Weather Service broadcasts for up-to-the-minute information when weather turns severe. Battery-operated for when the power is out, so you can still get information even during severe storms. 1-Piece Requires one 9V battery (not included). Includes: Telescoping antenna or external antenna jack Crystal tuner Receiver dimensions (LxWxD) : 5x3x11/8" Receiver weight : 6.8 oz. Closeouts. China.
Ellington Weather One Weather Broadcast Receiver - 1-Piece Questions
Questions and Answers
Where to Buy
$9.95
Code ALNOVEMBER9 : 15% Off $100 & 20% Off $150
BizRate Rating Outstanding 9.0
Product Reviews
Last update: Sep 4, 2009
Ellington Weather One Weather Broadcast Receiver - 1-Piece Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[6 of 6 customers found this review helpful]
4.0
Good for the price
"This is a good basic weather radio - popped in a battery and it worked just fine. A couple of things to note: this is a very inexpensive radio with a small speaker - don't expect high fidelity, but that's OK; it does the job. Before buying, check your local NOAA Weater Radio broadcast frequency (use your favorite web search engine) and ensure that this radio receives it - you only get 3 frequencies on this rad..." Read Full Review »
Aug 22, 2009 by WaterBoy G
See more positive Ellington Weather One Weather Broadcast Receiver - 1-Piece reviews
2.0
Did not perform as expected
"Of the 3 stations received, only high powered Tx in area "downwind" in range of used location. We already had the weather just being warned about. Ok if you need 5-day forecast, not good for dangerous weather. Receives 164.400,162.475,162.550. Check [@] for transmitters. OK product **if** your local station is one of these 3 frequencies...." Read Full Review »
May 08, 2008 by Tool-using Mom
See more negative Ellington Weather One Weather Broadcast Receiver - 1-Piece reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
2.0
    Pros
  • Compact
    Cons
  • Low volume
  • Needs external antenna
  • Only 3 of 7 NWS stations
    Best Uses
  • Car Camping
  • Day trip
"Of the 3 stations received, only high powered Tx in area "downwind" in range of used location. We already had the weather just being warned about. Ok if you need 5-day forecast, not good for dangerous weather. Receives 164.400,162.475,162.550. Check [@] for transmitters. OK product **if** your local …"  Read Full Review »
Was this Portable Radio review on the Ellington Weather One Weather Broadcast Receiver - 1-Piece helpful to you?
 Report Abuse  (6)  (0)  0 comments
May 8 2008
Tool-using Mom
Baltimore, Md
I am:
  • Casual/ Recreational
Reviewed at:
Price: $9.95
[5 of 5 customers found this review helpful]
Poor Quality
1.0
    Pros
  • Compact
    Cons
  • Does not receive
    Best Uses
  • None
"Does not receive ANY of 7 NOAA weather stations from anywhere in my house or on the property. Totally useless. "
 Report Abuse  (5)  (0)  0 comments
May 16 2008
weather enthusiast
Atlanta
I am:
Reviewed at:
Price: $9.95
Good for the price
4.0
    Pros
  • Easy to use
  • Lightweight
    Cons
    Best Uses
  • Daily Use
  • Hurricane kit
"This is a good basic weather radio - popped in a battery and it worked just fine. A couple of things to note: this is a very inexpensive radio with a small speaker - don't expect high fidelity, but that's OK; it does the job. Before buying, check your local NOAA Weater Radio broadcast frequency (u …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Aug 22 2009
WaterBoy G
Long Island, New York
I am:
  • Practical
Reviewed at:
Price: $9.95
Works great!
5.0
    Pros
  • Durable
  • Good Sound Quality
  • Great Reception
  • Lightweight
    Cons
  • None
    Best Uses
  • Commuting
  • Travel
"Although I read mixed reviews about this product, it is working great for me. My old car had weather reception as part of the radio,so I wanted this for my new car as well, as I listen to it frequently. Very practical. "
Apr 15 2009
Sierra Trading Post devotee
COlumbus, OH
I am:
  • Practical
Reviewed at:
Price: $9.95
[1 of 1 customers found this review helpful]
weather radio
3.0
    Pros
    Cons
    Best Uses
  • Travel
"I have one which I bought about 8yrs ago. same model but is much better quality/material. this newer one feel/looks like it was made much cheaper, as if it would break easier. "
 Report Abuse  (1)  (0)  0 comments
Jun 10 2009
joe the hunter
san antonio, tx
I am:
  • Frequent Traveler
Reviewed at:
Price: $9.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
