Electro-Voice EV FORCEISUBE 18 In Subwoofer/Neutrick Output *
5.0
based on 1 review
from
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
Pros
  • Great sound quality (2)
  • Attractive design (1)
  • Easy to connect (1)
  • Powerful (1)
See less See more
Cons
  • Size (1)
Best Uses
  • Basic systems (1)
  • Home theater (1)
  • Smaller rooms / apartments (1)
Provided by PSSL.com - ProSound and Stage Lighting
EV FORCEISUBE 18 IN SUBWOOFER/NEUTRICK OUTPUTThe Force i Sub makes it easy and cost-effective to add solid, low-end response to any sound system. Thanks to its very solid enclosure and a powerful, cast frame 18-inch woofer, the Force i Sub can add substantial bass response to many two-way full-range speakers.An important feature of the Force i Sub is that it is designed to be paralleled with the Force i two-way full-range speaker system on a single amplifier channel. The Force i sound system combining the Force i two-way, Force i Sub and Eliminator i power amplifier rivals larger and much more expensive biamped sound systems for overall sound quality and output capability.The Force i Sub's powerful 18-inch woofer has a four-layer voice coil and nearly two inches of total excursion capability for tremendous air moving capability with reliability. Force i Sub's woofer was designed to have less midrange response so that its input filter reduces the mids and highs to allow parallel operation with a full-range system. Force i Sub's RoadWoodTM enclosure is much stronger and lighter than particleboard or MDF and has excellent acoustical properties too.The Force i Sub has a built-in metal stand mount and comes with a removable 34-inch steel pole to elevate EV two-way systems. It also comes with rear-mounted casters and a 3- stage, luggage-style expandable metal handle to make moving easy. The handle can also be removed to prevent rattles during use or to prevent damage in transportation. The enclosure is finished in black industrial-grade carpeting that is extremely durable.Features:18-inch cast frame driver with 350 watts continuous, 700 watts program and 1,400 watts peak power handlingBuilt-in input filter for single-amp drive capability - Biamping not requiredComes with 34-inch pole for elevating two-way systemsComes with wheels and removable, expandable handle for easy transportRoadWoodTM enclosure is strong and light?69 lb (31.3 kg)Same height (25.5 in) as Force i Two-Way for more efficient vehicle packingPerfectly matched to Eliminator i power amplifier with processorConnectors: 1/4 phone jack/Speakon NL4Size: 25.55" x 20.4" x 23.7"Weight: 69 lbs
Electro-Voice EV FORCEISUBE 18 In Subwoofer/Neutrick Output * Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: EV FORCEISUBE 18 In Subwoofer/Neutrick Output *
See all eBay results
  at eBay.com
Product Reviews
Last update: Sep 19, 2009
Electro-Voice EV FORCEISUBE 18 In Subwoofer/Neutrick Output * Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Great sub for the money
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • Size
    Best Uses
  • Basic Systems
  • Home Theater
  • Smaller Rooms
"This is a great little sub. The sub is right in the power range where it is usable on many different amplifiers on the market. But the sound quality you get on this sub is amazing. I bought this to replace a twin 18 sub from Peavey. I needed something that was lighter and easier to transport. This s …"  Read Full Review »
Was this Speaker & Subwoofer review on the Electro-Voice EV FORCEISUBE 18 In Subwoofer/Neutrick Output * helpful to you?
Sep 19 2009
Rockstar
WI
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
