Electro-Voice EV FORCE-I-25 Dual 15-In/600W 2-Way Loudspeaker +
#811
4.4
based on 7 reviews
Ratings Distribution
5 star
3
4 star
4
3 star
0
2 star
0
1 star
0
Category Average
4.4
$429.99 - $529.99
from 2 stores
More Images
Pros
  • Great sound quality (10)
  • Powerful (5)
  • Attractive design (3)
  • Easy to connect (3)
  • Easy to use (1)
  • Great highs (1)
  • Powerful bass (1)
  • Professional functions (1)
  • Versatile (1)
  • Wheels on bottom (1)
See less See more
Cons
  • Heavy / bulky (3)
  • Not durable (2)
Best Uses
  • Large rooms (3)
  • Professional (3)
  • Amateurs (2)
  • Basic systems (2)
  • Smaller rooms / apartments (2)
  • Audiophiles (1)
  • Home theater (1)
  • Outdoors (1)
Provided by PSSL.com - ProSound and Stage Lighting
EV FORCE-I-25 DUAL 15-INCH/600W 2-WAY LOUDSPEAKERElectro-Voice knows what the dual 15-inch two-way customer wants - more BASS! Designed with the "Subwoofer Up" approach, the Force i25 reproduces tremendous low-end along with patented Electro-Voice high and mid-range clarity. Able to handle 600 watts continuous, 2400 watts peak, Force i25 is a complete system for the mobile DJ or band that needs extended low frequency drive, and outstanding portability. While competitors waste enclosure volume on trapezoidal designs (which were really intended for multiple speaker arrays), Force i25 utilizes an Anti-Trap approach gaining more enclosure volume and incredible bass. Built-in wheels and a handle on top provide comfortable ergonomics for rolling the Force i25 from the van to the gig. Listen to the difference and you'll be blown away. 48.1kg (106lbs)Utilizing a two elementshaded array, the upper woofer covers bass and midswhile the lower woofer combines to drive the huge bassport with room-shaking efficiency. EV's Ring ModeDecoupling (RMD) technology assures that voices andinstruments will stay smooth and detailed regardlessof level. The DH3 one inch exit true compression driver has a pure titanium diaphragm for sparkling, crystal clear highs. Coupled with EV's proven 80? x 55? low distortion Constant Directivity? horn, your audience will hear more details more clearly throughout more of the room than with typical competitive 90? horns. The large single handle on the top of the enclosure makes it easy to tilt and roll the Force i25 on its built-in pocket wheels. For truly outstanding performance, power a pair of Electro-Voice Force i25's with an Electro-Voice CP2200 power amplifier or a Dynacord PowerMate? powered mixer.Features:Two-Element Shaded ArrayRMDTM - Ring-Mode Decoupling1-inch Exit Pure Titanium TrueCompression Driver80o x 55o true Constant-Directivity hornHigh Power Crossover NetworkBuilt-in Wheels for Easy TransportManufactured in the United StatesConnectors: (2) Speakon NL4Size: 45.98" x 17.92" x 20.25"Weight: 106 lbs
Electro-Voice EV FORCE-I-25 Dual 15-In/600W 2-Way Loudspeaker + Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 7, 2009
Electro-Voice EV FORCE-I-25 Dual 15-In/600W 2-Way Loudspeaker + Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Great Speaker
4.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
  • More »
    Cons
  • Heavy
    Best Uses
  • Basic Systems
  • Home Theater
  • Large rooms
  • Outdoors
  • Smaller Rooms
"I just bough me a pair of these bad boys and I love them. They sound great. Have crisp clean highs and mids all while thumping your chest with amazing bass. I am a mobile dj so the only downfall to these speakers is the size and wieght. They are slightly over 100 pounds so until I can afford a t …"  Read Full Review »
Was this Speaker & Subwoofer review on the Electro-Voice EV FORCE-I-25 Dual 15-In/600W 2-Way Loudspeaker + helpful to you?
Apr 14 2009
djdice19
Lincoln, NE
I am:
  • Musically Inclined
these babies rock!!
4.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • Heavy
    Best Uses
  • Basic Systems
"I've had my I-25's about 2 years. I use them 8 times a month. After about 5 months the twitter went out in one. Got it repaired and a few weeks later, the other one shut down. Found out that the EV's(I-25)has very low tolerance for feedback. The twitters are expensive to replace compared to other sp …"  Read Full Review »
Aug 7 2009
DJ CHARLES
ORLANDO FL.
I am:
  • Audiophile
  • Professional
Blew Away My Expectations!!!
5.0
    Pros
  • Huge Sound Output
    Cons
  • Heavy
    Best Uses
  • Audiophiles
  • Larger Rooms
  • Smaller Rooms
"I have been using this cabinet for DJing and Sound Reinforcement for a while, and I have to tell you that no cabinet I have used has been as amazing to work with as these. I’ve used these side-by-side with Carvin TRX-153B’s and Cerwin Vega PSX-253’s (both are 3-Way speakers), and the i25’s have out …"  Read Full Review »
Jul 6 2007
Sean
Chicago, IL
I am:
  • Professional
  • Tech Savvy
WOW these are loud
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Larger Rooms
"WOW, I got these in 2 days ago and I can only say that they are huge, loud, and have the best sound quality, I mean you can turn these up and they don't even flinch. I'm driving them with the new QSC GX 5 and it puts out 700 to 800 each side and i never put these pass 400 - 500 watts each side becau …"  Read Full Review »
Jul 10 2008
Dj Pauley
out side of PHILLY
I am:
  • Professional
I like this model a lot
4.0
    Pros
  • Clear Sound
  • Powerful
    Cons
  • Breaks Easily
    Best Uses
  • Professionals
"I've had the I-25's for about 9 months QSC plx3402 driving them, they take the abuse that my amp sends out, just about everything the amp has too 1100w @ 4ohms theese speakers were rated at 600w@4 ohms and i clip the hell out of the amp, ive replaced both drivers though, first one blew and second on …"  Read Full Review »
Apr 16 2007
Donny
Watertown, Connecticut
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
