Elan Home Systems THP1200SW Black 12-inch 300 watt Powered Subwoofer
#956
4.0
based on 8 reviews
Ratings Distribution
5 star
4
4 star
2
3 star
1
2 star
0
1 star
1
Category Average
4.4
$299.88 at OneCall
Find it at Amazon
Find it at Ebay
$299.88
from 1 store
Pros
  • Easy to connect (8)
  • Attractive design (7)
  • Great sound quality (6)
  • Powerful (6)
  • Powerful bass (1)
See less See more
Cons
  • Heavy / bulky (3)
  • Poor sound quality (2)
  • Lack of power (1)
Best Uses
  • Home theater (4)
  • Audiophiles (1)
  • Basic systems (1)
  • Large rooms (1)
  • Smaller rooms / apartments (1)
Provided by OneCall
Unparalleled Flexibility
A family of speakers so precisely timbre-matched that any combination of free-standing, in-wall, on-wall or ceiling speakers can be used to create the ideal Home Theater listening environment regardless of a room’s size, shape or aesthetics.
Laser-Guided Calibration
A precision laser pointer, included with each pivoting tweeter model, fits snugly into a notch built in to the tweeter’s housing, allowing meticulous calibration of high frequencies into your Home Theater’s “sweet spot” in only minutes.
Innovative, Patent-Pending Designs
Angled and rotating baffles; woven Kevlar woofers, midrange drivers and tweeters; footprints that take up minimal space yet deliver maximum sound – these are just some of the groundbreaking innovations that set TheaterPoint apart from the competition.
Exceptional Sound, Exceptional Value
Designed in-house by some of the finest acoustical engineers in the business and precision manufactured at ELAN’s own facilities, TheaterPoint brings you audiophile Home Theater sound at a price you can afford.
Radically Innovative Design.
Deeply committed to never taking shortcuts at the expense of performance, ELAN engineers went outside the box when designing the TheaterPoint line, coming up with new and exciting ways to
the apply principles of acoustic design to create in-wall and in-ceiling speakers with audiophile sound characteristics and imaging comparable to the finest cabinet speakers.
The Right Assortment.
Create the perfect home theater package every time with TheaterPoint by ELAN. Regardless of the room size, acoustics or aesthetics, our flexible, coherent designs and awesome family sound allow you to configure the ideal system for every Home Theater. Use all in-ceiling surround when space is at a premium, or select the in-wall surround with on-wall plasmas for ultimate aesthetics. Or, mix and match with free-standing models to fit the needs of larger Home Theaters. From 5.1 up to 7.1 Surround Sound, TheaterPoint has you covered. And, with pointable, laser-directed tweeters and meticulous family voicing, you're assured of the best possible performance, listening experience and value, from entry level up to exceptional.
Specification Description
Model THP1200SW
UPC 838029006846
Amplifier 300 Watts
Auto Power On/Off Yes
Crossover Frequency 50Hz-150Hz
Depth (Inches) 17
Frequency Response 22Hz-150Hz (variable)
Height (Inches) 15.75
Line In (1) LFE Input
Line Level (1) Rear Input
Line Level (1) Rear Output
Phase Switch 180 degrees
Speaker Level Inputs (1) 5-Way Binding Post
Speaker Level Outputs (1) 5-Way Binding Post
Weight (Pounds) 56.8
Width (Inches) 15.75
Woofer Size (Inches) 12
Elan Home Systems THP1200SW Black 12-inch 300 watt Powered Subwoofer Questions
Questions and Answers
Where to Buy
$299.88
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Oct 19, 2009
Elan Home Systems THP1200SW Black 12-inch 300 watt Powered Subwoofer Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
[0 of 1 customers found this review helpful]
Amazing Subwoofer
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • Heavy
    Best Uses
  • Basic Systems
  • Home Theater
"All I can say is that this was the best purchase so far. Amazing built quality, looks gorgeous and stands out as a very nice subwoofer.I am very happy I chose the Elan 12 inch and for [$] its unbeatable, and you wont find a better subwoofer at this price "
Was this Speaker & Subwoofer review on the Elan Home Systems THP1200SW Black 12-inch 300 watt Powered Subwoofer helpful to you?
 Report Abuse  (0)  (1)  0 comments
Mar 31 2009
Mokus
Cathedral City
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $299.88
For the rated frequency response.
3.0
    Pros
  • Easy To Connect
    Cons
  • Not Very Powerful
    Best Uses
  • Home Theater
"I use this sub-woofer for my home entertainment system. The sub was easy to connect, pretty fool proof there. For the rated frequency response the bass was kinda weak for a self powered sub-woofer. "
Aug 27 2009
Jimbo
Dover, NJ
I am:
  • Audiophile
  • Movie Enthusiast
  • Professional
  • Tech Savvy
Reviewed at:
Price: $299.88
[1 of 1 customers found this review helpful]
Beautiful sound and looks.
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • Heavy
    Best Uses
  • Home Theater
"Excellent sound only negative was the pointed 1-1/2" metal legs that screw into the bottom corners that will scratch your floor and create vibration "
 Report Abuse  (1)  (0)  0 comments
Mar 2 2009
Rich
Texas
I am:
  • Musically Inclined
  • Practical
  • Technically Challenged
Reviewed at:
Price: $299.88
unbelievable!!
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
  • Powerful Bass
    Cons
  • NONE
    Best Uses
  • Larger Rooms
"the sub intergrates well with speaker systems.very nice smooth way to blend with your listening movie experience.highly recommended!a true sleeper! "
Nov 21 2008
urbeenjammin
kenner,Louisiana
I am:
  • Tech Savvy
Reviewed at:
Price: $299.88
Just Horrible
1.0
    Pros
  • Attractive Design
  • Easy To Connect
    Cons
  • Distorted Sound
  • Poor Sound Quality
    Best Uses
  • None
"Just horrible, It has been replaced twice, does not sound very good when new, Has blown twice, very cheap woofer, don't waste your money "
Jun 12 2009
yep
Arkansas
I am:
  • Tech Savvy
Reviewed at:
Price: $299.88
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
