Eizo CG222W Widescreen LCD Monitor
#60
4.6
based on 9 reviews
Ratings Distribution
5 star
5
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$1,248.95 at B&H Photo Video
 Trusted:
$1,248.95 at Adorama
Find it at Amazon
$1,248.95 - $1,454.99
from 4 stores
More Images
Pros
  • Great picture quality (8)
  • Adjustable (5)
  • Vivid colors (5)
  • Easy setup (2)
  • Reliable (2)
  • Accurate colors (1)
  • Adjustable viewing angles (1)
  • Build quality (1)
  • Built-in calibrator (1)
  • Exceptional detail (1)
See less See more
Best Uses
  • Multimedia (2)
  • Photography (2)
  • Color correction photo (1)
  • Photoshop editing (1)
Provided by Super Warehouse
This wide gamut monitor is ideal for high-end graphics work such as pre-press and digital photography. It features 12-bit hardware calibration and uniform brightness across the screen.
  • Device Type: Flat panel display / TFT active matrix
  • Color: Black
  • Built-in Devices: USB hub
  • Dimensions (WxDxH): 17.3 in x 9.1 in x 20 in
  • Weight: 24.7 lbs
  • Diagonal Size: 22"- widescreen
  • Dot Pitch / Pixel Pitch: 0.282 mm
  • Max Resolution: 1680 x 1050
  • Display Positions Adjustments: Height- tilt
  • Color Support: 24-bit (16.7 million colors)
  • Image Aspect Ratio: 16:10
  • Response Time: 8 ms
  • Image Brightness: 200 cd/m2
  • Image Contrast Ratio: 800:1
  • Digital Video Standard: Digital Visual Interface (DVI)
  • Signal Input: 2xDVI-I- 1xVGA
  • Manufacturer Warranty: 5 years warranty
Specification Description
Model CG222W-BK, CG222WBK
UPC 690592021486
Select Flat Panel LCD
Viewable Size 22"
Eizo CG222W Widescreen LCD Monitor Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 13, 2009
Eizo CG222W Widescreen LCD Monitor Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Excellent monitor ... easy setup
5.0
    Pros
  • Adjustable
  • Easy Setup
  • Sharp Image
  • Simple calibration
  • Vivid Colors
    Cons
  • None
    Best Uses
  • Photo Editing
  • Soft Proofing
"I bought this monitor and added it to my 2007 iMac for photo editing and soft-proofing. The web reviews regarding Eizo are superb; unlike many options out there, this Eizo model is optimized for low brightness operation ... perfect for soft proofing.The monitor is absolutely the perfect size when pa …"  Read Full Review »
Was this LCD Monitor review on the Eizo CG222W Widescreen LCD Monitor helpful to you?
Nov 18 2009
TR
St. Louis, MO
I am:
  • Quality Oriented
Reviewed at:
Price: $1,248.95
[5 of 5 customers found this review helpful]
Good Color Stability
4.0
    Pros
  • Built-in Calibrator
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Color Correction Photo
"I use this as my color critical monitor for photo color correction. I have no complaints about anything so far. I especially like the built-in color correction software that is compatible with eye-one calibrators. The across screen color stability is also extremely useful when it comes to creating a …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Dec 30 2008
john
Brooklyn NY
I am:
  • Photographer
Reviewed at:
Price: $1,248.95
Amazing color out of the box.
5.0
    Pros
  • Adjustable
  • Easy Setup
  • Lightweight
  • Sharp Image
  • Vivid Colors
    Cons
  • None
    Best Uses
  • Photography
"As a graphic designer I have found this monitor to be the most color accurate I have experienced. It needed very little calibration, color was very close right out of the box. I used the Mac OS X monitor calibration software which seemed to be sufficient. Not having purchased the optional sensor I w …"  Read Full Review »
Oct 13 2009
Debra MMG
Ocala, FL
I am:
  • Quality Oriented
Reviewed at:
Price: $1,248.95
Outstanding!
5.0
    Pros
  • Adjustable
  • Build quality
  • Sharp Image
  • Vivid Colors
    Cons
  • None
    Best Uses
  • None
"After doing much research through the miriad of monitors available I decided this was the one for my needs.
I intend to use it primarily for digital photo viewing and editing and secondary for normal every day use .
Once I got through the set up and opened some of my digital photos, I was am …"  Read Full Review »
Feb 4 2009
David H
Virginia
I am:
  • Quality Oriented
Reviewed at:
Price: $1,248.95
[0 of 1 customers found this review helpful]
One great monitor
4.0
    Pros
  • Adjustable
  • Sharp Image
  • Vivid Colors
    Cons
  • None
    Best Uses
  • Multimedia
"I did not give 5 Stars because I am not a "pro" so I don't know what a more expensive monitor can do. I'll tell you that this monitor has made all the difference in the world when it comes to my workflow in photo/image work. The colors are great, set up is extremely quick and easy, calibration is …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Jan 28 2009
Allen
Littleton, Colorado
I am:
  • Quality Oriented
Reviewed at:
Price: $1,248.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
