Close Login Module
Join
Dynex 3-Port FireWire/IEEE 1394 PCI Card
#149
3.3
based on 13 reviews
Ratings Distribution
5 star
2
4 star
6
3 star
1
2 star
2
1 star
2
Category Average
3.9
$34.99
from 1 store
Where to Buy
$34.99
Product Reviews
Last update: Aug 6, 2009
Dynex 3-Port FireWire/IEEE 1394 PCI Card Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
Plug and Play in XP
"I did not have firewire ports on my Dell Desktop. It has a large hard drive and good processor that is built for media applications. My camcorder is firewire oriented - Canon Camcorder - thus I needed firewire ports for this computer. The directions / procedures where clear and illustrated with a graphic. The firewire port was easily pop into the appropriate place and secured with the screw to the rear portion ..." Read Full Review »
Mar 12, 2008 by rdfeducator
See more positive Dynex 3-Port FireWire/IEEE 1394 PCI Card reviews
2.0
Easy Install, Bad performance
"This card is very easy to install and seemed to work at first. While having my external 250 GB hard drive and M-Audio Firewire sound card attached to this card, the sound became distorted upon large data transfers. This card simply cannot handle the throughput / processing that it should. Sometimes the firewire devices would stop responding and the card would disappear from the installed device list. Replacing t..." Read Full Review »
Jun 12, 2008 by djblade
See more negative Dynex 3-Port FireWire/IEEE 1394 PCI Card reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
Plug and Play in XP
4.0
The directions / procedures where clear and illustrated with a g …"  Read Full Review »
Mar 12 2008
rdfeducator
Undisclosed
Reviewed at:
Price: $34.99
2.0
"This card is very easy to install and seemed to work at first. While having my external 250 GB hard drive and M-Audio Firewire sound card attached to this card, the sound became distorted upon large data transfers. This card simply cannot handle the throughput / processing that it should. Sometimes …"  Read Full Review »
Jun 12 2008
djblade
OC
Reviewed at:
Price: $34.99
Does not work with Visat
2.0
"Reasonable value for money and easy to install seemed to support the decision to add this to my PC to provide 1394/Firewire video input support. Installed without any drama and worked well to capture digital video from my camcorder. BUT..interferred with Visa to the extent that I could not either tu …"  Read Full Review »
Jun 27 2009
Austin, TX
Reviewed at:
Price: $34.99
Almost too easy
5.0
"I purchased one of these cards as a simple computer upgrade to take advantage of the dedicated bandwidth on each port so that my external hard drives could transfer more data faster. So far i couldn't be happier with the performance of this card. It does exactly what it says it should and was super …"  Read Full Review »
May 25 2008
412PCHOMichigan
Metro Detroit, Michigan
Reviewed at:
Price: $34.99
BAD PROBLEMS WITH VISTA
1.0
"The package says Vista compatible!!! It was a let down. Vista started up and recognized the new hardware and it installed and was ready to be used. But every firewire device i plugged into it... nothing would happened. It didn't recognize the external devices being used. I put the card on a system r …"  Read Full Review »
Feb 19 2009
bkmtj
Columbus, Georgia
Reviewed at:
Price: $34.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$34.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
