Dynex 2-Port USB 2.0 PCI Card
#131
3.4
based on 12 reviews
Ratings Distribution
5 star
5
4 star
2
3 star
1
2 star
1
1 star
3
Category Average
3.9
$24.99 at Best Buy
Find it at Amazon
Find it at Ebay
$24.99
from 1 store
Provided by Best Buy
You can never have too many USB 2.0 ports and with this simple-to-install PCI card, you can quickly and easily have 2 additional USB 2.0 ports.
Dynex 2-Port USB 2.0 PCI Card Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 2, 2009
Dynex 2-Port USB 2.0 PCI Card Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
Didn't get many problems
"I didn't have any USB 2.0 ports on my computer so I decided to buy one of these when I bought my capture card. After I bought it I read the packaging and it didn't say it was supported in XP so I started to worry. When I got home and installed it, I booted up my computer (w/XP SP2) and installed the driver. No problems at all, and worked right off the bat. I use it for my flash drive and capture card mostly, and..." Read Full Review »
Mar 29, 2008 by Dipfur
See more positive Dynex 2-Port USB 2.0 PCI Card reviews
1.0
Cheaper modle
"this unit does not hold up that good if you have to use for flash drive and plugomg camra transfere lead do not buy this modle if you want to just plug printer or scanner in and leave it pluged in it's ok. but like i said if you want 2.0 usb and you need pci card to add it buy a better model as you see the price is not much. had mine for just under two months and the one port is very loose and will not read anym..." Read Full Review »
Sep 09, 2007 by MuddoggerHD
See more negative Dynex 2-Port USB 2.0 PCI Card reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
4.0
"I didn't have any USB 2.0 ports on my computer so I decided to buy one of these when I bought my capture card. After I bought it I read the packaging and it didn't say it was supported in XP so I started to worry. When I got home and installed it, I booted up my computer (w/XP SP2) and installed the …"  Read Full Review »
Was this Computer Expansion Card review on the Dynex 2-Port USB 2.0 PCI Card helpful to you?
Mar 29 2008
Dipfur
VA
Reviewed at:
Price: $24.99
Cheaper modle
1.0
"this unit does not hold up that good if you have to use for flash drive and plugomg camra transfere lead do not buy this modle if you want to just plug printer or scanner in and leave it pluged in it's ok. but like i said if you want 2.0 usb and you need pci card to add it buy a better model as you …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Sep 9 2007
MuddoggerHD
Toledo, OH
Reviewed at:
Price: $24.99
xp beware - sp1 only
1.0
"if you are already on xp/service pack2, the system will not recognize the "unknown device" & the disc fails to load the 'driver provided'. maybe if you back out sp2 & go back to sp1(when the "dynex" company did not have a 'licensing issue' with microsoft) this might work, oh but then your operating …"  Read Full Review »
Feb 5 2008
finky
houston, tx
Reviewed at:
Price: $24.99
GREAT VALUE
5.0
"Despite the other two reviews I had read on this product, i had found it to be great! I'm normally not a big fan of dynex, but this thing really does the job. Now, i'm not the smartest man on in the world, but it took me all of 10 seconds to install on my computer, i use windows xp and my computer i …"  Read Full Review »
Jan 1 2008
CirusWeatherbe
so cali
Reviewed at:
Price: $24.99
card works, driver install a pain
3.0
"Installing the card was easy, the drivers were another mater. I'm running Windows 2000 on a machine that costs to much to uppgrade at this time, there is no internet connection and no printer connected, the installation hung up when it came to the window after the licensing agreement, it insisted th …"  Read Full Review »
Jan 2 2009
johninwr
washington
Reviewed at:
Price: $24.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
