Dual 4", 3-Way 100-Watt Indoor/Outdoor Loudspeakers (Model #LU43PW)
#990
3.9
based on 28 reviews
from $24.95 - $64.99
Ratings Distribution
5 star
14
4 star
6
3 star
3
2 star
2
1 star
3
Category Average
4.4
More Images
Pros
  • Great sound quality (20)
  • Easy to connect (19)
  • Attractive design (10)
  • Compact (8)
  • Powerful (7)
  • Cheap (1)
  • Decent sound quality (1)
See less See more
Cons
  • Not durable (4)
  • Lack of power (3)
  • Covers rust immediately (1)
  • Difficult to set up (1)
  • Heavy / bulky (1)
  • Mount bracket knobs rust (1)
  • Not intended for boats (1)
  • Not wterproof (1)
  • Poor sound quality (1)
  • Poorly made (1)
Best Uses
  • Basic systems (9)
  • Outdoors (4)
  • Audiophiles (2)
  • Boat (2)
  • Large rooms (2)
  • Smaller rooms / apartments (2)
  • Great for boating (1)
  • Home theater (1)
  • Outdoors only if protect (1)
  • Patio deck (1)
Provided by eAngler.com
Great for docks, patios and boats!
  • Features: Woofer: Polypropylene with rubber surround
  • Midrange: 25mm Polypropylene cone
  • Tweeter: 20mm Piezo dome
  • Nominal Impedance: 8 ohms
  • Aluminum Grille (Non Removable)
  • Rotating logo for versatile mounting options
  • Two 1/4-20 insert mounts on rear of each speaker
  • UV treated ABS enclosure
  • Includes multi-angle mounting brackets
    Throughout the past century, both Namsung and Dual have made monumental contributions to the innovation, evolution and distribution of consumer electronics from the introduction of stereophonic sound to the creation of the first remote controlled high fidelity cassette player, and beyond. With their combined resources of 100 years of brand recognition, they continue into the 21st century as leaders in unequalled technology, value and customer support.
  • Specification Description
    Model DULLU43PW, LU43PW
    UPC 827204209950
    Benefits Handles up to 100W power for strong performanceFrequencey response of 100Hz~20kHz gives you a broad range of soundWeather-re
    Capacity UOM mAh
    Connectivity technology Wired
    Country Of Origin China
    Description Header Great sound, whether you're in or out.
    Display Catalog Number 55035320
    Enclosure Color White
    End Product Indicator Yes
    Frequency response 100Hz~20kHz
    Grille color White
    Impedance 8 ohms
    Included in the Box LU43PW speakers (2)Mounting bracketsThumb screws
    Manufacturer Labor Warranty 12
    Manufacturer Part Number LU43PW
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Midrange size 1.5 inches
    Model LU43PW
    Mounting kit included Yes
    Operating Temperature UOM ° F
    Peak power 100 watts
    Product Depth 5.25
    Product Dimensions UOM inches
    Product Height 8.25
    Product Type Home speakers
    Product Weight 2.8
    Product Weight UOM pounds
    Product Width 5.25
    RMS (continuous) power 50 watts
    Sensitivity 85.5 dB
    Speaker type Outdoor
    Speakers included 2
    Supported Languages English
    Tweeter size 0.75 inches
    Tweeter type Polycarbonate
    Water resistant Yes
    Woofer size 4 inches
    Woofer type Polypropylene
    Dual 4", 3-Way 100-Watt Indoor/Outdoor Loudspeakers (Model #LU43PW) Questions
    Questions and Answers
    Where to Buy
    $51.88
    $29.99
    Code FALLSAVINGS33 : $5 Off Orders Over $50
    $24.95
    Shop CameraWorld with FREE Shipping/No Sales Tax! ends 12/31/99
    Show all 14 stores
    _
    Product Reviews
    Last update: Oct 7, 2009
    Dual 4", 3-Way 100-Watt Indoor/Outdoor Loudspeakers (Model #LU43PW) Reviews
    Most helpful positive review
    Most helpful negative review
    4.0
    good for the price
    "put them on my wake tower and they worked good the sound traveled far..." Read Full Review »
    Aug 13, 2008 by big scare
    See more positive Dual 4", 3-Way 100-Watt Indoor/Outdoor Loudspeakers (Model #LU43PW) reviews
    3.0
    Water "RESISTANT" NOT waterproof
    "It is kind of unfir that I have to give these a 3 star rating. It should actually be a 2 star. The reason being is I ordered these for my boat. This item is mis-represented because when I got them the box they came in from the manufacturer plainly says "Water Resistant" and when I looked at the manual it says "These speakers are water resistant and they are NOT waterproof". I can not remark on the actual perf..." Read Full Review »
    Dec 17, 2008 by Big Friendly Giant
    See more negative Dual 4", 3-Way 100-Watt Indoor/Outdoor Loudspeakers (Model #LU43PW) reviews
    Displaying 1 - 5 of 28 Reviews
    Show
    Sort by
    good for the price
    4.0
      Pros
    • Attractive Design
    • Compact
    • Easy To Connect
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Basic Systems
    "put them on my wake tower and they worked good the sound traveled far "
    my boat
    my boat
    • Picture of Product
    Was this Speaker & Subwoofer review on the Dual 4", 3-Way 100-Watt Indoor/Outdoor Loudspeakers (Model #LU43PW) helpful to you?
    Aug 13 2008
    big scare
    muscoy
    I am:
    • Musically Inclined
    [1 of 2 customers found this review helpful]
    Worth the price
    5.0
      Pros
    • Crisp Sound
    • Easy To Connect
      Cons
    • Large size
      Best Uses
    • Boat
    • Outdoors
    • Smaller Rooms
    "I have just 1 of these speakers installed on my 1546 Jon Boat. It is definitely loud enough and actually sounds really good [$] I was going to install both speakers, but they are an awkward size and after hearing just 1, I decided it was all I needed, so I have a spare if this one goes out. I have f …"  Read Full Review »
     Report Abuse  (1)  (1)  0 comments
    Jun 16 2009
    russ010
    Canton, GA
    I am:
    • Audiophile
    • Practical
    • Tech Savvy
    Reviewed at:
    3.0
      Pros
    • None
      Cons
    • Not wterproof
      Best Uses
    • Basic Systems
    • Larger Rooms
    • Smaller Rooms
    "It is kind of unfir that I have to give these a 3 star rating. It should actually be a 2 star. The reason being is I ordered these for my boat. This item is mis-represented because when I got them the box they came in from the manufacturer plainly says "Water Resistant" and when I looked at the ma …"  Read Full Review »
    Dec 17 2008
    Big Friendly Giant
    Detroit Michigan Burbs
    I am:
    • Tech Savvy
    [1 of 1 customers found this review helpful]
    Save Yourself a Headache
    1.0
      Pros
    • None
      Cons
      Best Uses
    • None
    "I bought these speakers at the boater's world store in Wilmington, NC. After one month and two times out on the water the screens on the speakers started rusting. I have now had the speakers on the boat for 3 months, and they are so rusted that they are leaving marks on my boat where they have dripp …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jun 13 2008
    Bryan
    Wilmington, NC
    Boat .Good Sound... Disappointed Quality
    3.0
      Pros
    • Compact
      Cons
    • Difficult To Set Up
    • Not Durable
      Best Uses
    • Basic Systems
    "On installation... the Mounting Nut fell inside the box as I was screwing onto the bracket.
    I Jury rigged another insert nut & the old one caused the speaker to rattle.
    I ended up drilling a hole in the speaker box with a circular hole drill to remove & reinstall the original nut.
    The speake …"  Read Full Review »
    Aug 6 2008
    Geno
    Boston, MA
    I am:
    • Tech Savvy
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
