Domke 1.5" Web Camera Strap with Swivel Quick Release
#2
4.7
based on 36 reviews
Ratings Distribution
5 star
27
4 star
8
3 star
0
2 star
0
1 star
1
Category Average
4.4
Low Price:
$19.99 at Adorama
 Trusted:
$22.00 at B&H Photo Video
Find it at Amazon
$19.99 - $22.00
from 2 stores
More Images
Pros
  • Comfortable (30)
  • Well built / quality construction (30)
  • Adjustable (29)
  • Does not chafe (24)
  • Well padded (7)
  • Looks great (2)
  • Adequately padded (1)
  • Does not slip (1)
  • Durable (1)
  • Low-key fashion (1)
See less See more
Cons
  • Poorly padded (3)
  • Grip may wear down (1)
  • No cushioning (1)
  • Rubber in strap deterates (1)
Best Uses
  • Supporting camera (22)
  • Stabilizing (19)
  • Comfortable (18)
  • Carrying camera (1)
  • Feature laden (1)
  • Not at all (1)
  • Photojournalism (1)
  • Sturdy for heave gear (1)
  • Travel (1)
Provided by B&H Photo Video
Whenever you have to carry your camera outside your bag these straps provide the same non-slip security as a Domke Shoulder Strap. They come with the hardware needed to attach to any SLR. QR models feature twist-proof quick release extensions. Swivel clips keep the straps lying flat untangled and easy to buckle/unbuckle. Adjustable length up to 42 (107cm). NOTE: This strap is 1.5 wide.
Specification Description
Model 742-6BK, 742-6NY, 7426BK, 7426NY
UPC 750062004019
For Cameras/Camcorders
Domke 1.5" Web Camera Strap with Swivel Quick Release Questions
Questions and Answers
Where to Buy
$22.00
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$19.99
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Nov 15, 2009
Domke 1.5" Web Camera Strap with Swivel Quick Release Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
5.0
Betcha can't take just one!
"Here's a new concept, products that actually work! I certainly didn't think this would make much difference on my camera & only got it because I hate the original Canon straps (40D w/ grip & 1D Mark III) & if Domke makes a version of what I'm looking for it's pretty much guaranteed that I'll go with them. So anyway the rubber strips on the underside of the strap are absolutely perfect & actually hold the camera ..." Read Full Review »
Dec 09, 2008 by Magik X Imaging
See more positive Domke 1.5" Web Camera Strap with Swivel Quick Release reviews
1.0
dropped camera today
"used these on my leicas for years but somehow my newest domke strap dropped my nikon d90 and 28-70 2.8 today. i was wearing my camera across my shoulder and had plenty of meat (extra strap above the buckle 4") but as i loaded my tripod in my car trunk i heard the strap slip (at buckle) and my camera crash to the ground.will never buy again[$]..." Read Full Review »
Aug 01, 2009 by george the boyscout
See more negative Domke 1.5" Web Camera Strap with Swivel Quick Release reviews
Displaying 1 - 5 of 36 Reviews
Show
Sort by
5.0
    Pros
  • Adjustable
  • American Made
  • Comfortable
  • Does not Chafe
  • Low-Key Fashion
  • More »
    Cons
  • None
    Best Uses
  • Supporting Camera
"Here's a new concept, products that actually work! I certainly didn't think this would make much difference on my camera & only got it because I hate the original Canon straps (40D w/ grip & 1D Mark III) & if Domke makes a version of what I'm looking for it's pretty much guaranteed that I'll go with …"  Read Full Review »
Was this Camera Strap review on the Domke 1.5" Web Camera Strap with Swivel Quick Release helpful to you?
 Report Abuse  (4)  (0)  0 comments
Dec 9 2008
Magik X Imaging
Pittsburgh, PA USA
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $22.00
[7 of 7 customers found this review helpful]
Excellent Strap, Great Quality, Great Functionality
5.0
"I use this strap with my Nikon D200 and 17-55. This strapis much better than the standard Nikon strap. The cloth issoft, not too thick but definitely not thin and cheap, andthe embedded rubber strips make sure the camera stays onyour shoulder or neck.The swivel clips are excellent as the strap doe …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Jan 8 2008
DK
NYC
Reviewed at:
Price: $22.00
Feels sturdy and looks good
4.0
    Pros
  • Adjustable
  • Strong Construction
    Cons
  • None
    Best Uses
  • Stabilizing
"This strap turned out to be everything I was hoping for EXCEPT for what it seems like a metal connector parts. Sturdy strap and looks good, I am glad I am not carrying around the camera manufactured advertisement strap. However this strap is connected by two metal connectors so I am putting caution …"  Read Full Review »
Nov 15 2009
Sam
Seattle
I am:
  • Photo Enthusiast
Reviewed at:
Price: $22.00
[2 of 2 customers found this review helpful]
The Best Bar None
5.0
    Pros
  • Adequately Padded
  • Adjustable
  • Comfortable
  • Does not Chafe
  • More »
    Cons
  • None
    Best Uses
  • Comfort
  • Feature Laden
  • Stabilizing
  • Supporting Camera
"The Domke strap is adequately comfortable with inlaid rubber linings to prevent slippage of camera from side to side and enhances the stability of the camera. There are 2 hooks that you can unfasten on both sides in case you have to use the tripod or mono pod in sports shooting or landscape photogra …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jan 16 2008
Tony G.
Quezon City, Philippines
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $22.00
Great camera strap
5.0
    Pros
  • Adjustable
  • Comfortable
  • Does not Chafe
  • Well Padded
    Cons
  • None
    Best Uses
  • Comfort
  • Stabilizing
  • Supporting Camera
"I got this strap to replace my Nikon strap on my D80. I wanted something with a QR so when I use my tripod I can take the strap off. This is a GREAT strap. Very well made, and the best part is the QR are made of metal, not easily breakable plastic. "
May 26 2008
taat2d
NYC
I am:
Reviewed at:
Price: $22.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
