DIRECTV HD DVR Satellite Receiver In Black
#31
3.5
based on 86 reviews
from $199.99
Ratings Distribution
5 star
31
4 star
24
3 star
8
2 star
7
1 star
16
Category Average
3.8
$199.99 at Best Buy
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Easy setup (25)
  • Easy to use (22)
  • Sleek design (20)
  • Large capacity / good size (18)
  • Reliable (15)
  • Easy to install (8)
  • Great picture quality (8)
  • Fast connection (7)
  • 90 mins of cache (1)
  • Abt price was great (1)
See less See more
Cons
  • Unreliable (4)
  • Difficult to set up (2)
  • Difficult to use (1)
  • Directv requirements (1)
  • Glichy begining (1)
  • Have to reset quite often (1)
  • Needed multiple resets (1)
  • No 2 stations (1)
  • No as good as old tivo de (1)
  • No easy check of 2 live t (1)
Best Uses
  • Home (32)
  • Television (19)
  • Movies (12)
  • Sports (5)
  • Office (3)
  • All (1)
Provided by Abt Electronics
DIRECTV HD DVR Satellite Receiver In Black - HR22/ Standard-Definition And High Definition Enabled/ Record Up To 500 Hrs Of SD Or 100 Hours Of HD (MPEG-4) Programming/ 2 Satellite Tuners/ Advanced Program Guide/ 480i 480p 720p 1080i Picture Output And Multiple Screen Formats Supported/ Replaced The HR21/ Black Finish
DIRECTV HD DVR Satellite Receiver In Black Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
DIRECTV HD DVR Satellite Receiver In Black Reviews
Most helpful positive review
Most helpful negative review
4.0
Necessary for DTV's MPEG4 HD broadcasts
"For the past 12 years I have set up my DTV receiver, dish and cabling myself without resorting to DTV's technicians. This HR21 receiver replaces a Hughes 10-250 which I have used for the past 4 years and which I was quite happy with but with DTV now putting out all HD channels in MPEG-4 format I had to change in order to receive them. Contrary to what DTV's technical support stated in several phone calls, I foun..." Read Full Review »
Apr 28, 2008 by methend
See more positive DIRECTV HD DVR Satellite Receiver In Black reviews
3.0
Two lemons in a row, one more on the way
"Writing this review is a bit of a dilemma for me. While the HR21-700 does enable HDTV and a stunning picture on my six-year-old Mitsubishi WS55909, it shouldn't be this painful.[...] What should have been up and running in under 1/2 hour including the call to DirecTV, took nearly four hours between waiting for customer support, being dropped, dialing back, waiting, getting dropped...On and on and only after havi..." Read Full Review »
Jan 31, 2008 by Up all night
See more negative DIRECTV HD DVR Satellite Receiver In Black reviews
Displaying 1 - 5 of 86 Reviews
Show
Sort by
3.0
    Pros
  • Easy To Set Up
    Cons
  • Unreliable
    Best Uses
  • Television
"Writing this review is a bit of a dilemma for me. While the HR21-700 does enable HDTV and a stunning picture on my six-year-old Mitsubishi WS55909, it shouldn't be this painful.[...] What should have been up and running in under 1/2 hour including the call to DirecTV, took nearly four hours between …"  Read Full Review »
Was this HDTV Tuner review on the DIRECTV HD DVR Satellite Receiver In Black helpful to you?
Jan 31 2008
Up all night
San Leandro, ca.
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • High Capacity
  • Reliable
  • Sleek Design
    Cons
  • None
    Best Uses
  • Home
"For the past 12 years I have set up my DTV receiver, dish and cabling myself without resorting to DTV's technicians. This HR21 receiver replaces a Hughes 10-250 which I have used for the past 4 years and which I was quite happy with but with DTV now putting out all HD channels in MPEG-4 format I had …"  Read Full Review »
Apr 28 2008
methend
Vero Beach, FL
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Tivo loyalist approved.
4.0
    Pros
  • Easy channel menu
  • Easy To Set Up
  • Easy To Use
  • Great quality picture
  • High Capacity
    Cons
  • Glichy begining
    Best Uses
  • Home
  • Television
"I was not happy with how my Tivo recorder performed with my HD DirecTV box. The Tivo could not record in High Definition and was starting to confuse me with addition and deleation of channels as the service packages changed. I really wanted a HD Tivo for DirecTV, but the companies no longer work tog …"  Read Full Review »
Feb 6 2008
Pasghettiandmeatbulbs
Chicago, IL.
I am:
  • Couch Potato
  • Gearhead
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Great product, a must have
5.0
"I have read most of the reviews that have been written about this fantastic technology!!! I have not had any issues with the product at all. If you investigate before you buy you would know that the $199 paid is a rental and not a purchase. You would also know that your contract is extended two addi …"  Read Full Review »
Oct 1 2009
ChiefMoose
Charlotte, NC
Reviewed at:
Price: $199.99
Works and Performs as Well as it Looks!
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • High Capacity
  • Reliable
  • Sleek Design
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Television
"I purchased the DIRECTV HR21 HD DVR Satellite Receiver In Black as a key part of a total change in my home entertainment system to HD technology. The decision to purchase was made at the end of a complete and very selective home restoration process. It is a wonderful, high performance, quality and a …"  Read Full Review »
Dec 19 2007
Roger the hard to convince guy
Chicago, IL
I am:
  • Practical
  • Professional
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
