Digital Spectrum Solutions MF-8104 Premium 10.4" Wireless Digital Frame
#68
4.1
based on 18 reviews
Ratings Distribution
5 star
9
4 star
5
3 star
1
2 star
2
1 star
1
Category Average
3.7
$175.47 - $369.00
from 8 stores
Pros
  • Clear image (8)
  • Attractive design (5)
  • Easy to use (5)
  • Quality construction (4)
  • Easy photo upload (3)
  • No photo service fees (1)
  • Stylish (1)
  • Wireless (1)
See less See more
Cons
  • Difficult to use (2)
  • Connection problems (1)
  • Max 255 wireless photos (1)
  • Wireless not working (1)
Best Uses
  • Digital photos (5)
  • Home decor (5)
  • Desk (3)
  • Gift (2)
  • Photography display (2)
  • Home (1)
Provided by Beach Audio
MODEL- U-40101 VENDOR- DIGITAL SPECTRUM
FEATURES- MF8104 MemoryFrame Wireless Digital Photo Frame
Bringing your digital lifestyle into view! The MemoryFrame Premium
family of wireless Digital Frames packs features and capabilities
not available elsewhere. The MemoryFrame can play images, MP3
audio, or MPEG-4 video. As a bonus audio can be played in the
background while a slideshow is playing, adding that extra
dimension of utility.
Sporting changeable frame capability, MemoryFrame can be decorated
to suit any decor. Coupled with contrast, brightness, and volume
controls, the MemoryFrame can be that perfect item in entryway,
living room, or den.
As for supplying content to the frame, choose any number of methods
including: Built-in Multi-format Card Reader
Generous 256MB of internal memory
USB Host and Device Ports (Camera, PC, Thumb Drive,
etc.)
Embedded 802.11 wireless
And because MemoryFrame is web enabled, you can enjoy all the
content sent to you by your family and friends though the internet
and Photo Sharing Sites.
Includes MemoryFrame system unit, Software Utility CD-ROM, USB Cable,
AC Power Adapter with cable, 8" x 10" Picture Frame, Remote Control,
User Manual and Warranty Card.
* Bright 10.4" Active Matrix TFT LCD Screen
* Plays Images, MP3 Audio, MPEG-4 Video, Audio Slideshow
* Built-in Multi-format Card Reader -- CF/SD/XD/MMC
* 256MB Internal Memory for local slideshow storage
* Built-in Stereo Speakers.
* Embedded 802.11 wireless
* Changeable Standard Frame to Match Your Decor
* Remote Control for content management
* No subscriptions, no PC required, easy to use
* Connect wirelessly to your home or corporate network
* Connect to the Internet for Photo Sharing
* Shares with Vista
* Shares with XP equipped with WMP 11
* Digital Pixmaster Software
For those that do use a PC, you can also create, name, save hundreds of
different slideshows for easy USB or wireless transfer to the
MemoryFrame.
Easily create professional looking slideshows. Choose the pictures,
choose the effects, transition and audio clip and let PixMaster do the
rest. With easy-to-use on-screen menu system and multifunction control
buttons, users can view thumbnails, select the time between transitions,
delete images from slideshows and much more. Manual image forward,
pause and reverse buttons and adjustable contrast are also provided.
-- SPECIFICATIONs -----------------------------------
SCREEN TYPE - Bright 10.4" TFT Active Matrix TFT LCD
INTERFACE - Camera: USB 2.0 Host interface
PC : USB 2.0 Target interface
WIRELESS - USB to 802.11b wireless dongle
MEMORY SIZE - 256MB Internal
FILE FORMAT - Photos: JPEG, TIFF, PNG, and BMP
Audio : MP3/WMA
Video : MPEG-4
RESOLUTION - 800 x 600 (larger pictures are automatically scaled to fit
the screen).
CONNECTORs - (1) Stereo Audio Out 3.5mm jack
POWER SOURCE - AC Adapter: 120 VAC, 60 Hz, 17w
DIMENSIONS - 10"w x 11.75"h x 2"d WT.- 62 oz.
www.digitalspectrum
Specification Description
Model MF-8104 PREMIUM, U-40101, U40101, U40101 –
UPC 893463001246
Built-In Devices Card Reader
Resolution 1024 x 768
Screen Size 10.4"
Select Size 10" Diagonal
Digital Spectrum Solutions MF-8104 Premium 10.4" Wireless Digital Frame Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 28, 2009
Digital Spectrum Solutions MF-8104 Premium 10.4" Wireless Digital Frame Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
[4 of 4 customers found this review helpful]
5.0
Very good
"I love this frame! Make sure all images are re-sized and adjusted before loading, as it seems to display the best images at the matched 800x600 resolution. Do not waste your time buying a frame with odd pixel dimensions as many seem to have. I learned that they will crop the image to fit it on the display. So, you end up with an image shown not the way it was captured. As an amateur photographer that takes pride..." Read Full Review »
Oct 03, 2007 by photoFred
See more positive Digital Spectrum Solutions MF-8104 Premium 10.4" Wireless Digital Frame reviews
2.0
Beware of expecting to much from the MF8
"If you were expecting the MF8140 to display all those thousands of photos you have on the server, beware that it is limited to 255. You will need to set up many smaller folders (of 255 or less) and have to manually reprogram the frame everytime you want to see a different set. I had expected to have it simply play all of my 5,000 photos contained on the server, but it's limited. They don't have any plans to inc..." Read Full Review »
Jul 02, 2007 by dave
See more negative Digital Spectrum Solutions MF-8104 Premium 10.4" Wireless Digital Frame reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
Very good
5.0
"I love this frame! Make sure all images are re-sized and adjusted before loading, as it seems to display the best images at the matched 800x600 resolution. Do not waste your time buying a frame with odd pixel dimensions as many seem to have. I learned that they will crop the image to fit it on the d …"  Read Full Review »
Was this Digital Picture Frame review on the Digital Spectrum Solutions MF-8104 Premium 10.4" Wireless Digital Frame helpful to you?
 Report Abuse  (7)  (0)  0 comments
Oct 3 2007
photoFred
Undisclosed
Reviewed at:
Best Wireless Frame for the Price
5.0
    Pros
  • Attractive Design
  • Clear Image
  • Easy Photo Upload
  • Easy To Use
  • More »
    Cons
  • None
    Best Uses
  • Desk
  • Gift
  • Home Decor
"We have now purchased two of these frames, one for each set of grandparents. They love them, and so does the whole rest of the family. We purchased the first for Christmas 07 and come Christmas 08 it was still the best value in a wireless frame. All the siblings have the email address to the frames …"  Read Full Review »
Feb 14 2009
Howard
Plymouth, Mi
I am:
  • Quality Oriented
Reviewed at:
[5 of 5 customers found this review helpful]
Quality Product
4.0
    Pros
  • Clear Image
  • Easy To Use
    Cons
  • None
    Best Uses
  • Desk
  • Digital Photos
  • Home Decor
"Product is easy to set up and contains many many features. Every possible method of getting photos to this frame is included. Showing pictures within 10 minutes. Bright Screen. Quality Product.
Only drawback is the product is quite expensive. "
 Report Abuse  (5)  (0)  0 comments
Jul 31 2008
Keith S. Photographer
Chicago, IL
I am:
  • Quality Oriented
Reviewed at:
2.0
    Pros
  • Stylish
    Cons
    Best Uses
  • Home
"If you were expecting the MF8140 to display all those thousands of photos you have on the server, beware that it is limited to 255. You will need to set up many smaller folders (of 255 or less) and have to manually reprogram the frame everytime you want to see a different set. I had expected to hav …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Jul 2 2007
dave
seattle
I am:
  • Professional
Reviewed at:
Price: $229.00
[1 of 2 customers found this review helpful]
Not as great as it appears
1.0
    Pros
  • Clear Image
  • Quality Construction
    Cons
  • Connection Problems
  • Hard To Use
    Best Uses
  • Digital Photos
"The frame at first appeared to have everything I wanted, good resolution, wireless capability, and large screen size. So it was a perfect anniversary gift for my wife. Unfortunately it became a nightmare and I had to return it.First of all both myself and my wife are pretty tecnically proficient. …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Aug 21 2008
Robert
Phoenix, AZ
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
