Diamond Multimedia TV Wonder HD 600 USB 2.0 TV Tuner (Model #TVW600USB)
#30
3.2
based on 16 reviews
Ratings Distribution
5 star
2
4 star
7
3 star
1
2 star
0
1 star
4
Category Average
3.8
Low Price:
$49.99 at Dell
 Trusted:
$78.95 at B&H Photo Video
$72.61 at pcRUSH
see all stores
$49.99 - $89.99
from 9 stores
More Images
Pros
  • Easy to install (2)
  • Easy to use (2)
  • Picture could be sharper (1)
  • Quality output (1)
  • Reliable (1)
See less See more
Cons
  • Unreliable performance (1)
Best Uses
  • Everyday (2)
Provided by Dell
The ATI TV Wonder HD 600 offers a feature rich set of media abilities, transforming your PC into the ultimate entertainment system. Attach an amplified high definition antenna or your TV cable and you can watch, pause or record analog and digital live HDTV on your PC or convert your recorded TV shows to take with you on your Portable Media Player. This hybrid PCI tuner will delight a home theater enthusiast looking for great value in a multimedia PC TV tuner.
Specification Description
Model TVW600USB
UPC 757448005929
Accessory Indicator Yes
Benefits Record over-the-air digital TV, HDTV and analog TVIncludes ATI Catalyst Media Center™ and AMD LIVE!™ CD featuring AMD LIVE!
Capacity UOM mAh
Connections A/V cable
Country Of Origin China
Description Header More TV for your PC.
Display Catalog Number 55031938
Enclosure Color Black/Silver
Included in the Box Diamond TV Wonder HD 600 USB 2.0Quick start guideInstallation CDRemote controlHDTV antennaA/V cab
Interface/form factor USB
Manufacturer Labor Warranty 12
Manufacturer Part Number TVW600USB
Manufacturer Parts Warranty 12
MAP Price 0.0
Model TVW600USB
Operating sytems supported Windows® XP or greater
Operating Temperature UOM ° F
Product Type TV tuner
Product Weight 2
Product Weight UOM ounces
Supported Languages English
System requirements Minimum Intel® 2.0 Celeron, Pentium, Duo, AMD® 3800+ or higher512MB of system memory, 1GB recommended for Vista®
Diamond Multimedia TV Wonder HD 600 USB 2.0 TV Tuner (Model #TVW600USB) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 14, 2009
Diamond Multimedia TV Wonder HD 600 USB 2.0 TV Tuner (Model #TVW600USB) Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
[4 of 5 customers found this review helpful]
5.0
ATI Wonderful
"Just installed the ATI TV Wonder HD 600 USB, on a Dell Inspiron with Vista Home Premium, completely in less than 1/2 hour & it works great! Great video & audio, in sync. However, the instructions are missing a key point or two. Luckily I spent some time reading reviews first. Shut down running programs and install the disk. While the disk is running, connect your cable to the outlet and the USB TV device th..." Read Full Review »
Sep 29, 2008 by JDHill
See more positive Diamond Multimedia TV Wonder HD 600 USB 2.0 TV Tuner (Model #TVW600USB) reviews
1.0
TV tuner problems
"The TV tuner USB drivers were difficult to install and required several long visits to the internet. When I got it set up it corrupted my sound card drivers to where even reloading the windows drivers was fruitless. I could receive the TV images but the speakers had to be turned off to eliminate a horrific screech. I had to format and reload all my software to clear up the problem...." Read Full Review »
Jul 08, 2008 by Wood Doc
See more negative Diamond Multimedia TV Wonder HD 600 USB 2.0 TV Tuner (Model #TVW600USB) reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
ATI Wonderful
5.0
"Just installed the ATI TV Wonder HD 600 USB, on a Dell Inspiron with Vista Home Premium, completely in less than 1/2 hour & it works great! Great video & audio, in sync. However, the instructions are missing a key point or two. Luckily I spent some time reading reviews first. Shut down running p …"  Read Full Review »
Was this HDTV Tuner review on the Diamond Multimedia TV Wonder HD 600 USB 2.0 TV Tuner (Model #TVW600USB) helpful to you?
 Report Abuse  (7)  (0)  0 comments
Sep 29 2008
JDHill
MI USA
Reviewed at:
Price: $84.99
[2 of 2 customers found this review helpful]
Just what I was looking for...XD
4.0
"First of all this product is great...as far as the software that came along ....I haven't tried it...I actually use (vitualdub) which is free and works great. I suggest that your machine is more than the system requirements because that will affect the video when being recorded to your computer. A …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Mar 10 2009
Max Macavilca
New Jersey
Reviewed at:
Price: $84.99
[0 of 2 customers found this review helpful]
What a horrible tuner and a waste of time!!
1.0
"This was an absolutely awful product!! Steer clear. I bought this TV tuner for its cable TV recording capabilities, and to archive old VHS tapes on DVD. This product is truly horrible, and is clear evidence that you get what you pay for. I am a "techie", and my career is in the tech business. Af …"  Read Full Review »
 Report Abuse  (0)  (2)  0 comments
Mar 22 2009
Michele Knight
Amazon
Reviewed at:
Price: $84.99
Just the right product
4.0
    Pros
  • Easy To Install
  • Easy To Use
  • Quality Output
    Cons
  • Unreliable Performance
    Best Uses
  • Everyday use
"TV Wonder 600 was easy to install. Could pick 20+ stationa with the simple antenna provided with the unit (not even fully extended).
I took back a point because the bundled SW is slow and at times slows my computer down and have to stop and restart the sofrtware. I will look for future releases o …"  Read Full Review »
Jun 24 2009
Erhan
Jersey City, NJ
I am:
  • Casual User
Reviewed at:
Price: $78.95
TV tuner problems
1.0
"The TV tuner USB drivers were difficult to install and required several long visits to the internet. When I got it set up it corrupted my sound card drivers to where even reloading the windows drivers was fruitless. I could receive the TV images but the speakers had to be turned off to eliminate a …"  Read Full Review »
 Report Abuse  (4)  (1)  0 comments
Jul 8 2008
Wood Doc
Alameda, CA
Reviewed at:
Price: $84.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
