Diamond Multimedia Stealth ATI Radeon 9250 PCI Display Card (S9250PCI256SB)
#494
3.6
based on 21 reviews
Ratings Distribution
5 star
8
4 star
6
3 star
2
2 star
1
1 star
4
Category Average
4.1
$63.34 - $71.14
from 16 stores
More Images
Pros
  • Quality output (1)
See less See more
Cons
  • Difficult to use (1)
  • Hard to install (1)
  • Poor output quality (1)
  • Unreliable performance (1)
Best Uses
  • Everyday (2)
  • Gaming (1)
Provided by CameraWorld.com
Highly evolved and extremely programmable, the Stealth 9250 opens a stunning new world of immersive play for gamers. Powered by high performance features including a Quad-pipe architecture, the Stealth 9250's visual processor delivers a dazzling visual experience optimized to support the most compelling next-generation 3D gaming environments of today and tomorrow.
Main Features
  • Manufacturer: Diamond Multimedia, Inc
  • Manufacturer Part Number: S9250PCI256SB
  • Manufacturer Website Address: www.diamondmm.com, www.diamondmm.com
  • Product Type: Graphics Card
  • Host Interface: PCI
  • Graphics Resolution: 2048 x 1536 Maximum
  • Processor: 1 x ATi Radeon 9250
  • Standard Memory: 256MB
  • Interfaces/Ports: 1 x 15-pin D-Sub VGA, 1 x DVI , 1 x S-Video TV-out
  • System Requirements:
  • Intel Pentium III, AMD Athlon, or higher CPU
  • 450 MHz or higher CPU
  • Super VGA or DVI-I compatible monitor
  • One available PCI slot
  • 64MB of system memory
  • Installation software requires CD-ROM drive
  • 90 MB available disk space
  • DVD playback requires DVD drive
  • Operating System Support:
  • Windows 98
  • Windows 98SE
  • Windows 2000
  • Windows ME
  • Windows XP
  • Specification Description
    Model S9250PCI256SB
    UPC 757448004915
    Accessory Indicator Yes
    Benefits 4 rendering pipelines for blazing 3-D gaming performanceSMARTSHADER™ supports Microsoft DirectX 9.0, enabling more complex and r
    Capacity UOM mAh
    Country Of Origin China
    Description Header Next level action!
    Display Catalog Number 55008275
    Features VIDEO IMMERSION™ provides support for digital and high-definition videoDVI and TV-out connections
    Manufacturer Labor Warranty 12
    Manufacturer Part Number S9250PCI256SB
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Model S9250PCI256SB
    Operating Temperature UOM ° F
    Product Type PCI cards
    Required to function Intel® Pentium® III, AMD® Athlon®, or higher CPU450MHz or higher CPUSuper VGA or DVI-I compatible monitor
    Supported Languages English
    Diamond Multimedia Stealth ATI Radeon 9250 PCI Display Card (S9250PCI256SB) Questions
    Questions and Answers
    Where to Buy
    $69.99
    $64.99
    $1.99 Shipping On Orders Over $100 at TigerDirect
    BizRate Rating Outstanding 9.1
    $63.34
    Show all 16 stores
    Product Reviews
    Last update: Sep 27, 2009
    Diamond Multimedia Stealth ATI Radeon 9250 PCI Display Card (S9250PCI256SB) Reviews
    Most helpful positive review
    [27 of 27 customers found this review helpful]
    Most helpful negative review
    5.0
    Great upgrade for my Dimension
    "Pros 1 Fast shipping 2 Very easy to install 3 Setup was fast and simple 4 Easy to use software 5 Great price Cons None at all. Additional Thoughts Dell Tech support helped me pick my new Graphics Card thank you I did not no about PCI and PCIE. The Stealth Radeon 9250 256 MB DDR PCI Cinematic 2D 3D Graphics Card was the perfect upgrade for my Dimension. I recently purchased a 22" monitor from Dell (Which is..." Read Full Review »
    May 16, 2007 by firstlook
    See more positive Diamond Multimedia Stealth ATI Radeon 9250 PCI Display Card (S9250PCI256SB) reviews
    1.0
    failed to install and poor customer serv
    "The product failed to install properly. contacted the service line by phone three times. Because it interfeard with my internet service. They said it was a faulty unit and suggested returning to Radioshack.com. They said I had to mail the product back and in 15 days I would get a credit. Then I could place my order again. Insted of just sending a replacement to swap out. I am looking for a diffent supplier and p..." Read Full Review »
    Jul 01, 2009 by Jeff B.
    See more negative Diamond Multimedia Stealth ATI Radeon 9250 PCI Display Card (S9250PCI256SB) reviews
    Displaying 1 - 5 of 21 Reviews
    Show
    Sort by
    5.0
    "Pros
    1 Fast shipping
    5 Great price
    Cons
    None at all.
    Additional Thoughts
    The Stealth Radeon 9250 256 MB DDR PCI Cinematic 2 …"  Read Full Review »
    Was this Sound & Video Card review on the Diamond Multimedia Stealth ATI Radeon 9250 PCI Display Card (S9250PCI256SB) helpful to you?
     Report Abuse  (27)  (0)  0 comments
    May 16 2007
    firstlook
    CA
    Reviewed at:
    Price: $69.99
    1.0
      Pros
    • None
      Cons
    • Difficult To Install
    • Difficult To Use
    • Poor Output Quality
    • Unreliable Performance
      Best Uses
    • Everyday use
    • Gaming
    "The product failed to install properly. contacted the service line by phone three times. Because it interfeard with my internet service. They said it was a faulty unit and suggested returning to Radioshack.com. They said I had to mail the product back and in 15 days I would get a credit. Then I coul …"  Read Full Review »
    Jul 1 2009
    Jeff B.
    Jack, Al.
    I am:
    • Casual User
    Reviewed at:
    Price: $69.99
    [6 of 8 customers found this review helpful]
    Efficient
    5.0
    "Pros
    Great tech support from Dell
    Quick delivery
    Easy to install
    Enabled computer to run more efficiently
    Cons
    I cannot think of any cons regarding this product.
    Additional Thoughts
    I appreciate the patience and knowledge of tech support. They are always willing to remain on the phone until the …"  Read Full Review »
     Report Abuse  (6)  (2)  0 comments
    Apr 29 2008
    TBaker
    Arizona
    Reviewed at:
    Price: $69.99
    [4 of 4 customers found this review helpful]
    Great video card
    5.0
    "Pros
    This is one great video card, even though an older PCI card it runs great and installed fast and easy on an XP Pro machine.
    Cons
    None
    Additional Thoughts
    It replaced the video card that came with the sytem and runs cooler. "
     Report Abuse  (4)  (0)  0 comments
    Jun 30 2008
    ATILover
    WI
    Reviewed at:
    Price: $69.99
    [5 of 5 customers found this review helpful]
    video card
    5.0
    "Pros
    great improvement on all of my graphics, gaming is so much better now, really easy to install and a great price.
    Cons
    nothing so far. "
     Report Abuse  (5)  (0)  0 comments
    Oct 28 2008
    mikemoo09
    Undisclosed
    Reviewed at:
    Price: $69.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
