Denon DJ DN-HS5500 Direct Drive Media Player/Controlr
4.3
based on 3 reviews
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.0
Pros
  • Attractive design (2)
  • Doesn't skip (2)
  • Clear sound (1)
  • Durable (1)
  • Easy setup (1)
  • Easy to use (1)
  • Great sound (1)
  • Powerful (1)
  • Professional functions (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Cd drive is additional (1)
  • Missing hdd sled (1)
Best Uses
  • Djs (1)
  • Events (1)
  • Large clubs (1)
  • Mobile (1)
  • Performances (1)
  • Professional recording (1)
Provided by PSSL.com - ProSound and Stage Lighting
Denon DN-HS5500 Direct Drive Media Player & Controller (Optional BB5501 CD Drive Sold Seperately) Features: • 2 Decks in 1 - One of the most riveting features of the DN-HS5500 is its independent Dual Deck-like operation with separate audio outputs. Deck 1 & Deck 2 can be operated simultaneously by a simple flip of a button, offering twice the power & creativity in a single deck. Each Deck layer has full access to all the available features as well as your connected devices & music library. Additionally, when used as a MIDI controller each Deck layer can fully control 2 players from your favorite DJ software such as, PCDJ/Reflex LE, Serato Scratch LIVE, Traktor...etc. • High Torque Direct Drive Motor & Spinning Platter Design - Denon’s proprietary 12-pole Direct Drive brushless motor design is keeping the art of the 110-year old turntable alive & true to its native feel, delivering instant full rotation speed with a powerful 2.5 kg/cm of start-up torque within 0.5 seconds for true turntable reaction and response. DJs can perform freely as if they were using a genuine analog turntable. Platter rotation can be changed from 33 to 45 R.P.M. for comfort. • Modular HDD - By this powerful and unique design, the DJ is now in full control over their internal hardware preference by choosing your own 2.5" laptop size *Hard Drive to store your Library as the secured "internal" source playback. The 2.5" HDD easily mounts to a removable caddy accessible from the front panel. • External USB Device Support (Sold Separately) - Got a portable music collection stored on external USB media? No problem…the DN-HS5500 can support multiple external USB mass storage class devices direct or via a USB 2.0 hub (sold separately). Connect your, iPod®, Jump Drive, and large USB Hard Drives for easy access to your small or extensive mp3/wav libraries. Simply plug these devices into the DN-HS5500 to obtain the powerful on-board features such as, Instant Start, Seamless Looping, Scratching and File Searching, just to name a few. Supported File Formats: MP3 & WAV • MIDI Interface Controller (PC/MAC) - The DN-S5500 is more than just player, it’s also designed to interface & control a variety of popular DJ programs that supports USB MIDI in/out interface, either by user custom mapping or direct native support by the software vendor. Control your favorite DJ software or your hard disk full of music all from one clever player. • USB Audio Internal 24-Bit Processing - Most DJ MIDI controllers on the market today don’t include an internal sound card. The DN-HS5500 encompasses its own USB Audio interface (sound card) which eliminates the hassle to source one and spend additional money. The internal power supply delivers optimum electrical specifications, resulting in best possible audio quality & performance, featuring industry leading Burr Brown (a product of TI) 24 bit DAC processing for superior output audio fidelity. USB Audio interface includes 2-Channel Stereo output pair, 44.1kHz sampling ranges and low latency ASIO / OSX Core Audio support • D-Sync - Two DN-HS5500 players can be linked together by a single RJ45 cross-cable for MASTER / REMOTE operation. This EASY operation enables the DJ to make all their peripheral connections to a single player while having full control of your music devices from either side. The REMOTE Player has i
Denon DJ DN-HS5500 Direct Drive Media Player/Controlr Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DN-HS5500 Direct Drive Media Player/Controlr
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 10, 2009
Denon DJ DN-HS5500 Direct Drive Media Player/Controlr Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Best Bang For The Buck, But has problem
4.0
    Pros
  • Attractive Design
  • Doesn't Skip
    Cons
  • None
    Best Uses
  • Large Clubs
  • Mobile
"DN-HS5500 is a dual channel CD player that, as of 5/25/08, cannot be beat by ANY other product on the market today. With that said, I have a love hate relationship with it and its developers and will tell you why to buy or stay clear.
PROS:
- Best bang for the buck
- It’s virtually two …"  Read Full Review »
Was this CD Player review on the Denon DJ DN-HS5500 Direct Drive Media Player/Controlr helpful to you?
 Report Abuse  (1)  (0)  0 comments
May 27 2008
DJ Smoove
Milwaukee, WI
I am:
  • Audiophile
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Awesome deck, with one issue.
4.0
    Pros
  • Clear Sound
  • Easy To Use
  • Powerful
  • Professional Functions
  • Versatile
    Cons
  • Missing HDD Sled
    Best Uses
  • Events
  • Performances
  • Professional Recording
"This is a great deck. It's easy to use as long as you are willing to give it a little time. The main thing you need to consider is that it doesn't come with the internal hard drive OR the sled to add your own so you have to use usb drives. The sled has still not been made available as of 3-19-08. Th …"  Read Full Review »
Mar 19 2008
RocKO
crack of the US, OK
I am:
  • Experienced
Reviewed at:
I LOVE IT!
5.0
    Pros
  • Attractive Design
  • Doesn't Skip
  • Durable
  • Easy Controls
  • Easy To Set Up
  • More »
    Cons
  • CD drive is additional
    Best Uses
  • DJs
"This is a great player, I love the midi functions. I think this player is better than the DN-S3700 since it has 2 players in one. 2 Built in sound cards. I use it with my virtual dj software. "
Jul 10 2009
DJ Boy Wonder
Los Angeles, CA
I am:
  • Professional
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
