Denon DJ AVR-4310CI 7.1-Channel Home Theater Receiver
#50
4.8
based on 6 reviews
Ratings Distribution
5 star
5
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.3
$1,998.95 - $1,999.98
from 5 stores
More Images
Pros
  • Clean sound (4)
  • Accurate controls (3)
  • Good power (3)
  • Durable (2)
  • Easy setup (2)
See less See more
Cons
  • Fm reception (1)
  • Remote controls (1)
  • Web ui (1)
Best Uses
  • Home theater (4)
  • Audiophiles (2)
  • Larger rooms (1)
Provided by OneCall
Discover a whole new world of multi-channel surround sound with Denon’s AVR-4310CI A/V receiver, which is among the first to include Dolby’s latest Pro Logic IIz decoder, which provides for front height channels to dramatically expand the front channels’ soundstage. The highest resolution audio decoders are provided, including Dolby TrueHD and DTS-HD Master Audio for the ultimate in audio fidelity. Audyssey's newest technology, Dynamic Surround Expansion, provides a more enveloping soundstage by deriving front height or front wide width channels for the most immersive surround sound experience. Analog and digital video sources are upconverted via Anchor Bay VRS processing to HD quality (up to 1080p/24/60), and the AVR-4310CI features no less than six HDMI inputs along with two parallel HDMI outputs. The Audyssey MultEQ XT room acoustic correction system features a supplied microphone that measures and corrects speaker/room response for up to eight measurement points, and the Dynamic Volume and Dynamic EQ systems provide rich, extended response at any volume level with no annoying volume jumps during commercials. With XM and Sirius satellite radio options, the AVR-4310CI also features built-in HD Radio for dramatically improved fidelity.
Specification Description
Model AVR-4310CI, AVR4310CI
UPC 883795001014
12V Trigger (2) Rear Output
AC Outlets (2) Switched
Analog Audio (2) Rear Output
Analog Audio (8) Rear Input
Analog Audio / Video (3) Rear Output
Analog Audio / Video (6) Rear Input
Channels 7.1
Coaxial Digital Input Yes
Color Black
Component Video (1) Rear Output
Component Video (3) Rear Input
Composite Video (4) Rear Output
Composite Video (6) Rear Input
Depth (Inches) 16.9
Dolby TrueHD Yes
DTS HD Yes
HD Radio Yes
HDMI (1) Rear Output
HDMI (5) Rear Input
HDMI Yes
Headphone Jack (1) Front Output
Height (Inches) 6.7
Multi-Channel 7.1 Channel Input
Multi-Channel 7.1 Channel Pre-Out
Multi-Room/Multi-Source Yes
Network Ready RJ45 Ethernet
Optical (1) Rear Output
Optical (2) Rear Input
Optical Digital Input Yes
Optical Digital Output Yes
Phono (1) Rear Input
Radio Frequencies AM FM and Sirius or XM Option
Remote Control Included
RJ45 Ethernet Rear Input
S-Video (3) Rear Output
S-Video (6) Rear Input
Satellite Radio Sirius Satellite Radio Ready
Stereo Power Rating (watts) 130
Surround Modes DTS 96/24
Surround Modes DTS ES Discrete 6.1
Surround Modes DTS ES Matrix 6.1
Surround Modes DTS NEO:6
Surround Modes Dolby Digital EX
Surround Modes Dolby Digital Plus
Surround Modes Dolby Pro Logic II
Surround Modes Dolby Pro Logic IIx
Surround Power Rating (watts) 130
Tuner AM
Tuner FM
Tuner HD
Tuner Sirius Satellite Radio Ready
Type of Receiver Home Theater Surround
Watts per channel 130
Weight (Pounds) 34.8
Width (Inches) 17.1
Denon DJ AVR-4310CI 7.1-Channel Home Theater Receiver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 14, 2009
Denon DJ AVR-4310CI 7.1-Channel Home Theater Receiver Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Awesome Denon AV Receiver
5.0
"I originally started out buying an open box/floor display Denon AVR 3808 and eventualy with the help of Mario (from Best Buy Tropicaire store Magnolia division) I bought a brand new AVR 4310.
At first I was a bid hesitant, but man oh man, Mario was correct. This is an awesome system, the sound, HD …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Denon DJ AVR-4310CI 7.1-Channel Home Theater Receiver helpful to you?
 Report Abuse  (1)  (0)  0 comments
Sep 7 2009
rraallpphh13
Fort Lauderdale, Fl
Reviewed at:
Price: $1,999.98
[0 of 1 customers found this review helpful]
BEST OF THE BEST
5.0
    Pros
  • Clean Sound
    Cons
  • None
    Best Uses
  • Home Theater
"I HAVE OWNED THE AVR-3808CI THE AVR-2807 THE AVR-4308CI AND THE AVR-2809CI AND THIS RECEIVER IS THE BEST OUT OF ALL OF THAM.YOU HEAR EVERY LITTLE DETAIL THAT IS POSSIBLE.IF ANYBODY IS LOOKING FOR A GREAT RECEIVER LOOK NO FURTHER THIS ONE IS THE BEST UNTILL THE AVR-4810CI COMES OUT. "
 Report Abuse  (0)  (1)  0 comments
Jul 30 2009
MAR
BALTIMORE,MD
I am:
  • Professional
Reviewed at:
Price: $1,999.00
[2 of 2 customers found this review helpful]
The Best Receiver I Have Owned
5.0
"Plain and simple this is an outstanding receiver. Coming from an older Onyko I was not sure if I would be able to hear any improvement in the audio. What an improvement!!! The sound is so much richer and clear. Both my wife and I have had trouble understanding the dialog in so many movies. But not a …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 9 2009
gkaz
Glendale, Az.
Reviewed at:
Price: $1,999.98
[1 of 5 customers found this review helpful]
Phenomenal receiver
5.0
Staff Expert  (what's this?)
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Home Theater
  • Larger Rooms
"This is a great receiver. It has gobs of power to spare. The GUI for setup is easy to read and not complicated at all. This receiver will decode both Dolby TrueHD and DTS-HD MA for blu-ray. I simply cannot find any flaws with this receiver. "
 Report Abuse  (1)  (4)  0 comments
Jul 30 2009
AO
NYC
I am:
  • Audiophile
  • Musically Inclined
  • Practical
  • Tech Savvy
Reviewed at:
Price: $1,999.00
Works for me
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Home Theater
"does everything I want and more "
Jul 25 2009
g
walnut creek, ca
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $1,999.00
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
