Denon DJ AVR-1709 7.1-channel Home Theater Receiver
3.5
based on 17 reviews
Ratings Distribution
5 star
3
4 star
7
3 star
3
2 star
3
1 star
1
Category Average
4.3
More Images
Pros
  • Great sound quality (10)
  • Accurate controls (7)
  • Good power output (7)
  • Durable (5)
  • Easy setup (2)
  • Thundering bass (1)
See less See more
Cons
  • Difficult to set up (6)
  • Limited functions (3)
  • 3 remote panels (1)
  • Must adj after change (1)
  • Requires constant adjust (1)
  • Shuts off with zone 2 (1)
Best Uses
  • Home theater (7)
  • Basic systems (5)
  • Large rooms (5)
  • Smaller rooms / apartments (3)
  • Living room (1)
  • Movies (1)
  • Sell (1)
  • Surround sound solution (1)
  • Television shows (1)
Provided by OneCall
Music around the home is now easier to realize than ever before. The AVR-1709 features a powerful seven channel amplifier section that can be easily configured for a 7.1 channel surround sound loudspeaker system, or to drive a 5.1 channel surround sound system in the main room, while at the same time able to drive a pair of stereo speakers in another room. Featuring tremendous video signal handling flexibility, the AVR-1709 features three latest specification v1.3a HDMI digital video inputs and one HDMI output that handles HD signals up to the highest 1080p resolution. As well, the AVR-1709 features on-board video up-conversion, along with three HD component video inputs for additional video signal handling flexibility. For optimum surround sound quality, the Audyssey MultEQ in-room acoustic measurement and optimization system measures the loudspeaker`s overall response (at up to six different measurement points) and tailors the audio signal for the smoothest, most natural-sounding tonal balance throughout the listening space. And, the AVR-1709 is one of the first to offer Audyssey`s Dynamic Volume leveling system, which eliminates jarring volume jumps between TV shows and commercials, as well as Audyssey Dynamic EQ to ensure rich bass and smooth tonal balance, even at low volume levels. Two remote controls are provided – one for the main room, and a second easy-to-use remote control for second zone audio control.
Specification Description
Model AVR-1709, AVR1709
UPC 883795000437
AC Outlets (2) Switched
Analog Audio (1) Front Input
Analog Audio (2) Rear Output
Analog Audio (9) Rear Input
Analog Audio / Video (1) Front Input
Analog Audio / Video (2) Rear Output
Analog Audio / Video (3) Rear Input
Channels 7.1
Color Black
Component Video (1) Rear Output
Component Video (3) Rear Input
Component Video Input Yes
Component Video Output Yes
D/A Converter 24-bit/96kHz
Depth (Inches) 14.9
HDMI (1) Rear Output
HDMI (3) Rear Input
HDMI Yes
HDMI Version 1.3
Height (Inches) 6.8
iPod Integration Yes
Multi-Room Rear Output
Multi-Room/Multi-Source Yes
Optical (2) Rear Input
Radio Frequencies AM FM and Sirius Option
Radio Station Programmable Memories (Presets) 40
Remote Control (2) Included
S-Video (2) Rear Output
S-Video (3) Rear Input
Satellite Radio Sirius Satellite Radio Ready
Speaker Switching Yes
Speaker Terminals Banana
Stereo Power Rating 80 Watts x 2
Subwoofer Preamplifier Rear Output
Surround Modes DTS 96/24
Surround Modes DTS ES Discrete 6.1
Surround Modes DTS ES Matrix 6.1
Surround Modes DTS NEO:6
Surround Modes Dolby Digital EX
Surround Modes Dolby Pro Logic IIx
Surround Power Rating 80 Watts x 7
Tuner AM
Tuner FM
Tuner Sirius Satellite Radio Ready
Type of Receiver Home Theater Surround
Watts per channel 80
Weight (Pounds) 24.9
Width (Inches) 17.1
Denon DJ AVR-1709 7.1-channel Home Theater Receiver Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: AVR-1709 7.1-channel Home Theater Receiver
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 28, 2009
Denon DJ AVR-1709 7.1-channel Home Theater Receiver Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
4.0
Receiver Has Latest Teschnology
"Has 4 HDMI inputs. A feature that automatically lowers the volume when annoying commercials come on. Very powerful and I have a second zone set up- 5.1 home theater in one zone and stereo reception in another zone. Denon makes quality products- my other Denon receiver is 8 years old. Denon makes extremely complicated products. The set up for the average person is nearly impossible without calling for help. ..." Read Full Review »
Dec 24, 2008 by DenonLvr
See more positive Denon DJ AVR-1709 7.1-channel Home Theater Receiver reviews
2.0
Eh
"I purchased this product on the recommendation of the salesperson and quickly realized that he was about 5 to 6 years behind the times. This particular model has no HDMI Audio capability which was essential to me. I returned the product for an Onkyo TRX 5607, which is much more conducive to my setup. If you plan to run audio and video from your TV to your receiver, don't purchase this model. Oh, and for the ..." Read Full Review »
May 28, 2009 by jumpman
See more negative Denon DJ AVR-1709 7.1-channel Home Theater Receiver reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Good Power
    Cons
  • Difficult To Set Up
    Best Uses
  • Home Theater
  • Larger Rooms
Denon mak …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Denon DJ AVR-1709 7.1-channel Home Theater Receiver helpful to you?
 Report Abuse  (3)  (0)  0 comments
Dec 24 2008
DenonLvr
New Jersey
I am:
  • Tech Savvy
Reviewed at:
I can't believe this is real!!!
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Good Power
    Cons
  • Limited Functions
    Best Uses
  • Home Theater
  • Smaller Rooms
"I used the AVR1709 to replace my Pioneer that I loved after only 4years due to a failure of the power supply and the blown center channel amplifier. I only had the Pioneer for about 4 years, so I was a little off guard for the cost. Since times are hard I opted for a more economical route to replace …"  Read Full Review »
Jul 13 2009
ChicagoBluesMan
Maywood, IL
I am:
  • Audiophile
  • Musically Inclined
  • Practical
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
Want Bang for Your Buck?
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • 3 Remote Panels
    Best Uses
  • Basic Systems
  • Home Theater
  • Larger Rooms
"A friend and I set up the system. We had some questions regarding setup, but they were easily answered in the manual. I particularly appreciated having a hard copy of the manual. Too many things bought today refer you to their website for a manual.
I liked the visibility of the power button on t …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
May 21 2009
Don
New City, NY
I am:
  • Critical
  • Practical
Reviewed at:
Good sound, Denon quality
4.0
    Pros
  • Accurate Controls
  • Clean Sound
    Cons
  • Limited Functions
    Best Uses
  • Home Theater
"Definitely lots of power and good sounds, Denon quality there.
On the other hand the upscaling functionality is total garbage!
HDMI will only do passthru so don't expect to have your component, s-video upscaled, it's only supposed to upscale it from component/s-video to component... somehow I …"  Read Full Review »
Oct 31 2008
samw5
US
I am:
  • Tech Savvy
Reviewed at:
Great Bargin
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Good Power
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"This replaced a sony receiver I loved for 13 years. I was missing out until I bought this new receiver. It is fantastic. I hate wires so I was a little bummed you cannot send sound through an HDMI cable. Perhaps this is normal. Everything sounds great and more features than I need which is great …"  Read Full Review »
Jul 28 2009
Scuba Guy
Albany,NY
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
