Denon DJ AVR-1609 7.1 Channels Home Theater Receiver
4.4
based on 17 reviews
from $229.99
Ratings Distribution
5 star
8
4 star
8
3 star
1
2 star
0
1 star
0
Category Average
4.3
$229.99 at Crutchfield
Find it at Amazon
Find it at Ebay
Pros
  • Great sound quality (10)
  • Accurate controls (6)
  • Good power output (6)
  • Easy setup (5)
  • Durable (3)
  • Interfaces well with tv (2)
  • Thundering bass (2)
  • Confusing / difficult controls (1)
  • Good value (1)
  • Looks great (1)
See less See more
Cons
  • Difficult to set up (4)
  • Hard to read titles (1)
  • Lack of power (1)
  • Limited functions (1)
  • Needed opt cable (1)
  • No dobly digital plus (1)
  • No dolby truehd (1)
  • No dts hd (1)
Best Uses
  • Home theater (8)
  • Basic systems (4)
  • Large rooms (4)
  • Smaller rooms / apartments (4)
  • Living room (2)
  • Movies (2)
  • Surround sound solution (2)
  • Music sounds good (1)
  • Television shows (1)
  • Tv broadcast sound great (1)
Provided by Abt Electronics
Denon Black AVR-1609 Home Theater Surround Sound Receiver - AVR1609/ 75 Watts Per Channel/ 7 Channels/ HDMI V1.3A Video Switching/ Dolby Digital Surround EX Dolby Pro Logic IIx DTS ES 6.1 DTS Neo:6 Decoding/ Audyssey MultEQ Dynamic Volume And Dynamic EQ/ Sirius Satellite Radio Ready/ Network And Digital Media Connectivity/ Black Finish
Specification Description
Model AVR-1609, AVR1609
UPC 883795000420
AC Outlets (2) Switched
Analog Audio (1) Front Input
Analog Audio (2) Rear Output
Analog Audio (8) Rear Input
Analog Audio / Video (1) Front Input
Analog Audio / Video (2) Rear Output
Analog Audio / Video (3) Rear Input
Channels 7.1
Color Black
Component Video (1) Rear Output
Component Video (2) Rear Input
D/A Converter 24-bit/96kHz
Depth (Inches) 14.9
HDMI (1) Rear Output
HDMI (2) Rear Input
HDMI Yes
HDMI Version 1.3
Height (Inches) 6.9
iPod Integration Yes
Optical (2) Rear Input
Radio Frequencies AM FM and Sirius Option
Radio Station Programmable Memories (Presets) 40
Remote Control Included
S-Video (2) Rear Output
S-Video (3) Rear Input
Satellite Radio Sirius Satellite Radio Ready
Speaker Switching A/B
Speaker Terminals Banana
Stereo Power Rating 75 Watts x 2
Subwoofer Preamplifier Rear Output
Surround Modes DTS 96/24
Surround Modes DTS ES Discrete 6.1
Surround Modes DTS ES Matrix 6.1
Surround Modes DTS NEO:6
Surround Modes Dolby Digital EX
Surround Modes Dolby Pro Logic IIx
Surround Power Rating 75 Watts x 7
Tuner AM
Tuner FM
Tuner Sirius Satellite Radio Ready
Type of Receiver Home Theater Surround
Watts per channel 75
Weight (Pounds) 24.9
Width (Inches) 17.1
Denon DJ AVR-1609 7.1 Channels Home Theater Receiver Questions
Questions and Answers
Where to Buy
$229.99
BizRate Rating Outstanding 9.4
Product Reviews
Last update: Jul 8, 2009
Denon DJ AVR-1609 7.1 Channels Home Theater Receiver Reviews
Most helpful positive review
Most helpful negative review
4.0
needs phono jack hooke-up for turntable
"Need more control over bass & treble for playing CDs, also needs less home theater features. Should have phono outlet for stereo turntable. Should not have to buy a preamp to push power for Denon receiver to play turntable. Phono should always be add to every receiver that Denon makes. Home Theater are Ok but it should not be the main selling point of the receiver. The bass & treble should be easier to locate on..." Read Full Review »
May 14, 2009 by vesh!
See more positive Denon DJ AVR-1609 7.1 Channels Home Theater Receiver reviews
3.0
Denon AVR-1609 & Bose speakers
"I have paired this Denon receiver with Bose single cubes from Lifetime Audio speakers and receiver has to be turned near top of volume to get reasonably loud volume. I'm a little disappointed in its power (or lack thereof). Maybe the cubes require allot of power??? Regards, Ron Porcoro..." Read Full Review »
Jun 16, 2009 by Ron
See more negative Denon DJ AVR-1609 7.1 Channels Home Theater Receiver reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
4.0
    Pros
  • Accurate Controls
  • Clean Sound
    Cons
  • Difficult To Set Up
  • Limited Functions
    Best Uses
  • Home Theater
Home Thea …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Denon DJ AVR-1609 7.1 Channels Home Theater Receiver helpful to you?
May 14 2009
vesh!
Los Angeles, California
I am:
  • Musically Inclined
  • Practical
Reviewed at:
Best value in the receiver market!
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Good Power
  • Good value
  • Looks Great
    Cons
  • No Dobly Digital Plus
  • No Dolby TrueHD
  • No DTS HD
    Best Uses
  • Basic Systems
  • Home Theater
  • Larger Rooms
  • Music sounds good
  • Smaller Rooms
  • More »
"- It can output 7.1 for regular TV broadcast (Dolby Prologic II)
- TV and Movies never sounded so clear
- It does not transfer audio from a HDMI cable.....annoying. Still a need for digital video and audio cable. To be fair through, for the cost it really isn't that much of a nuisance. "
Jun 6 2009
Brian
Washington, DC
I am:
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
AVR-1609... not the high end, but close
4.0
    Pros
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • Limited HDMI connections
    Best Uses
  • Basic Systems
  • Smaller Rooms
"The AVR-1609 only has video pass through for HDMI. So if you're looking for a single HDMI connection for Video and audio you'll need to move up the electronics food chain.
This model still has excellent sound and capabilities for digital audio fiber connection for both HDMI connections, so enjoy …"  Read Full Review »
May 4 2009
gabook
San Ramon, CA
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Solid performer for the price
4.0
    Pros
  • Clean Sound
  • Good Power
    Cons
  • Controls are confusing
    Best Uses
  • Basic Systems
  • Home Theater
"I purchased two AVR-1609 receivers: one for the master bedroom and one for the living room. Overall, they perform well in the relatively small (16X18 or so) rooms. Larger rooms will need more power, and the dynamic audio is a great concept but takes away from the theater experience. (Guess I shou …"  Read Full Review »
Jul 8 2009
They call me
Ridgecrest, CA
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Impressive sound, questionable video quality
4.0
"I was very pumped to get a new receiver for Christmas, and for the money this one seemed to have all the features that I needed, especially the multiroom feature. However, when I hooked up the cable to the receiver and tried to watch TV I noticed a very distinct loss of quality. I am not sure if the …"  Read Full Review »
Mar 5 2009
bshizzle
Sauk Rapids MN
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
