Denon DJ 980W 7.1-Ch. XM Satellite Radio/Network-Ready A/V Home Theater Receiver
#10
4.5
based on 40 reviews
from $1,296.77 - $1,999.00
Ratings Distribution
5 star
27
4 star
9
3 star
1
2 star
3
1 star
0
Category Average
4.3
Pros
  • Great sound quality (32)
  • Good power output (30)
  • Accurate controls (22)
  • Durable (15)
  • Easy setup (12)
  • 4 hdmi inputs (1)
  • Competitvely priced (1)
  • Denon is the best (1)
  • Does everything (1)
  • Firmware upgrades (1)
See less See more
Cons
  • Difficult to set up (12)
  • Confusing / bad remote control (3)
  • Browser ctrls need work (1)
  • Docs needs narratives (1)
  • Functionality with ipod (1)
  • Manuel hard to understand (1)
  • Mp3 interface needs work (1)
  • No audy eqvol (1)
  • Overly complex interface (1)
  • Poor instructions / manual (1)
Best Uses
  • Home theater (30)
  • Large rooms (22)
  • Audiophiles (16)
  • Smaller rooms / apartments (6)
  • Basic systems (4)
  • Budget audiophile categor (1)
  • Computer experts (1)
  • Flexible (1)
Provided by OneCall
7-Channel Equal Power
7-Channel Equal Power is a feature used in various Denon amplifiers to connect 7 speakers independently so that separate power amps connected via pre-outs are not required. It allows you to connect the second 'surround back' speaker to complement the surround back speaker for 6.1, straight off the main amplifier without adding a power amplifier to support 7.1 surround formats. Amplifiers with 7-Channel Equal Power have built-in separate internal amplifiers to power each channel independently, thus allowing you to enjoy the same high power output capability per channel, giving a balanced and truly high-impact surround-sound environment.
7-Channel Stereo
Denon's 7-Channel Stereo mode enables top quality normal two channel stereo output from the surround speakers to provide a unique 7 channel stereo option. This mode can be fully utilized from any high quality stereo source via CD, tape, FM-radio or video recorder for dynamic 7-channel output. The 7-channel stereo is available if you have a surround back right speaker connected as well as the surround back left speaker used in 6.1, otherwise you can still experience multi-channel stereo output using a 5-channel-stereo or 6-channel-stereo configuration.
8-Channel Input
These input jacks are for inputting multi-channel audio signals in high definition MUSE 3-1 format, multi-channel audio signals from an MPEG multi-channel decoder, SACD and DVD-Audio. The 8 channels are the Front left, Front right, Center, Surround left, Surround right, Surround Back Left, Surround Back Right and the Subwoofer. These connections are made by using 8 standard phono (RCA's) cables. The inputs are on the amplifier and by selecting 'Ext in' you can receive analog audio signals via a source such as a DVD player. Denon DVD players can be connected via the 6 phono cables to a Denon amplifier's 6-CH or 8-CH EXT inputs to allow for SACD or DVD-Audio transfer. This can also be used as an alternative to IEEE1394-output (Digital Audio) FireWire connection or the DENON LINK connection.
Advanced AL24 Processing
The acclaimed Advanced AL24 DSP processing improves the fidelity of high resolution stereo PCM sources such as CD and DVD (up to 192kHz sampling frequencies). Through sophisticated DSP processing algorithms, it improves low level detail and enhances fidelity by up-sampling and adaptive filtering techniques. Advanced AL24 also provides increased dynamic range and spatial information, bringing out all the nuances with optimum clarity and natural fidelity. For additional information, visit the Denon Tech Showcase.
Audyssey MultEQ XT
The Audyssey MultEQ XT provides advanced room correction and calibration technology. During the Auto Set-Up mode, MultEQ XT automatically determines how many loudspeakers are connected, whether they are connected in phase and whether they are satellites or subwoofers. After processing, it then analyzes and calibrates speaker level, size, and distance. MultEQ XT detects the proper crossover point and determines correct frequency response for up to eight listener positions simultaneously. Denon's implementation of MultEQ XT uses multiple Texas Instruments' Aureus DSP processors with high-end digital-to-analog converters. Both the Room EQ and Auto Set-Up features can be disabled if required. For additional information, visit the Denon Tech Showcase.
Cinema Equalizer
The sound from movie sources recorded in Dolby Digital, dts, or other formats emphasizes high-frequency range due to a theater`s front speakers being placed behind the movie screen. If this sound is reproduced in the home theater without correction, the high-frequency range can be too strong. Denon amplifiers feature a Cinema Equalizer to correct these high-frequency components so that the sound is clearer and easier to listen to.
Directional Correlation De-interlacing (DCDi)
DCDi is a specialized video processing developed by Faroudja that involves advanced algorithms to remove the jagged edges that appear when standard interlaced video is viewed on progressive scan displays. DCDi converts standard interlaced signals into progressive scan signals in order to eliminate the stair casing effect that conventional up-converters can introduce to diagonal edges.
Specification Description
Model AVR-4308CI, AVR4308CI
UPC 081757508087
12V Trigger (2) Rear Output
2:2 Pulldown Receiver Call-In Special
Analog Audio / Video (2) Rear Output
Analog Audio / Video (8) Rear Input
Coaxial (3) Rear Input
Color Black
Command / Control (1) DENON LINK
Component Video (3) Rear Input
Component Video (3) Rear Output
Composite Video (2) Rear Output
Composite Video (6) Rear Input
D/A Converter 24-bit/192kHz
Depth (Inches) 17.9
HD Radio Yes
HDMI (1) Rear Output
HDMI (4) Rear Input
HDMI Version 1.3
Height (Inches) 7.7
iPod Integration Yes
Monitor Output (1) Component video
Monitor Output (1) Composite Video
Monitor Output (1) HDMI
Monitor Output (1) S-Video
Multi-Channel (1) 7.1 Channel Input
Multi-Channel (1) 7.1 Channel Pre-Out
Multi-Room Rear Output
Network Ready RJ45 Ethernet
Network Ready Wi-Fi
Optical (2) Rear Output
Optical (3) Rear Input
Remote Control Illuminated, preprogrammed/learning LCD
RJ45 Ethernet (1) Rear Input
RS-232C (1) Rear In/Out
S-Video (2) Rear Output
S-Video (6) Rear Input
Satellite Radio XM Radio Ready
Speaker Terminals 5-Way Binding Post
Stereo Power Rating 140 Watts x 2
Surround Modes DTS ES Discrete 6.1
Surround Modes DTS ES Matrix 6.1
Surround Modes DTS NEO:6
Surround Modes DTS-HD
Surround Modes Dolby Digital
Surround Modes Dolby Digital EX
Surround Modes Dolby TrueHD
Surround Power Rating 140 Watts x 7
Tuner AM
Tuner FM
Tuner HD
Tuner XM Radio Ready
USB Port (1) Rear Input
Video Conversion to HDMI
Weight (Pounds) 40.8
Width (Inches) 17.1
Denon DJ 980W 7.1-Ch. XM Satellite Radio/Network-Ready A/V Home Theater Receiver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 10, 2009
Denon DJ 980W 7.1-Ch. XM Satellite Radio/Network-Ready A/V Home Theater Receiver Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[1 of 2 customers found this review helpful]
4.0
Not perfect but it has options then most
"I choose this AVR due to its extensive list of options and the fine Denon name. If I were to do it again I would look more into Yamaha now that I know the weaknesses. Don't get me wrong, it's a nice piece of equipment. The user interface is difficult to use and the manual is useless. Its just not laid out in a simple easy to understand way. It's strong points is it does allow for almost limitless changes. It can..." Read Full Review »
Oct 13, 2008 by Derk
See more positive Denon DJ 980W 7.1-Ch. XM Satellite Radio/Network-Ready A/V Home Theater Receiver reviews
3.0
Great Amp - Difficult to use
"I love the sound and the features. However, the interface is so complex, that many people will be overwhelmed trying to set it up and use it. I am a computer engineer, and have been stumped for hours trying to figure out why certain features “suddenly” stop working. Tip – do NOT accidently hit the center of the “soft” buttons on the main remote. That button switches the amp into “direct” mode, which disabl..." Read Full Review »
Aug 31, 2008 by jbthuis
See more negative Denon DJ 980W 7.1-Ch. XM Satellite Radio/Network-Ready A/V Home Theater Receiver reviews
Displaying 1 - 5 of 40 Reviews
Show
Sort by
One heck of a Reciever !!
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
  • Larger Rooms
"This Reciever is not for the novice but once you get it set up and get a good remote(Harmony One)you will be floored by all this reciever will and can do.The WiFi home networking works awesome,literally thousands of stations around the world at a push of a button.The amp section has incredible power …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Denon DJ 980W 7.1-Ch. XM Satellite Radio/Network-Ready A/V Home Theater Receiver helpful to you?
Nov 9 2009
bzizzi
Phila Pa
I am:
  • Tech Savvy
Reviewed at:
Price: $1,296.77
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Good Power
    Cons
  • Difficult To Set Up
    Best Uses
  • Audiophiles
  • Home Theater
  • Larger Rooms
"I choose this AVR due to its extensive list of options and the fine Denon name. If I were to do it again I would look more into Yamaha now that I know the weaknesses. Don't get me wrong, it's a nice piece of equipment. The user interface is difficult to use and the manual is useless. Its just not la …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Oct 13 2008
Derk
Los Angeles CA
I am:
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
Can't beat the price for its features
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Good Power
  • High end AVR
    Cons
  • No Audy EQvol
    Best Uses
  • Home Theater
  • Larger Rooms
"Unit is complicated because "Home Theater" audio has become very complex. This is why high end AVR's are difficult to setup for the typical user. However, once setup it's worth the effort. It has many features which allows you to customize the sound for your own environment. [...] "
 Report Abuse  (1)  (0)  0 comments
Nov 10 2009
Ben the audiophile
Torrance, CA.
I am:
  • Audiophile
  • Movie Enthusiast
  • Tech Savvy
  • Technically Challenged
Reviewed at:
Price: $1,999.00
Effortless installation
5.0
    Pros
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • Confusing Remotes
    Best Uses
  • Home Theater
"This unit is remarkable. I have it connected to a Roku; Denon 3930 dvd; Denon 2500 Blu-Ray; 67" Samsung DLP TV and a Time Warner Digital receiver box. It is driving seven Polk Audio speakers (2) LC80i (2) LC65i (2) LC265i and an LSiC for the front center. In addition I run two Polk Audio DSW400 Subs …"  Read Full Review »
Apr 27 2009
Spotcoolerman
Chapel Hill, NC
I am:
  • Practical
  • Tech Savvy
Reviewed at:
All my Home Theater Needed
4.0
    Pros
  • Clean Sound
  • Good Power
    Cons
    Best Uses
  • Home Theater
  • Larger Rooms
"The installation of the AVR-4308 went well but there were several issues I would like to address.
The Audyssey MultEQ XT automated room equalizer did not accurately set up distances and speakers for my room. This was corrected by manual speaker setup with a sound meter. Also it identified a rev …"  Read Full Review »
Jun 29 2009
P Daddy
San Diego, CA
I am:
  • Tech Savvy
Reviewed at:
Price: $1,296.77
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
