Delphi XM Radio Signal Repeater
#11
4.6
based on 5 reviews
from $53.82 - $170.00
Ratings Distribution
5 star
3
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.0
Low Price:
$53.82 at Meijer.com
 Trusted:
$169.00 at Rainbow Appliance
Find it at Amazon
More Images
Pros
  • Easy to install (2)
  • Easy to use (2)
  • Attractive design (1)
  • Clear display (1)
  • Durable (1)
  • Easy to configure (1)
  • Good value (1)
  • High quality (1)
  • Portable (1)
  • Quality construction (1)
See less See more
Best Uses
  • Home (2)
  • In the car (1)
  • Music (1)
  • News (1)
  • Portable devices (1)
  • Sports (1)
  • Talk shows (1)
  • Travel (1)
Provided by drugstore.com
Delphi XM Signal Repeater - Transmits XM satellite signal up to 75', even through walls!! Rebroadcasts XM signal to one or more repeater antennas which connect to your home kit or audio systems. Works with all Delphi and most other XM satellite radio receivers. The sleek design of the transmitter and antenna blends well with your other home stereo components. Additional features include: Rebroadcasts to one or more repeater antennas which connect to your home kit or audio systems; Works with all Delphi and most other XM satellite radio receivers through home kits/audio systems; This repeater package includes a transmitter, an antenna, and a power adapter; Transmits XM satellite signal up to 75 feet; item demensions are 2-3/4" W x 4" H x 1-3/4" D.
Specification Description
Model 689604159224, DELSA10116, SA1010116-11B1, SA101011611B1
UPC 689604159224
color null
CountryOrNoWool Malaysia
Product Details Delphi XM Signal Repeater - Transmits XM satellite signal up to 75', even through walls!! Rebroadcasts XM signal to one or more repeater antennas which connect to your home kit or audio systems. Works with all Delphi and most other XM satellite radio receivers. The sleek design of the transmitter and antenna blends well with your other home stereo components. Additional features include: Rebroadcasts to one or more repeater antennas which connect to your home kit or audio systems; Works with all Delphi and most other XM satellite radio receivers through home kits/audio systems; This repeater package includes a transmitter, an antenna, and a power adapter; Transmits XM satellite signal up to 75 feet; item demensions are 2-3/4" W x 4" H x 1-3/4" D.
size null
sku 147488
skuprice 58.9900
style SA101011611B1
taxable Y
Delphi XM Radio Signal Repeater Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 18, 2009
Delphi XM Radio Signal Repeater Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
Does the job
4.0
    Pros
  • Very easy to set up
    Cons
  • None
    Best Uses
  • None
"Easy to set up and works great. Agree with another review that it would benefit from a signal strenght indicator, but once set up with radio, no problem. I couldn't get a signal at first and then remembering that window glass may be an issue, I mounted the antenna between window and screen and get …"  Read Full Review »
Was this Satellite Radio System review on the Delphi XM Radio Signal Repeater helpful to you?
Mar 5 2008
John Boy
Boston
I am:
  • Value Oriented
Reviewed at:
Easy way to get more use with XM radios
5.0
    Pros
  • Easy To Install
  • Easy To Use
  • Quality Construction
    Cons
  • None
    Best Uses
  • Home
"This is very easy to set up and means you can use your XM Radio in your home without having to worry about using it in a room with a south facing widow or that sensitive ariel losing signal or being moved by tiny hands.
Works very well indeed. Very satisfied. "
Jan 13 2008
ktmpoahsay
Concord NC
I am:
  • Quality Oriented
Reviewed at:
Inexpensive, great solution!
4.0
    Pros
  • Easy To Configure
    Cons
  • None
    Best Uses
  • In The Car
  • In the Home
  • Portable Devices
  • Travel
"I needed this Signal Repeater Kit to improve my XM signal indoor at home. I did not want to mount an external antenna and run wiring. This product is a great solution and inexpensive too! "
Oct 30 2008
partsgirl68
Newland, NC
I am:
  • Enthusiast
Reviewed at:
This is a great product!
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"Easy to assemble and great sound. It met my expectations and more! I think it is a great product and would recommend it to anyone. "
Jun 19 2007
Mary the Lady Rider
Bethany, La.
Reviewed at:
Beats running a cable
5.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • Music
  • News
  • Sports
  • Talk Shows
"Works great and beats having to run cable "
Jan 18 2009
TooTall
Virginia Beach VA
I am:
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
