#8
based on 20 reviews
Ratings Distribution
| 5 star |
12 |
| 4 star |
4 |
| 3 star |
2 |
| 2 star |
1 |
| 1 star |
1 |
Category Average
$74.95 - $78.95
from 2 storesPros
Cons
Best Uses
Where to Buy
BizRate Rating
Outstanding 9.6
$74.95 |
No Tax Outside NY | |||
BizRate Rating
Outstanding 9.1
$78.95 |
at
Adorama
Product Reviews
[1 of 1 customers found this review helpful]
[2 of 3 customers found this review helpful]
"With this instrument I am absolutely confident that if anything is on the sensor, I will spot it. When you try it, you will see how clearly it works. How you clean the sensor of any fine particles is a subject for debate, but this scope will allow you to see if there is something on it. This scope can be used as a lighted magnifier for checking your lens surfaces or even locating a splinter in your finger if ne..." Read Full Review »
Apr 04, 2008 by Blind as a Bat
See more positive Delkin SensorScope, 5x Digital SLR Sensor Viewer with Case reviews
"That's about all this is. Keeping the light on means keeping the button pressed. Would be better with press-on, press-off switch. I found keeping the button pressed difficult (must be getting arthritis). Have to admit I saw this complaint in another review but thought it couldn't be that bad. Seeing into the corners of a full-size sensors requires looking in at a low angle so expect lots of distortion. On ..." Read Full Review »
Oct 06, 2008 by Dogface
See more negative Delkin SensorScope, 5x Digital SLR Sensor Viewer with Case reviews
Displaying 1 - 5 of 20 Reviews
Delkin SensorScope, 5x Digital SLR Sensor Viewer with Case Review
Pros
Cons
Best Uses
This sco
Read Full Review »
Pros
Cons
Best Uses
"I really like this product. I found it easy to use and it worked very well spotting dust on my sensor. What I don't like is that when I have to go clean dust of the sensor I have to remove the scope completely from the camera and then use the cleaning tool. I have seen similar products that do th …" Read Full Review »
Pros
Cons
Best Uses
"This product is what it is. It does a good job lighting and magnifying the sensor (or any small area). The only issue I have found is that you have to hold the power buttong to keep the light on. And it takes some pressure to keep it on. So a better design might be a toggle switch that allows yo …" Read Full Review »
"That's about all this is. Keeping the light on means keeping the button pressed. Would be better with press-on, press-off switch. I found keeping the button pressed difficult (must be getting arthritis). Have to admit I saw this complaint in another review but thought it couldn't be that bad. S …" Read Full Review »
Pros
Cons
Best Uses
"I do not have a lens for every camera so I have to change lenses. Dust gets in and I have to edit my photos afterwards. I used this Scope and I saw every partical and hair. I removed it and this scope shows every small detail. I definitely will advice all my students to buy one of these scopes. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.6
$74.95 |
BizRate Rating
Outstanding 9.1
$78.95 |
at
Adorama
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
