Definitive Technology SuperTower Floor Standing Speaker
#180
5.0
based on 4 reviews
from $1,499.00 - $1,499.95
Ratings Distribution
5 star
4
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$1,499.00 at OneCall
 Trusted:
$1,499.00 at Crutchfield
Find it at Amazon
More Images
Pros
  • Great sound quality (6)
  • Attractive design (3)
  • Easy to connect (3)
  • Powerful (3)
See less See more
Best Uses
  • Home theater (3)
  • Basic systems (1)
Provided by OneCall
For music and movie lovers who want audiophile-grade performance and drop- dead gorgeous looks from their loudspeakers, we offer the new Mythos STS.
The Mythos STS combines a high-definition mid/high frequency monitor section with an integrated SuperCube(R) powered subwoofer for no-compromise sonic performance. With the Mythos STS there is no longer a need to find room for and run wires to a separate subwoofer to get the full visceral impact from your favorite music and movies. The STS can do it all.
Exquisite Styling and Build Quality
Like the rest of the award-winning Mythos Series, the STS boasts slim, space-efficient, modern design that perfectly complements today`s sleek video monitors. In order to make the Mythos STS an aesthetic enhancement for any room, we spared no expense or effort on design, fit and finish details. The extruded Aluminum enclosure is anodized (both silver and black finishes are offered) and hand-polished to a pearlescent sheen. The base is solid granite for both greater stability and a richer more elegant look. All of the Mythos STS styling emanates from a parabolic form, grounded as much in technical appropriateness as visual beauty. With emphasis on a narrow, deep column, the parabolic theme is repeated in the lines of the cap and granite base. There is an unabashed acknowledgement of classic “American Streamline" principles in the STS, communicating motion, direction and clean utility. Your decorator will be jealous.
State of the Art Definitive Technology
Each Mythos STS contains a D`Appolito array consisting of two high-definition 4-1/2 drivers surrounding a 1 dome tweeter housed in an acoustically isolated sealed enclosure. The drivers feature Definitive`s patent-pending Balanced Dual Surround System (BDSS) technology that supports the speaker cone at both the inner and outer edges for longer, more linear excursion, greater clarity and finely textured inner detail. The tweeter is a pure aluminum dome, which has been heat-treated to relax the crystal structure and then coated with a ceramic to produce extended highs that reveal nuance and shimmer without a trace of edginess. The slim, curved shape of the enclosure reduces diffraction contributing to the STS`s remarkable imaging that is truly startling in its ability to float utterly lifelike highly defined sonic images across a broad and deep soundstage.
The subwoofer is built around a 5 x 10 racetrack-shaped polymer/carbon composite cone driver powered by a built-in 300-Watt digital amplifier and pressure-coupled to two 5 x 10 racetrack-shaped planar low-bass radiators for a total bass radiating area greater than a 12 woofer. A pair of STSs is like having two 12, 300-Watt powered subwoofers in your room without taking up all the floor space. The result is bass that is deep, powerful and impactful while at the same time having the kind of tight, controlled and accurate response of the finest and costliest audiophile speakers.
Specification Description
Model MYTHOSSTS, MYTHOSSTSBLA, Mythos STS, Mytohs STS
UPC 093207052682
Color Black
Depth (Inches) 8.5
Frequency Response 16Hz-30Hz
Height (Inches) 46
Impedance 8 ohms
Midrange Size (Inches) 5.25
Sensitivity 93dB
Speaker Terminals 5-Way Binding Post
Speaker Type Floor Standing
Subwoofer 300 Watts
Subwoofer 5x10
Tweeter Size (Inches) 1
Weight (Pounds) 61
Width (Inches) 5.5
Definitive Technology SuperTower Floor Standing Speaker Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 2, 2009
Definitive Technology SuperTower Floor Standing Speaker Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Best pair of speakers I've ever heard
5.0
"So I haven't purchased these yet but have auditioned these speakers numerous times over the past few days. For all you people who enjoy listening to rock or other music with a stong beat, def tech is the way to go. When watching action movies, you are in the heart of all the action. With these indiv …"  Read Full Review »
Was this Speaker & Subwoofer review on the Definitive Technology SuperTower Floor Standing Speaker helpful to you?
Mar 16 2009
Barback
Milwaukee, WI
Reviewed at:
[1 of 1 customers found this review helpful]
Outstanding speakers.
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Home Theater
"I am thrilled by these speakers.They have a full,crisp sound which is theater quality and tight bass.I also bought the mthos 3 for center and 4 mythos gems for my 7.1 system.
Meagan at Abt's was very helpful as always with this purchase.I am so happy with these speaker's.
Thanks Abt's. "
 Report Abuse  (1)  (0)  0 comments
Mar 25 2009
Bobby
San Francisco
I am:
  • Audiophile
Reviewed at:
Price: $1,499.00
[0 of 1 customers found this review helpful]
Excellent Speakers!
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
"I use them in a 16x18 Theater Room and they work perfect! The built-in power sub sounds great, never thought they would work as well as they do. "
 Report Abuse  (0)  (1)  0 comments
Jun 2 2009
Rob
San Antonio, TX
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Price: $1,499.00
Incredible Sound Quality
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Home Theater
"ABT is the Best. [...] "
Feb 13 2009
Kevin
Idaho
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $1,499.00
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
