Definitive Technology ProCinema 800 System Black 5.1-Channel Home Theater Speaker System
#49
4.7
based on 7 reviews
from $1,199.00
Ratings Distribution
5 star
5
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.4
Pros
  • Great sound quality (11)
  • Attractive design (7)
  • Easy to connect (7)
  • Powerful (4)
  • Compact (2)
  • Powerful bass (1)
See less See more
Cons
  • Heavy / bulky (1)
Best Uses
  • Basic systems (3)
  • Home theater (3)
  • Smaller rooms / apartments (3)
  • Audiophiles (1)
  • Large rooms (1)
Provided by OneCall
ProMonitor Loudspeakers satisfy your need for small, easy-to-place systems with speakers that deliver the true state-of-the-art, no-compromise performance you want.
ProMonitors are full-range speakers. Use them by themselves in a host of applications (including as stand-alone bookshelf, stand- or wall-mounted speakers). Pair them with matching powered subwoofers and center channels to build music and movie systems of astonishing performance capability: ultra-smooth high-definition clarity and musical linearity combine with superb transient response, tremendous dynamic range, rich warmth and precise room-filling three-dimensional imaging.
Definitive's C/L/R and Center Channel Speakers Complete Your Ultimate Home Theater
All Definitive center channels and C/L/Rs are designed with the same rigid standards and high performance goals as our main left and right front speakers. They include state-of-the-art features like high-definition polymer coned cast-basket bass/midrange drivers with butyl rubber surrounds, wide dispersion pure aluminum dome tweeters with magnetic fluid cooling, complex Linkwitz-Riley crossover networks, solid non-resonant monocoque cabinets with diffractionless grill/baffle interfaces and effective magnetic shielding incorporating both metal shield and dual field canceling magnets. All center channels and C/L/Rs have been voiced (timbre-matched) with the same sonic signature as all of Definitive's front main speakers. They will also, because of their true full-range quality and linear response, often provide better performance and do a better job matching other companies' main speakers than their own. of course, as you move up in the Definitive line, the overall performance improves, especially in the areas of dynamic range, extended linear response, fullness and clarity.
Definitive's ProSub Subwoofers - The Ultimate in Bass Performance for Maximum Enjoyment from Your Music and Movies
Definitive Technology is pleased to present our amazing powered subwoofers, a 9-time Grand Prix award-winning range of active subwoofers with built-in high-power, high-current amplifiers and electronic crossovers which achieve a unique combination of delicate musicality and thunderous power, for the absolute ultimate in bass performance.
When you listen to any of Definitive Technology's award-winning powered subwoofers, you will discover true state-of-the-art bass performance, extending down well beyond the limits of audibility into the range of purely physical subsonic energy that shakes the body and stirs the soul. This has long been the most exciting, sought after and rarest of audio achievements, and now it is yours for the asking.
Definitive's ProSub 800 is an advanced state-of-the-art technology active subwoofer with built-in high-power, high-current amplifiers and sophisticated electronic cross-overs in combination with its 8" driver of the highest quality. In addition, precisely accurate equalization, combined with a complete array of controls and connections, allows it to be hooked up to any electronics, perfectly integrated with any speaker system, and tuned for optimum performance in any room. The sonic result is accurate, awe-inspiring, high-impact, high-reality bass performance with superior transient response, vanishingly low distortion, stupendous subsonic power and high output capabilities. It is truly a unique combination of delicate musicality and thunderous power for the ultimate in home theater sound effects as well as unsurpassed musical excellence.
Specification Description
UPC 093207060922
Color Black
Line Level LFE Input
Magnetic Shielding Yes
Speaker Terminals 5-Way Binding Post
Subwoofer 300 Watts
Definitive Technology ProCinema 800 System Black 5.1-Channel Home Theater Speaker System Questions
Questions and Answers
Where to Buy
$1,199.00
BizRate Rating Outstanding 9.1
$1,199.00
BizRate Rating Outstanding 9.4
$1,199.00
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Oct 6, 2009
Definitive Technology ProCinema 800 System Black 5.1-Channel Home Theater Speaker System Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Great little system!
4.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Basic Systems
  • Smaller Rooms
"They have an excellent transparent sound with a slight tendency towards the warmish side, but GREAT definition and imaging. I use them in a reasonably large room about 24 x12 but they are not lost in the room size. I suspect that in a smaller room they would be just fantastic. The only con I have …"  Read Full Review »
Was this Speaker & Subwoofer review on the Definitive Technology ProCinema 800 System Black 5.1-Channel Home Theater Speaker System helpful to you?
Apr 23 2009
OB Won
Downingtown PA
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $1,199.00
[1 of 1 customers found this review helpful]
Great System - Great Sound
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
"Great system that I wanted to buy a few years back, and I should have. Great big bass from a subwoofer that doesn't look like it can do it out of the box. Unfortunately, the first system had a bad subwoofer. Luckily, onecall sent a new one that came a few days later. Very happy with this system, an …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
May 11 2009
jabdigital
floral park, ny
I am:
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Price: $1,199.00
[1 of 4 customers found this review helpful]
Theaters, beware of new competion
5.0
    Pros
  • Attractive Design
  • Easy To Connect
    Cons
  • Heavy
    Best Uses
  • Basic Systems
  • Larger Rooms
"This plasma displays an awesome picture and kept up with all the movements in Speed Racer. Viewing of this blue-ray movie increased my appetite for more blue-ray and less trips to the theaters. Don't forget to plan on equal quality furniture to view this system. Make sure you have strong help to se …"  Read Full Review »
 Report Abuse  (1)  (3)  0 comments
Jan 16 2009
marco105
Wichita, KS
I am:
  • Practical
Reviewed at:
Price: $1,199.00
Best Bang for the Buck
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Home Theater
"This system is amazing. The sound is wonderful, replaced a Bose system, this system beats it hands down. The only regret is I did not have enough money to get their higher end products. "
Jan 26 2009
atlow8
Kansas City
I am:
  • Tech Savvy
Reviewed at:
Price: $1,199.00
[0 of 1 customers found this review helpful]
great sound , very impressed with system
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Powerful Bass
    Cons
  • None
    Best Uses
  • None
"nice system, easy hook up, and they sound great for a small speaker. "
 Report Abuse  (0)  (1)  0 comments
Dec 6 2008
sound guy
allentown, PA
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $1,199.00
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
