Davis & Sanford Davis & Sanford ProVista 7518 Tripod and Head, 75 Video Tripod With FM-18 Fluid Head. (Head Supports up to 18 lbs., Tripods 25 lbs., extends 28" - 64")
#339
4.3
based on 120 reviews
Ratings Distribution
5 star
73
4 star
27
3 star
9
2 star
8
1 star
3
Category Average
4.4
Low Price:
$189.95 at B&H Photo Video
 Trusted:
$189.95 at Adorama
Find it at Amazon
$189.95
from 2 stores
More Images
Pros
  • Good stability (49)
  • Smooth movement (36)
  • Good footing (33)
  • Locks in tight (30)
  • Unfolds quickly (29)
  • Easily adjusted (26)
  • Lightweight (26)
  • Rugged (24)
  • Folds small (13)
  • Good value (5)
See less See more
Cons
  • Heavy (32)
  • Difficult to adjust (13)
  • Weak construction (4)
  • Cumbersome (3)
  • Flimsy (2)
  • Jerky movement (2)
  • Adjusters prone to fail (1)
  • Bad smell (1)
  • Doesn't go very low (1)
  • Initially hard to move (1)
Best Uses
  • Special events (35)
  • Stabilization (30)
  • Home (19)
  • Sports (19)
  • Office (17)
  • Long exposures (14)
  • Travel (13)
  • Photography (10)
  • Reducing noise (iso reduction) (4)
  • Movies (3)
Provided by B&H Photo Video
The ProVista combined with the FM18 Fluid Video Head provides rigid support for those who need strength more than versatility in height options. It assembles to its working height very quickly thanks to a 75mm claw ball and twist locks which require just half a rotation.
Specification Description
Model PROVISTA7518B
UPC 049383056334
Maximum Capacity 10 To 19.9 Lbs
Maximum Height 60" to 72"
Select Aluminum
Davis & Sanford Davis & Sanford ProVista 7518 Tripod and Head, 75 Video Tripod With FM-18 Fluid Head. (Head Supports up to 18 lbs., Tripods 25 lbs., extends 28" - 64") Questions
Questions and Answers
Where to Buy
$189.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$189.95
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Nov 16, 2009
Davis & Sanford Davis & Sanford ProVista 7518 Tripod and Head, 75 Video Tripod With FM-18 Fluid Head. (Head Supports up to 18 lbs., Tripods 25 lbs., extends 28" - 64") Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
Great Tripod for the Money!
"I used this tripod for a wedding this past weekend and it worked out great. It is a little on the heavy side, but that is great in my book. It is not so heavy it cannot be carried, but my PD170 is rock solid on top! Head is very smooth and does excellent. I noticed a lot of reviewers complained about breaking the tighteners for the arms and that the tightener for the pan got in the way. If you will notice, ..." Read Full Review »
Jun 23, 2008 by Fish Hook Productions
See more positive Davis & Sanford Davis & Sanford ProVista 7518 Tripod and Head, 75 Video Tripod With FM-18 Fluid Head. (Head Supports up to 18 lbs., Tripods 25 lbs., extends 28" - 64") reviews
3.0
A great tripod - almost
"This product was purchased primarily for video work and was everything I had hoped it would be - except for one major flaw that really should be addressed by the manufacturer. The tripod itself is very sturdy, the fluid head is smooth, the leg locks positive, and the W3-Dolly that came as part of the BH package was a very useful addition. All in all, a great value. BUT...the tripod uses a plastic molding for ..." Read Full Review »
Jan 21, 2009 by Script Doctor
See more negative Davis & Sanford Davis & Sanford ProVista 7518 Tripod and Head, 75 Video Tripod With FM-18 Fluid Head. (Head Supports up to 18 lbs., Tripods 25 lbs., extends 28" - 64") reviews
Displaying 1 - 5 of 120 Reviews
Show
Sort by
5.0
    Pros
  • Easily Adjusted
  • Good Footing
  • Locks In Tight
  • Rugged
  • Smooth Movement
    Cons
  • None
    Best Uses
  • Sports
  • Weddings
I noticed a lot of reviewers complaine …"  Read Full Review »
Was this Tripod Leg review on the Davis & Sanford Davis & Sanford ProVista 7518 Tripod and Head, 75 Video Tripod With FM-18 Fluid Head. (Head Supports up to 18 lbs., Tripods 25 lbs., extends 28" - 64") helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jun 23 2008
Lexington, Ky
I am:
  • Semi-Professional
Reviewed at:
Price: $189.95
Excellent Choice for Canon XL-2
5.0
    Pros
  • Easily Adjusted
  • Good Footing
  • Lightweight
  • Locks In Tight
  • Rugged
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Independent Films
  • Office
  • Special Events
  • Sports
  • More »
"I use this tripod with my Canon XL-2 filming wedding videos, short films etc. The tripod gives tight, smooth pans and tilts and is very stable. The XL-2 is front heavy because the image stabilization is in the lens, which requires a strong tripod to not have jitter when panning/tilting. This is defi …"  Read Full Review »
Sep 9 2008
Dennis111
Arkansas
I am:
  • Professional
Reviewed at:
Price: $189.95
3.0
    Pros
  • Good Value
    Cons
  • None
    Best Uses
  • None
The tripod itself is very sturdy, the fluid head is smooth, the leg locks positive, and the W3-Dolly that came as part o …"  Read Full Review »
Jan 21 2009
Script Doctor
Kansas City, MO
Reviewed at:
Price: $189.95
I'm Impressed with this tripod
3.0
    Pros
  • Good Footing
  • Lightweight
  • Locks In Tight
  • Rugged
  • Smooth Movement
    Cons
  • Difficult To Adjust
    Best Uses
  • General stabilization
"After I recieved this Tripod I set it up and began to look at the it more closely. The first thing I noticed is that it has 3 section legs, which are sturdy and stable. It will get rather tall which is nice. It is much more robust than it appears in the pictures. The only issue is that it cannot get …"  Read Full Review »
Jun 4 2008
Staci
Tucson AZ
I am:
  • Semi-Professional
Reviewed at:
Price: $189.95
Just buy it.
5.0
    Pros
  • Folds Small
  • Good Stability
  • Lightweight
  • Unfolds Quickly
    Cons
  • None
    Best Uses
  • None
"So professional for being under $200. The dolly is great even though you cant get steady shots with it, but if your filming a wedding for instance and you need to move the camera 6 feet to the left, you can just slide it over and its good to go. "
Nov 16 2009
Denny K
Buffalo New York
Reviewed at:
Price: $189.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
