Davis & Sanford Davis & Sanford Davis & Sanford Magnum X3T - tripod
#58
3.6
based on 17 reviews
Ratings Distribution
5 star
10
4 star
1
3 star
0
2 star
2
1 star
4
Category Average
4.2
$99.99 at Dell
Find it at Amazon
Find it at Ebay
$99.99
from 1 store
More Images
Pros
  • Lightweight (3)
  • Easily adjusted (1)
  • Good footing (1)
  • Good stability (1)
  • Locks in tight (1)
  • Not good (1)
  • Smooth movement (1)
  • Unfolds quickly (1)
See less See more
Cons
  • Flimsy (2)
  • Unstable (2)
  • Weak construction (2)
  • Difficult to adjust (1)
  • Not durable (1)
  • Slips out of position (1)
Best Uses
  • Home (2)
  • Better not use it (1)
  • Photography (1)
  • Special events (1)
  • Stabilization (1)
  • Travel (1)
Provided by B&H Photo Video
The Davis & Sanford MagnumX3T is a 3-leg section tripod with 1 ¼ diameter legs and comes supplied with the FGX10 head which makes this kit ideal for video or telescope use. Designed as an all purpose tripod for photo digital or video these tripod legs have a maximum load-capacity rating of 9 lb and feature Easy Grip foam cushioned insulated legs a built-in bubble level in the legs and head and rubber/retractable spiked feet. The connected head is the FGX10 3 way fluid-effect head with built-in Stroboframe quick release and auto closure which provides easy mounting and dismounting of equipment and direct connection to many Stroboframe brackets.Delivered in Titanium anodized color scratch resistant finish.
Specification Description
Model MAGNUMX3T
UPC 049383246537
Maximum Capacity 10 To 19.9 Lbs
Maximum Height 60" to 72"
Select Aluminum
Davis & Sanford Davis & Sanford Davis & Sanford Magnum X3T - tripod Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 15, 2009
Davis & Sanford Davis & Sanford Davis & Sanford Magnum X3T - tripod Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
Excellent Build Quality, Sturdy, & Durable
"Pros The unit is constructed of very high-grade materials and is easy to set up and use. Stroboframe feature is definitely well designed and implemented on the unit. Although the unit is heavier than other similar tripods, it is far superior in workmanship and engineering. Additional Thoughts The cost-benefit ratio exceeds most all other similar products on the market...." Read Full Review »
Jan 06, 2007 by CDR2007
See more positive Davis & Sanford Davis & Sanford Davis & Sanford Magnum X3T - tripod reviews
2.0
Sturdy, but....
"We bought 2 of these tripods about 9 months ago. Here are a few issues we have experienced in our educational use environment.First, after a few uses several of the cap nuts came off. No problem, I figured they were loose from shipping and tightened them all. Well, here it is months later and the cap nuts are still coming loose. In fact, now one of the enclosed studs spins with the nut cap making it impossib..." Read Full Review »
Sep 10, 2007 by Skdupre
See more negative Davis & Sanford Davis & Sanford Davis & Sanford Magnum X3T - tripod reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
Sturdy, but....
2.0
"We bought 2 of these tripods about 9 months ago. Here are a few issues we have experienced in our educational use environment.First, after a few uses several of the cap nuts came off. No problem, I figured they were loose from shipping and tightened them all. Well, here it is months later and the …"  Read Full Review »
Was this Still Photography Tripod review on the Davis & Sanford Davis & Sanford Davis & Sanford Magnum X3T - tripod helpful to you?
 Report Abuse  (3)  (0)  0 comments
Sep 10 2007
Skdupre
Texas
Reviewed at:
Dont ever buy this product!
1.0
    Pros
  • None
    Cons
  • Weak Construction
    Best Uses
  • None
"I bought this magnum3xt tripod from J&R and after second time I use within a week the nut volts and the rubber start falling part, I called up the manufacture company in Long Island they fixed it but the volts are slips and it is very dangerous to use for expensive camera, Thank god my camera was no …"  Read Full Review »
Apr 14 2009
G Sherpa
NY
I am:
  • Pro Photographer
Reviewed at:
5.0
"Pros
Additional Thoughts
The …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Jan 6 2007
CDR2007
Fresno, CA
Reviewed at:
Price: $99.99
So-So
1.0
    Pros
  • Lightweight
    Cons
  • Flimsy
  • Slips Out Of Position
  • Unstable
    Best Uses
  • Home
"I bought this tripod as I am getting into novice photography. I use my camera mostly for car shows and car club events, and wanted to do some panoramic shots, and low level light night shots. After having it for a day or so, the head tilt stay loosened up, and the clamp broke. Not really happy, b …"  Read Full Review »
May 6 2008
Brendon
CT
I am:
  • Getting started
Very stable/sturdy tripod...
5.0
"Pros
Excellent value..
Cons
Not the lightest but if you want a stable one who cares?
Additional Thoughts
Decided to purchase this Magnum X3T over the Slik Pro 330 DX and Manfrotto 725B($40 more!) and the feature/quality of this DS Magnum X3T is far worth more. The best $79 tripod out there..it …"  Read Full Review »
Mar 22 2008
RandR
Las Vegas,NV
Reviewed at:
Price: $99.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
