Close Login Module
Join
Davis & Sanford Belt Mounted Compact Steady Stick for all mini-DV, Hi8, 8mm, & VHS Video Cameras with Standard Tripod Socket
3.9
based on 18 reviews
Ratings Distribution
5 star
4
4 star
11
3 star
1
2 star
1
1 star
1
Category Average
4.1
$69.95 - $74.90
from 2 stores
Pros
  • Lightweight (14)
  • Folds small (11)
  • Good stability (9)
  • Unfolds quickly (5)
  • Easy to use (4)
  • Improves performance (4)
  • Compact design (2)
  • High quality (2)
  • Highly compatible (2)
  • A bit bouncy when walking (1)
See less See more
Cons
  • Flimsy (4)
  • Unstable (2)
  • Lacks functionality (1)
  • Mover shaker (1)
  • No fluid head (1)
  • No safety belt (1)
  • Not shocked absorbent (1)
  • Poor design (1)
Best Uses
  • Stabilization (8)
  • Independent films (5)
  • Complex projects (2)
  • Home movies (2)
  • Long days of shooting (1)
  • Non-moving stabilization (1)
  • Studio (1)
  • Trashcan (1)
Where to Buy
BizRate Rating Outstanding 9.6
$69.95
No Tax Outside NY
BizRate Rating Outstanding 9.1
$74.90
Product Reviews
Last update: Oct 22, 2009
Davis & Sanford Belt Mounted Compact Steady Stick for all mini-DV, Hi8, 8mm, & VHS Video Cameras with Standard Tripod Socket Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Most Useful and Convenient!
"I am rating this with five stars, but with a quality caveat noted at the end of this discourse - in a word, this is the steady, easily portable platform I have been seeking for over three years! And in that period of time, it is the fifth device I have purchased, but the first steadying device that has worked unequivocally well for me. The price is only a fifth of the most expensive shoulder mounts or combina..." Read Full Review »
Jun 05, 2008 by Bill
See more positive Davis & Sanford Belt Mounted Compact Steady Stick for all mini-DV, Hi8, 8mm, & VHS Video Cameras with Standard Tripod Socket reviews
1.0
"Tilt A Whirl!"
"I purchased the product to be able to steady & perfect my shooting style. The easy adjustment on the velcro belt is the cat's meow. The adjusting screws on the device are under-equated.The pop in/out assembly results in a shaking affect.The bottom line is I felt like I had in my hands a camera support that felt like a tilt-n whirl saucer rendering my purchase useless & headed for the TRASH!!!!..." Read Full Review »
Dec 10, 2008 by Mr. Big Shot
See more negative Davis & Sanford Belt Mounted Compact Steady Stick for all mini-DV, Hi8, 8mm, & VHS Video Cameras with Standard Tripod Socket reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
my arms can rest
5.0
    Pros
  • Highly Compatible
  • Lightweight
    Cons
  • Lacks Functionality
    Best Uses
  • In The Studio
  • Independent Films
"once you understand its operation becomes a constant tool, and raises the point of view of your shots to another dimencion, is a very economical solution and it works very well, plus has good presence "
Oct 22 2009
nidepiedra
Iquique, Chile, Sud America
I am:
  • Independent Film Maker
  • Professional Artist
Reviewed at:
Price: $69.95
5.0
    Pros
  • Folds Small
  • Good Stability
  • Lightweight
    Cons
  • Weak Construction
    Best Uses
  • Stabilization
"I am rating this with five stars, but with a quality caveat noted at the end of this discourse - in a word, this is the steady, easily portable platform I have been seeking for over three years! And in that period of time, it is the fifth device I have purchased, but the first steadying device that …"  Read Full Review »
Jun 5 2008
Bill
Austin, Texas
I am:
  • Tech Savvy
Reviewed at:
Price: $69.95
[2 of 2 customers found this review helpful]
[$] is just one chiropractor appointment
4.0
    Pros
  • Folds Small
  • Good Stability
  • Lightweight
    Cons
  • None
    Best Uses
  • None
"While recently running a Z1U for a Travel Channel program I appreciated the light weight of a camcorder when compared to a full-sized ENG or Production camera. In the end though my back, shoulder and arm suffered from the weeks of run and gun shooting even worse than usual, because of the awkward b …"  Read Full Review »
Apr 16 2008
Epaka
Minneapolis
I am:
  • 10+ years in film/video
  • Film Professional
  • Tech Savvy
Reviewed at:
Price: $69.95
Needs little getting used to
4.0
    Pros
  • Folds Small
  • Good Stability
  • Lightweight
  • Sollid
  • Unfolds Quickly
    Cons
  • No Safety belt
    Best Uses
  • Stabilization
"Today I received the Steady Stick Compact. It’s much more solid than I expected. I thought it would be much more plastic, but it is made from very solid material. Great.
I made some testing shots in my garden and it feels good, but you do have to change your recording method a bit. I’m used to h …"  Read Full Review »
May 7 2008
Remco
Almere, The Netherlands
I am:
  • Aspiring Film Maker
  • Technically Challenged
Reviewed at:
Price: $69.95
Stick is great! Buckle is not.
4.0
    Pros
  • Easy To Use
  • Improves Performance
  • Professional Quality
    Cons
  • Poor Design
    Best Uses
  • Home Movies
  • Independent Films
"I bought this steady stick to use with my Canon XH-A1s. The quick release function is great and when in use, the steady stick produces a shot as steady as a tripod with the ability to move around, high and low. The only unfortunate thing is that the plastic buckle that holds the belt on broke afte …"  Read Full Review »
Jul 2 2009
Lip Media LLC
Eugene OR
I am:
Reviewed at:
Price: $69.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$69.95
No Tax Outside NY
$74.90
Out Of Stock
$89.95
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
