D-Link Xtreme N Wireless-N Desktop Card
#281
3.3
based on 57 reviews
Ratings Distribution
5 star
16
4 star
17
3 star
4
2 star
6
1 star
13
Category Average
3.9
$59.00 - $79.99
from 16 stores
More Images
Provided by Beach Audio
MODEL- DWA-552 VENDOR- D-LINK
FEATURES- Xtreme N Desktop Adapter
The D-Link Xtreme N Desktop Adapter (DWA-552) is a draft 802.11n
wireless client that delivers unrivaled wireless performance for
your desktop computer. This wireless adapter delivers up to 14x
faster speeds and 6x farther range than 802.11g while staying
backward compatible with 802.11g and 802.11b networks. Once
connected, you can share a high-speed Internet connection, photos,
files, music, videos, printers, and storage.
Includes Xtreme N Desktop Adapter, Quick Installation Guide, CD-ROM
(Installation Wizard, Drivers, Product Documentation).
* GET CONNECTED, STAY CONNECTED
The Xtreme N Desktop Adapter is powered by Xtreme N technology to
provide superior wireless reception in your home or office. This adapter
is designed for use in larger homes and offices, or for users running
multiple bandwidth-intensive applications. This adapter enables you to
simultaneously make or receive Internet phone calls (VoIP), surf the
Web, transfer files, and stream High-Definition (HD) media when
connected to an Xtreme N Gigabit Router (DIR-655). The DWA-552 supports
WEP, WPA, and WPA2 encryption that allow you to connect securely to a
wireless network.
* EASY TO SETUP, EASY TO USE
D-Link's Quick Adapter Setup Wizard guides you step-by-step through the
installation process. Configure this notebook adapter without having to
call a networking expert to help you. The D-Link Wireless Manager is
also included with this product to keep track of all your most
frequently accessed networks so that you can join them quickly and
easily.
With unmatched wireless performance, reception, and security, the D-Link
Xtreme N Desktop Adapter (DWA-552) is the best choice for easily adding
or upgrading wireless connectivity to your notebook computer.
* XTREME N ADAPTER BENEFITS
- Delivers up to 14x faster speeds and 6x farther range than 802.11g.
- Xtreme N technology enables HD video streaming, file sharing, enhanced
Internet phone calling (VoIP), and surfing the Web.
- Access secure wireless networks using advanced WEP, WPA, or WPA2
encryption.
- Easy to install and use with D-Link's Quick Adapter Setup Wizard.
- Backward compatible with existing 802.11g and 802.11b networks.
-- SPECIFICATIONs -----------------------------------
STANDARDS - IEEE 802.11n (draft), IEEE 802.11g, IEEE 802.11b
INTERFACE/BUS- 32-bit PCI
FREQUENCY - 2.4GHz to 2.4835GHz
SECURITY - Wi-Fi Protected Access (WPA, WPA2)
Wired Equivalent Privacy (WEP)
INDICATORS - LEDs for Link, Activity
REQUIREMENTS - Computer with: Windows XP SP2 or Windows 2000 SP4
CD-ROM Drive
20MB Hard Disk Space
32-bit PCI Slot
APPROVALS - FCC B, CE
DIMENSIONS - 3.8"w x 0.1"h x 4.7"d WT.- 0.2 lbs.
www.dlink.com
tech@irvine.dlink.com
Specification Description
Model DWA-552, DWA552
UPC 790069298578
Interface 32-bit PCI
Network Type Wireless 802.11b / 802.11g / 802.11n
Wireless Technology IEEE 802.11b/g
Wireless Transmission Speed 54Mbps
D-Link Xtreme N Wireless-N Desktop Card Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 26, 2009
D-Link Xtreme N Wireless-N Desktop Card Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Excellent Card
"I have a media PC downstairs and my wireless router is upstairs. I previously had some cheapie card in my PC which couldn't even get a signal from the upstairs router. I am transitioning to a wireless-N network in order to stream HD content to and from various sources. My first step was to upgrade the PC's card. Installation was a breeze. Windows XP autodetected it and prompted for the CD as usual. A single rest..." Read Full Review »
Oct 12, 2007 by stringplucker
See more positive D-Link Xtreme N Wireless-N Desktop Card reviews
2.0
Poor Product
"I bought 2 of these adapters and the D-Link Xtreme N Wireless router a little over a month ago. I installed both onto machines running Windows XP SP2. I immediately started having performance problems with the machine with the slower processor. I upgraded to the Dlink 1.3 drivers which solved the performance issue but BROKE Dlink's own connection manager software. Eventually the only was I could get a WPA2 conne..." Read Full Review »
Oct 30, 2007 by Hawk491
See more negative D-Link Xtreme N Wireless-N Desktop Card reviews
Displaying 1 - 5 of 57 Reviews
Show
Sort by
Excellent Card
5.0
"I have a media PC downstairs and my wireless router is upstairs. I previously had some cheapie card in my PC which couldn't even get a signal from the upstairs router. I am transitioning to a wireless-N network in order to stream HD content to and from various sources. My first step was to upgrade t …"  Read Full Review »
Was this Wireless Networking review on the D-Link Xtreme N Wireless-N Desktop Card helpful to you?
 Report Abuse  (2)  (0)  0 comments
Oct 12 2007
stringplucker
New Hampshire
Reviewed at:
Price: $69.99
Poor Product
2.0
"I bought 2 of these adapters and the D-Link Xtreme N Wireless router a little over a month ago. I installed both onto machines running Windows XP SP2. I immediately started having performance problems with the machine with the slower processor. I upgraded to the Dlink 1.3 drivers which solved the pe …"  Read Full Review »
Oct 30 2007
Hawk491
Boston, MA
Reviewed at:
Price: $69.99
[1 of 1 customers found this review helpful]
Excellent Network Card
4.0
"I purchased 2 of these cards and the D-Link DIR-655 wireless router to maximize my Draft N experience. I've read reviews both negative and positive, and I experienced some of the same problems as others did. On Vista, I had to use the standard driver that came with the card, XPHE I had to use the la …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 5 2008
NetGeek22
La Plata, MD
Reviewed at:
Price: $69.99
This card works well, it ...
3.0
"This card works well, it also works smooth. However it is not as great as I had hoped. I upgraded from a Wireless G Linksys which got 3 bars in my basement and assumed that this with its triple antennae would be at least as good with my router. I dropped 2 bars. So I only had one bar.
I had to …"  Read Full Review »
Oct 26 2009
TwistedPower
Undisclosed
Excellent Wireless Card
5.0
"This is my first wireless networking endeavor, and it's been a whole lot easier then I thought it was going to be. I read the reviews on here (bestbuy.com) before buying the products that I bought, and thank god I did!
Using the installation software that came with the card was useless to me, I tri …"  Read Full Review »
Feb 20 2009
Cheezewhiz
Anchorage, AK
Reviewed at:
Price: $69.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
