D-Link WIRELESS ROUTER, RANGEBOOSTER DRAFT 802.11N 4 Port Switch
#18
4.1
based on 46 reviews
Ratings Distribution
5 star
23
4 star
14
3 star
2
2 star
6
1 star
1
Category Average
3.8
Low Price:
$59.99 at TigerDirect
 Trusted:
$64.99 at Dell
Find it at Amazon
$59.99 - $98.20
from 9 stores
More Images
Pros
  • Easy setup (1)
  • Fast (1)
  • Secure (1)
See less See more
Best Uses
  • Home (1)
  • Small office (1)
Provided by Beach Audio
MODEL- DIR-625 VENDOR- D-LINK
FEATURES- Platinum Series RangeBooster N Router
Create a secure high-speed wireless network using the D-Link
RangeBooster N Router (DIR-625) and share your broadband internet
access with multiple computers in your home, along with photos,
music, movies, and more. The RangeBooster N Router is a draft
802.11n compliant high performance wireless router that delivers
signal rates of up to 300Mbps and 4x farther coverage than an
802.11g connection. It also remains backward compatible with
802.11g and 802.11b wireless devices for improving the wireless
coverage area. With a built-in award-winning QoS Engine, this
router enables an enhanced Internet experience by keeping digital
phone calls (VoIP) and online gaming smooth and responsive.
Includes RangeBooster N Router, 2 Detachable Antennas, CAT5 Ethernet
Cable, Power Adapter, CD-ROM with: Installation Wizard, Product
Documentation and Special Offers.
* SUPERIOR HOME NETWORK COVERAGE
Powered by RangeBooster N technology, this high performance router
provides superior home network coverage while reducing dead spots. The
RangeBooster N Router is designed for use in large homes and for users
that demand higher networking performance. Add a RangeBooster N desktop
or notebook adapter and stay connected to your network from virtually
all corners of your home.
* SUPERIOR NETWORK SECURITY
The RangeBooster N Router supports the latest wireless security features
to help prevent unauthorized access, be it from over the wireless
network or from the Internet. Support for WPA and WPA2 encryption
standards ensure that you will be able to use the best available
encryption, regardless of your client device. In addition, the
RangeBooster N Router utilizes dual active firewalls (SPI and NAT) to
help prevent potential attacks from across the Internet.
Delivering superior wireless performance, advanced network security, and
excellent home network coverage, the RangeBooster N Router (DIR-625) is
the ideal wireless networking solution for large homes.
* NOTE: Maximum wireless signal rate derived from IEEE Standard 802.11g and
draft 802.11n specifications. Actual data throughput will vary.
Network conditions and environmental factors, including volume of
network traffic, building materials and construction, and network
overhead, lower actual data throughput rate. Environmental factors
will adversely affect wireless signal range. All attached devices
must support 802.1p queuing to allow QoS functionality.
-- SPECIFICATIONs ------------------------------------
STANDARDS - IEEE 802.11n (draft), IEEE 802.11g, IEEE 802.11b
IEEE 802.3, IEEE 802.3u
ANTENNA TYPE - 2 External Reversed SMA Antenna
SECURITY - Wi-Fi Protected Access (WPA, WPA2)
FIREWALL - Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
VPN Pass-through/Multi-sessions PPTP/L2TP/IPSec
MANAGEMENT - Internet Explorer v6 or Later; Mozilla Firefox v1.5 or
Later; or other Java-enabled Browsers.
INDICATORS - LEDs for Power, Status, WAN, WLAN, LAN (10/100), USB
REQUIREMENTS - Cable or DSL Modem
Computer with: Windows XP SP2 or Windows 2000 SP4
or Mac OS X (v10.4)
Internet Explorer v6 or Mozilla Firefox v1.5
CD-ROM Drive
Network Interface Card
APPROVALS - FCC, CE
DIMENSIONS - 4.6"w x 1.2"h x 7.6"d WT.- 0.7 lbs.
www.dlink.com
tech@irvine.dlink.com
Specification Description
Model DIR-625, DIR625
UPC 790069292637
Interface 4 x RJ-45 10/100Base-TX Auto MDI/MDI-X LAN
Network Type Wireless 802.11b / 802.11g / 802.11n
Transmission Speed 300Mbps
Wireless Technology IEEE 802.11b/g
D-Link WIRELESS ROUTER, RANGEBOOSTER DRAFT 802.11N 4 Port Switch Questions
Questions and Answers
Where to Buy
$64.99
$59.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$95.00
Show all 9 stores
Product Reviews
Last update: Oct 27, 2009
D-Link WIRELESS ROUTER, RANGEBOOSTER DRAFT 802.11N 4 Port Switch Reviews
Most helpful positive review
Most helpful negative review
5.0
Great Wireless Router
"This is a great wireless router. I was using a Linksys G with Speedbooster, which was fine, but the range on this router is much better. It definitely has a more in depth feature set as well. One thing I couldn't do with the Linksys that bothered me was being able to set an ip reservation for devices so they always received the same ip, the D-Link can do so. Also this router has N capability which is very nic..." Read Full Review »
Aug 06, 2008 by popeboy
See more positive D-Link WIRELESS ROUTER, RANGEBOOSTER DRAFT 802.11N 4 Port Switch reviews
3.0
Like others I have had ...
"Like others I have had issues with the install. After hours spent trying to install using the quick start and the manual instructions I finally called D-link support. More hours going over the same thing I did only to be told that the unit is defective. I like the features and am exchaning it for another. I will update this review when I receive the replacement. Received replacement and installed it in unde..." Read Full Review »
Sep 21, 2009 by BOB
See more negative D-Link WIRELESS ROUTER, RANGEBOOSTER DRAFT 802.11N 4 Port Switch reviews
Displaying 1 - 5 of 46 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Secure
    Cons
  • None
    Best Uses
  • Home
  • Small Office
One thing I couldn't do with the Linksys that bothered me was being able to set an ip reservation for dev …"  Read Full Review »
Was this Network Router & Bridge review on the D-Link WIRELESS ROUTER, RANGEBOOSTER DRAFT 802.11N 4 Port Switch helpful to you?
Aug 6 2008
popeboy
Parma, OH
I am:
  • High bandwidth user
Reviewed at:
3.0
"Like others I have had issues with the install. After hours spent trying to install using the quick start and the manual instructions I finally called D-link support. More hours going over the same thing I did only to be told that the unit is defective. I like the features and am exchaning it for …"  Read Full Review »
Sep 21 2009
BOB
Undisclosed
Reviewed at:
Price: $59.99
Excellent router!! Had a ...
4.0
"Excellent router!! Had a few issues at the start with this router. My wireless connection would work, but my wired PC would drop internet connection at times. Had to re-install to get it to work when that happened a few times. Then I updated the firmware, and found out that my Webroot Spy Sweeper …"  Read Full Review »
May 5 2009
Canadian24
Undisclosed
Reviewed at:
Price: $59.99
I purchased this product ...
2.0
"I purchased this product just so i could hook up a printer for remote access inside house. After two , over 30 minute phone calls and 5 emails the usb shareport still doesnt work , i have done everything D=link trchs say and then some ,,,each tech at Dlink has a different answer to problem ,,downloa …"  Read Full Review »
Aug 11 2009
rpwjr
Undisclosed
Reviewed at:
Price: $59.99
The first one they sent ...
2.0
"The first one they sent me did not work. It took me about four hours of sitting on the phone with D-Link for them to realize that it was faulty. When I tried to exchange the product, It was nothing but trouble. They were not able to just exchange it. I had to re-buy it and wait for my money to be pu …"  Read Full Review »
Jan 28 2008
wasted tim
Undisclosed
Reviewed at:
Price: $59.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
