D-Link 4 Port High Speed USB 2.0 Hub (DUB-H4)
#130
4.5
based on 4 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
1
2 star
0
1 star
0
Category Average
4.1
$21.22 - $35.04
from 14 stores
More Images
Pros
  • Easy setup (3)
  • Reliable (3)
  • Small (3)
  • Fast (2)
  • Easily expanded (1)
See less See more
Cons
  • Not energy efficient (1)
Best Uses
  • Desktop (2)
  • Home (2)
  • Small networks (2)
Provided by Shoppers Choice
MODEL- DUB-H4 VENDOR- D-LINK FEATURES- Hi-Speed USB 2. 0 4-Port Hub The DUB-H4 is a Hi-Speed USB 2. 0 4-Port Hub. The D-Link DUB-H4 adds an additional four ports to an existing USB 2. 0 compatible computer. The DUB-H4 provides users with four additional Hi-Speed USB 2. 0 ports to expand peripheral connectivity. Plug-&-Play installation requires no driver disk. One Type B upstream port allows the DUB-H4 to connect to a USB 2. 0 host adapter such as the DU-520 (5-Port USB 2. 0 PCI adapter) or DUB-A2 (2-port USB 2. 0 PCI adapter). A USB 2. 0 host adapter with one free port is required to take advantage of the Hi-Speed features of the DUB-H4 such as the DU-520 (5-Port USB 2. 0 PCI Adapter) or DUB-A2 (2-port USB 2. 0 PCI adapter). Start benefiting from all the Hi-Speed USB 2. 0 peripherals that can make your computer time more fun and more productive. At 480Mbps, 40 times faster than USB 1. 1, USB 2. 0 provides the required band- width for external storage, printing, scanning and CD burning. The DUB-H4 Hi-Speed USB 2. 0 4-port Hub lets you do more with your PC or Mac. With four additional USB 2. 0 ports, the DUB-H4 provides an affordable and convenient way to connect your computer with today s latest USB peripherals. The DUB-H4 has a sleek industrial design and is compact in size, allowing you to save more desktop space for your gadgets. The DUB-H4 supports USB 1. 1 without sacrificing compatibility with your older USB devices. STANDARDs - USB Specification Version 2. 0 USB Specification Version 1. 1 USB Specification Version 1. 0 OHCI (Open Host Controller Interface) EHCI (Enhanced Host Controller Interface) CONNECTORs - (4) USB Type A downstream ports (1) USB Type B upstream ports INDICATORs - LEDs for Self-powered, Port status TOPOLOGY - Tiered Star CONNECTIVITY - up to 127 devices by cascading multiple hubs O/S COMPATIBLE- For USB 2. 0 Speed: Microsoft Windows 98, Me, 2000, XP with USB 2. 0 Support Mac OS X with USB 2. 0 Support For USB 1. X Speed: Microsoft Windows 98, Me, 2000, XP with USB1. X Support Mac OS 8. 6 or above with USB 1. X Support and USB Card Support 1. 4. 1. APPROVALS- CE, FCC B, VCCI, UL POWER- Bus Powered - 2. 5 W, 0. 5 A 3. 3 VDC ( or -. 3 VDC ) Self Powered - 12. 6W, 2. 1 A 6 VDC Power Supply - Output 5V 2. 5A Consumption: 150 mA 3. 3 VDC SIZE - 3. 98 inch x 2. 38 x 1. 03 inch www. Dlink. Com tech irvine. Dlink. Com
Specification Description
Model 790069243905, DUB-H4, DUBH4
UPC 790069243905
Form Factor External
Number of Ports 4
D-Link 4 Port High Speed USB 2.0 Hub (DUB-H4) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Apr 16, 2009
D-Link 4 Port High Speed USB 2.0 Hub (DUB-H4) Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Third One ......... They're Great
5.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
  • Small Networks
"I use these hubs to expand my office peripheral equipment with great success.... they work great and D-Link has great tech support!! "
Was this Networking Hub & Switch review on the D-Link 4 Port High Speed USB 2.0 Hub (DUB-H4) helpful to you?
Sep 23 2008
Jim S
Princeton NJ
I am:
  • High bandwidth user
Reviewed at:
Price: $24.95
no complaints
3.0
    Pros
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • Energy Inefficient
    Best Uses
  • Small Networks
"Very easy to set up, no conflicts with peripherals. "
Jul 27 2008
raffan
new york, ny
I am:
Reviewed at:
Price: $24.95
[1 of 2 customers found this review helpful]
d-link 4 port
5.0
"Pros
it is a nice 4 port high speed usb hub i never hd a problem . i have used them for about 8 years this is the second hub i have ordered from dell
Cons
none
Additional Thoughts
none "
 Report Abuse  (1)  (1)  0 comments
Jan 19 2009
shakeyjake
nebraska
Reviewed at:
Works well
5.0
    Pros
  • Easy To Set Up
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
"Works well, no problems, would buy another "
Apr 16 2009
Cjenso
Scotch plains NJ
I am:
Reviewed at:
Price: $24.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
