Cyberpower CP600LCD UPS Battery Backup
#41
4.0
based on 2 reviews
from $67.14 - $89.95
Ratings Distribution
5 star
0
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.1
Low Price:
$67.14 at pcRUSH
 Trusted:
$68.95 at PC Connection
Find it at Amazon
More Images
Provided by Beach Audio
FEATURES- CP600LCD Compact Series UPS- Black finish
The CP600LCD Home and Office Series UPS is ideal power protection
for individuals running a stand-alone PC in their home or office.
Real-time system vitals can be viewed from the Crystal-Blue LCD
display, and the unit can be conveniently mounted in a workstation
cabinet or directly on the desktop. LCD diagnostics include Input
Voltage Level, Output Voltage Level, Battery Capacity, Runtime,
Load Level, Output Power Frequency, On Battery, Overload, Wiring
Fault, and Silent Mode. It also includes PowerPanel PE Power
Management software which monitors the vitals of the UPS and will
safely shutdown your system in case of a power outage.
Composite IC circuitry offers advanced lightning protection and also
guards against surges, spikes, sags, brownouts and other power
abnormalities. This rugged unit is equipped with a RJ11/45 port
which protects against surges from phone, modem, network, and
broadband disruptions. The small footprint design is ideal for
horizontally or vertically placement, and is even designed for
wall-mountability. A HID compliant USB port allows for
connectivity of both PC and Mac systems.
The unit is also perfect for protecting other electronics such as
monitors, printers, scanners, speakers, fax machines, CD/DVD
players, and iPods.
Includes UPS Unit; User Manual; Power Management Software; Warranty
Card; Phone Cable; USB Cable.
* Crystal-Blue LCD Diagnostic Display
The innovative front panel LCD can be used to display detailed
information on the UPS status and current power conditions. The LCD
displays 10 different diagnostics: Input Voltage Level, Output Voltage
Level, Battery Capacity, Runtime, Load Level, Output Power Frequency, On
Battery, Overload, Wiring Fault, and Silent Mode.
* EMI/RFI
Provides shielding against electromagnetic interference & radio
frequency signals. Most commonly, this is used to prevent line noise or
"humming" that occurs over telephone lines or stereo electronics.
* Transformer-spaced Outlets
Widely spaced outlets allow you to conveniently add large transformer-
based plugs without compromising the utility of other outlets.
* USB Connectivity
HID compliant USB port enables full integration with built-in power
management and auto shutdown features of Windows, Linux and Mac OS X.
* PowerPanel PE Smart Management Software
In event of a power outage, PowerPanel PE will not only save your open
files and will also "Hibernate" your PC to increase the run-time on the
UPS unit.
PowerPanel is quickly and easily installed on any Windows-based PC and
is designed to utilize minimal system resources. Diagnostic screens
give immediate visuals of the UPS s status, and also include the
following features: Silent operation mode, configurable system
notifications, automatic self tests, adjustable high/low voltage
warnings, event/data logging, and scheduled shutdowns.
* LED Indicators
LED status lights indicate Power-On and wiring faults.
* Audible Alarms
Audible tones identify when the unit is running off battery power, unit
overloads and low battery.
* Convenient Mounting
Multiple mounting options: horizontal, vertical, cabinet, and wall.
* Resettable Circuit Breaker
Convenient unit reset switch in case of an overload.
* 3-year Warranty
CyberPower will replace damaged units if within 3 years of purchase
date. We stand behind our products and guarantee quality. CyberPower
also offers a #1 rated technical support team that will assist you with
product, installation, or warranty concerns --- Free of Charge!
* ISO & Safety Certifications
All CyberPower's manufacturing facilities are ISO-9001 Quality Tested.
Our products are also certified by the FCC, cUL, and UL.
* Windows Vista Compliant
Our Power Management software has been fully tested and compliant with
Windows 9x, 200x, Server, XP, and Vista.
-- SPECIFICATIONS -----------------------------------
POWER - Waveform : Simulated Sine Wave
Load Capacity : 600 VA
Load Capacity : 340 Watts
Automatic Voltage
Reg. (AVR) : none
INPUT/OUTPUT - Plug/Connector : NEMA 5-15P
Input Voltage : 100 - 140 Volts AC
Input Frequency : 57 - 63 Hz
Output Voltage : 120 Volts AC
Output Frequency : 59 - 61Hz
Switching Time : 4 ms
RECEPTACLES/OUTLETS-
Total Receptacles : (8)
(4) 5-15R (Battery/Surge)
(4) 5-15R (Surge Only)
BATTERY & RUNTIME-
Quantity/Type : (1) 12V/7Ah
Maintenance Free : Yes
Sealed Lead-acid : Yes
User-replaceable : Yes
Hot-swappable : Yes
Battery Life : 3-6 Years
Runtime (Half Load): 2 Minutes
Runtime (Full Load): 10 Minutes
Recharge Time : 8 Hours
COMMUNICATIONS & MANAGEMENT-
SNMP : N/A
Overload Protection: On Utility: Circuit Breaker
On Battery: Internal Current Limiting
Audible Alarms : On Battery; Low Battery; Overload
LEDs : Input Voltage Level, Output Voltage
On Battery, Overload, Wiring Fault,
Silent Mode.
Interfaces : (1) USB 4-pin
Modular Slots : N/A
SURGE PROTECTION & FILTERING-
Surge Energy Rating: 1030 Joules
Filtering : EMI/RFI
Phone/Network
Protection: (1) RJ11/45 Combo (One-in/One-out)
Coax/Cable
Protection : N/A
SOFTWARE - Includes PowerPanel Personal Edition
ENVIRONMENTAL- Temperature : 32 to 95 degrees F (Operating)
Temperature : 5 to 113 degrees F (Non-Operating)
Humidity : 0 to 95% Non-condensing (Operating)
Humidity : 0 to 95% Non-condensing (Non-Operating)
Altitude : 0 to 10,000 feet (Operating)
Altitude : 0 to 50,000 feet (Non-Operating)
WARRANTY - $125,000 Insurance
APPROVALS - FCC B, CUL, UL1778
POWER CORD - 6 foot
DIMENSIONS - 11.0"w x 6.5"h x 3.5"d WT.- 11.6 lbs.
www.cyberpowersystems.com
Specification Description
Model CP600LCD, CYBCP600LCD
UPC 649532016006
Form Factor Multi-mount Desktop
Input Voltage 110V AC
Load Capacity 600VA
Output Voltage 120V AC Single-phase
Plug/Connector Type NEMA 5-15P
Receptacles 4 x NEMA 5-15R - Backup/Surge-protected
Standard Warranty 3 Year Parts & Labour
UPS Type Standby UPS
Cyberpower CP600LCD UPS Battery Backup Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 15, 2008
Cyberpower CP600LCD UPS Battery Backup Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Just what I needed
4.0
"I bought this to keep my cable digital box powered during power outages. We lose power at least once every 3 months. I didn't realize that I could also power my receiver. With receiver and digital box, it says I have 30+ minutes of run time. Nice bonus for weather info during a hurricane. Makes g …"  Read Full Review »
Was this Battery Backup/UPS review on the Cyberpower CP600LCD UPS Battery Backup helpful to you?
Feb 23 2008
nanmka
Tampa, FL United States
Reviewed at:
Price: $89.95
Great UPS
4.0
"As with the other CP products I have this one works just as you would expect.
My only issue is that the LCD status display can't be configured to stay on all the time. "
Aug 15 2008
DeP
Chicagoland, USA
Reviewed at:
Price: $89.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
