Cyberpower CP Office Tower 1350AVRLCD1350VA UPS
#16
4.9
based on 7 reviews
from $124.97 - $189.95
Ratings Distribution
5 star
6
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Provided by Beach Audio
FEATURES- CP Tower Series UPS
The CyberPower Systems CP1350AVRLCD UPS, designed for mid to high-
end computer systems, features dynamic line conditioning and a LCD
diagnostic display. Real-time system vitals can be viewed from
this display and the unit can be conveniently mounted in a
workstation cabinet or directly on the desktop.
The CP1350AVRLCD also guards against surges/spikes, and also offers
battery backup in the event of brownouts or total power loss.
Automatic Voltage Regulation (AVR) ensures that all your electronics
are receiving clean power and stabilizes the voltage to a nominal
120VAC. PowerPanel PE Management Software automatically saves and
closes open files and then shuts down the computer system in an
intelligent and orderly manner.
The CP series are also equipped with full dataline protection:
RJ11/RJ45 (phone, fax, Ethernet, network, DSL) and RG-6 coax (DSS,
cable modem, satellite, cable TV).
"Surge-Only" outlets are perfect for the addition of peripherals
such as monitors, printers, scanners, iPods, or CD/DVD players.
CyberPower stands behind its projects by offering an industry-
leading 3-year warranty, coupled with our award winning Technical
Support and Connected Equipment Guarantees of up to $425,000.
Includes UPS Unit; User Manual; Power Management Software; Warranty
Card; USB Cable; Phone Cable; Coaxial Cable.
* Crystal-Blue LCD Diagnostic Display: The innovative front panel LCD
can be used to display detailed information on the UPS status and
current power conditions. The LCD displays 11 different diagnostics:
Input voltage level, Output voltage level, Automatic voltage regulator,
Runtime estimate, Load level, Power frequency, On battery, Overload,
Fault, Battery capacity, and Silent mode.
* Automatic Voltage Regulation (AVR) - Incoming AC power is electronically
regulated for dips and spikes AVR takes this irregular AC power and
converts it into a consistent Sinewave so sensitive electronic equipment
can achieve its optimal performance.
* EMI/RFI - Provides shielding against electromagnetic interference & radio
frequency signals. Most commonly, this is used to prevent line noise or
"humming" that occurs over telephone lines or stereo electronics.
* Transformer-spaced Outlets - Widely spaced outlets allow you to
conveniently add large transformer-based plugs without compromising the
utility of other outlets.
* USB Connectivity - Plug-N-Play software and convenient USB ports allow
for quick and easy installation.
* PowerPanel PE Smart Management Software - In event of a power outage,
PowerPanel PE will not only save your open files and will also
"Hibernate" your PC to increase the run-time on the UPS unit. PowerPanel
is quickly and easily installed on any Windows-based PC and is designed
to utilize minimal system resources. Diagnostic screens give immediate
visuals of the UPS s status, and also include the following features:
Silent operation mode, configurable system notifications, automatic self
tests, adjustable high/low voltage warnings, event/data logging, and
scheduled shutdowns.
* LED Indicators - LED status lights indicate Power-On and wiring faults.
* Audible Alarms - Audible tones identify when the unit is running off
battery power, unit overloads and low battery.
* Convenient Mounting - Multiple mounting options: horizontal, vertical,
cabinet, and wall.
* Resettable Circuit Breaker - Convenient unit reset switch in case of
an overload.
* 3-year Warranty - CyberPower will replace damaged units if within
3 years of purchase date. We stand behind our products and guarantee
quality. CyberPower also offers a #1 rated technical support team
that will assist you with product, installation, or warranty concerns
--- Free of Charge!
* ISO & Safety Certifications - All CyberPower's manufacturing facilities
are ISO-9001 Quality Tested. Our products are also certified by the FCC,
cUL, and UL.
* Windows Vista Compliant - Our Power Management software has been fully
tested and compliant with Windows 9x, 200x, Server, XP, and Vista.
-- SPECIFICATIONS ----------------------------------
POWER - Waveform : Simulated Sine Wave
Load Capacity : 1350 VA
Load Capacity : 810 Watts
Automatic Voltage
Reg. (AVR) : Boost
INPUT/OUTPUT - Plug/Connector : (1) NEMA 5-15P
Input Voltage : 90 - 140 Volts AC
Input Frequency : 57 - 63 Hz
Output Voltage : 120 Volts AC
Output Frequency : 59 - 61Hz
Switching Time : 4 ms
RECEPTACLES/OUTLETS-
Total Receptacles : (8)
(4) 5-15R (Battery/Surge)
(4) 5-15R (Surge Only)
BATTERY & RUNTIME-
Quantity/Type : (2) 12V/8Ah
Maintenance Free : Yes
Sealed Lead-acid : Yes
User-replaceable : Yes
Hot-swappable : Yes
Battery Life : 3-6 Years
Runtime (Half Load): 2 Minutes
Runtime (Full Load): 11 Minutes
Recharge Time : 8 Hours
COMMUNICATIONS & MANAGEMENT-
SNMP : N/A
Overload Protection: On Utility: Circuit Breaker
On Battery: Internal Current Limiting
Audible Alarms : On Battery; Low Battery; Overload
LEDs : Power On; Wiring Fault
Interfaces : (1) Serial DB9
(1) USB 4-pin
Modular Slots : N/A
SURGE PROTECTION & FILTERING-
Surge Energy Rating: 1500 Joules
Filtering : EMI/RFI
Phone/Network
Protection: (1) RJ11/45 Combo (One-in/One-out)
Coax/Cable
Protection : (1) RG-6
SOFTWARE - Includes PowerPanel Personal Edition
ENVIRONMENTAL- Temperature : 32 to 95 degrees F (Operating)
Temperature : 5 to 113 degrees F (Non-Operating)
Humidity : 0 to 95% Non-condensing (Operating)
Humidity : 0 to 95% Non-condensing (Non-Operating)
Altitude : 0 to 10,000 feet (Operating)
Altitude : 0 to 50,000 feet (Non-Operating)
WARRANTY - $425,000 Insurance
APPROVALS - FCC B, CUL, UL1778
POWER CORD - 6 foot
DIMENSIONS - 4.0"w x 9.75"h x 13.25"d WT.- 24.6 lbs.
www.cyberpowersystems.com
Specification Description
Model CP1350AVRLCD
UPC 649532013500
Form Factor Tower
Input Voltage 110V AC
Load Capacity 1350VA
Output Voltage 120V AC Single-phase
Plug/Connector Type NEMA 5-15P
Receptacles 4 x NEMA 5-15R - Backup/Surge-protected
Standard Warranty 3 Year Parts & Labour
UPS Type Line-interactive UPS
Cyberpower CP Office Tower 1350AVRLCD1350VA UPS Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 3, 2009
Cyberpower CP Office Tower 1350AVRLCD1350VA UPS Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[5 of 5 customers found this review helpful]
Works like a champ
5.0
"I've had my Cyberpower 1350 for almost a year now and it has worked well switching to backup power dozens of times. I have a large desktop with two raptor HD's and two standard HD's, an IBM 19" CRT monitor, a Viewsonic 22" LCD monitor, a Canon 9000Pro printer, canon 8400F scanner and several other …"  Read Full Review »
Was this Battery Backup/UPS review on the Cyberpower CP Office Tower 1350AVRLCD1350VA UPS helpful to you?
 Report Abuse  (5)  (0)  0 comments
Aug 17 2008
AVJGUY
Templeton CA
Reviewed at:
Price: $189.95
Nice UPS, does its job well
5.0
"I've owned one of these for over a month now. I use it with my computer, and overall, I've been very satisfied with it. It has already proven itself, as we've lost power a few times already, and this kept my computer running without a problem. I can't think of any bad things to say about it.
Pro …"  Read Full Review »
Jul 3 2009
Eric
Portland, OR, USA
Reviewed at:
Price: $189.95
[3 of 3 customers found this review helpful]
Powerful and easy to set up
5.0
"I bought two of these, one for my home computer/network, and one for my home theater system. I'm not using the software for either. I especially like the dosplay on the front. Recently during hurricane Ike, I used them to power a small TV for hours. Seem to hold plenty of juice. "
 Report Abuse  (3)  (0)  0 comments
Oct 29 2008
Hugh D. Murray
Humble, TX United States
Reviewed at:
Price: $189.95
Great value!
5.0
"This is my 2nd CyberPower UPS. I bought this one for my wife's desktop PC that we use as a centralized storage unit and for backup of one other desktop and a laptop on our home network. We now have a CyberPower UPS on each of the desktops. We made the purchase because of numerous momentary power int …"  Read Full Review »
Jun 24 2009
Bob in PA
Amazon
Reviewed at:
Price: $189.95
Better than expected with zero lag
5.0
"Works very well, I have a dish network 622 that is very, very sensitive to power interruptions (the lights would flicker and it would reset!) and the reboot takes a long time. This works well and has my 52" LCD, DVR, aTV and two routers plugged in, kept it all running for around 30 mins with no inte …"  Read Full Review »
May 23 2009
Jamie M. Keogh
Houston, TX
Reviewed at:
Price: $189.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
