Crucial Additional 2GB (1X2GB) 204-pin SODIMM DDR3 PC3-8500 Memory Module
#5427
4.8
based on 7 reviews
Ratings Distribution
5 star
4
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.6
$39.99 - $99.99
from 14 stores
More Images
Pros
  • Easy to install (1)
  • Fast (1)
  • Fast connectivity (1)
  • Reliable (1)
See less See more
Cons
  • Freezes easily (1)
Best Uses
  • Increased performance (1)
  • Laptops (1)
Provided by PC Mall
Additional 2GB (1X2GB) 204-pin SODIMM DDR3 PC3-8500 Memory Module 204-pin small outline dual inline memory modules (SODIMMs) are the form factor used to provide DDR3 memory modules for notebook computers and other small form factor computing platforms. In short, 204-pin small outline dual inline memory modules (SODIMMs) are the form factor used to provide DDR3 memory modules for notebook computers and other small form factor computing platforms. 204-pin SODIMMs are currently available in PC3-8500 (DDR3 1066MHz) speeds.To use DDR3 memory, your system must have both a 204-pin SODIMM slot and a chipset that supports DDR3 memory. A DDR3 SODIMM will not fit into DDR2 or DDR memory sockets.SODIMMs are smaller and thinner than regular DIMMs, and the 204-pin SODIMM PCBs are always ~2.6 inches long and are usually around 1.75 inches high (though the heights can vary slightly). They consist of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The number of memory components on a 204-pin SODIMM's printed circuit board (PCB) can vary, but the PCB will always have 102 pins on the front and the back both, for a total of 204 pins. The gold pins on the bottom of the SODIMM provide the connection between the memory module and the memory socket.
Specification Description
Model CT25664BC1067, CT898328
UPC 649528741219
Connection Type DDR3 SDRAM
Memory for use in Notebook
Memory Size 2GB
Memory Speed 1066MHz
Memory Type 204-pin SoDIMM
Memory Upgrade Type DDR3
Number of Memory Sticks in Pack 1
Crucial Additional 2GB (1X2GB) 204-pin SODIMM DDR3 PC3-8500 Memory Module Questions
Questions and Answers
Where to Buy
$39.99
$46.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$44.99
Show all 14 stores
Product Reviews
Last update: Nov 17, 2009
Crucial Additional 2GB (1X2GB) 204-pin SODIMM DDR3 PC3-8500 Memory Module Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Great Product
5.0
    Pros
  • Easy To Install
  • Fast
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Increased Performance
"Great RAM for my new HP Netbook - improved performance "
Was this Computer Memory review on the Crucial Additional 2GB (1X2GB) 204-pin SODIMM DDR3 PC3-8500 Memory Module helpful to you?
Nov 17 2009
Sher
York, ME
I am:
  • Casual User
Reviewed at:
Price: $39.99
Upgraded my MacBook to ...
5.0
"Upgraded my MacBook to 4GB with 2 of these. I was a little skeptical about using this memory first as there was other memory specifically labeled for Apple (but was twice the price) until I read these reviews. Thanks to everyone else who provided reviews that it worked fine in their Macs. "
Nov 2 2009
newfie
Undisclosed
Reviewed at:
Price: $46.99
Installed 2 of these to ...
5.0
"Installed 2 of these to upgrade my macbook unibody to 4GB of RAM.... Opened up several programs and the wheel of death doesnt appear no more... if i do see its for a glimpse... Verry happy i upgraded the RAM.... I recommend.... "
Sep 17 2009
C-LoS
Undisclosed
Reviewed at:
Price: $46.99
I bought two sticks for ...
5.0
"I bought two sticks for my 13" macbook pro to upgrade from the 2 gb base up to the 4 gb. Plugged them in, and working without an issue. Cost less that paying Apple, less than buying direct from the OEM. Nothing more to ask for. "
Jul 17 2009
coloradogr
Undisclosed
Reviewed at:
Price: $46.99
I installed two of these ...
5.0
"I installed two of these in my Mac Mini bringing it up to 4GB. No issues, boots and recognizes the memory just fine. MUCH cheaper than buying directly from Apple. "
Oct 11 2009
Biff
Undisclosed
Reviewed at:
Price: $46.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
