Crucial 4GB kit (2GBx2) Upgrade for a Dell Precision M6300 System
#317
4.7
based on 56 reviews
Ratings Distribution
5 star
47
4 star
6
3 star
1
2 star
1
1 star
1
Category Average
4.6
$51.99 at Crucial
Find it at Amazon
Find it at Ebay
$51.99
from 1 store
Pros
  • Easy to install (55)
  • Reliable (43)
  • Fast (21)
  • Increases speed (20)
  • Affordable (1)
  • Cost competetive (1)
  • Great product (1)
  • Large capacity / good size (1)
  • Speed increase (1)
  • Works like a charm (1)
See less See more
Cons
  • No increase in speed (2)
  • Hard to open package (1)
  • Unreliable performance (1)
  • Web order system errors (1)
Best Uses
  • Multiple desktop applications (33)
  • Increased performance (24)
  • Multimedia (20)
  • Gaming (3)
  • Back-up (2)
  • Adobe suite apps (1)
  • Audio editing (1)
  • Daw (1)
  • Improved vm performance (1)
  • Large andor multiple vms (1)
Provided by Crucial
4GB kit (2GBx2), 200-pin SODIMM, DDR2 PC2-5300, NON-ECC,
Crucial 4GB kit (2GBx2) Upgrade for a Dell Precision M6300 System Questions
Questions and Answers
Where to Buy
$51.99
BizRate Rating Outstanding 9.3
Product Reviews
Last update: Nov 17, 2009
Crucial 4GB kit (2GBx2) Upgrade for a Dell Precision M6300 System Reviews
Most helpful positive review
Most helpful negative review
5.0
Minor improvement
"I mainly use my MacBook Pro for internet surfing, managing pictures in iPhoto and managing music in iTunes. It is not uncommon for me to have 3 or 4 Safari windows, iTunes and iPhoto opened. Every now and then I noticed windows took a little longer to open or switch between. Knowing I only had 1 gig of 5300 ram. I decided to upgrade to 4 gig of 5300 to fix the problem. All the multi tasking I was doing m..." Read Full Review »
Oct 29, 2009 by Sean the pilot
See more positive Crucial 4GB kit (2GBx2) Upgrade for a Dell Precision M6300 System reviews
1.0
Product did not work at all
"I received the two Ram Chips as a gift. I properly installed the Ram Chip and the computer fan started but the screen remained black and there was no startup sound. I tried one 2 gig chip and one one gig and then reversed the slots for each chip then tried two two gig in the two slots. nothing worked the roam chips do not work. I have a Mac Book Pro 2.33 ghz manufacture date November 2006. the specs for the ..." Read Full Review »
May 28, 2009 by James
See more negative Crucial 4GB kit (2GBx2) Upgrade for a Dell Precision M6300 System reviews
Displaying 1 - 5 of 56 Reviews
Show
Sort by
Crucial delivered as advertised
5.0
    Pros
  • Easy To Install
  • Fast
    Cons
  • None
    Best Uses
  • Improved VM Performance
  • Increased Performance
"The Windows VM on my Mac Book Pro now launches and runs much faster. Putting my laptop to sleep now takes about 15 seconds, instead of a couple minutes, and waking again after in sleep mode is nearly instantaneous. Less expensive options were available, but Crucial came highly recommended to me. I …"  Read Full Review »
Was this Computer Memory review on the Crucial 4GB kit (2GBx2) Upgrade for a Dell Precision M6300 System helpful to you?
Nov 9 2009
Lyndy
Stratham NH
I am:
  • Power user
Reviewed at:
Price: $51.99
Minor improvement
5.0
    Pros
  • Easy To Install
  • Fast
  • Reliable Performance
    Cons
  • No Increase In Speed
    Best Uses
  • None
Every now and then I noticed windows took a little longer to open or switch between. Knowing I only ha …"  Read Full Review »
Oct 29 2009
Sean the pilot
Louisville, KY
I am:
  • Power user
Reviewed at:
Price: $51.99
It's RAM alright!
5.0
    Pros
  • Easy To Install
  • Increases Speed
    Cons
  • None
    Best Uses
  • Adobe suite apps
  • DAW
  • Software Samplers
"I use my Macbook Pro for my audio and design computer away from my 8 Core at work. It is worth noting that this RAM went in on my mbp with less fiddling than my xeon- but this is probably to be expected with the increased slot count.
The RAM has exponentially increased performance on an already fas …"  Read Full Review »
Aug 5 2008
agentwonderbread
Athens, Ga.
I am:
  • Power user
Reviewed at:
Price: $51.99
Perfectly compatible and easy to install
5.0
    Pros
  • Easy To Install
  • Speed increase
    Cons
  • None
    Best Uses
"In my previous experience with another company, the 4Gb Memory Kit advertised and sold for the MacBook Pro didn't work, even after running all the reset functions and programs suggested by the vendor and by the manufacturer for more than an hour. When I returned the "non working" memory to them, the …"  Read Full Review »
Jul 13 2009
Mac Fan
Mill Creek, WA
I am:
  • Power user
Reviewed at:
Price: $51.99
Fantastic performance at a great price!
5.0
    Pros
  • Cost competetive
  • Easy To Install
  • Increases Speed
    Cons
  • None
    Best Uses
  • Multimedia
"I spent a lot of time looking for the best options to replace my OEM RAM chip in a MacBook Pro 2.2GHz. I narrowed it to three vendors with excellent reputations and user reviews, of which Crucial was one. Buying direct from the company saved me approximately 25% from the major retail outlets, and it …"  Read Full Review »
Mar 16 2009
Steve
Lancaster, PA
I am:
  • Power user
Reviewed at:
Price: $51.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
