Crucial 2GB kit (1GBx2) Upgrade for a Dell Dimension 8400 Series System
#5831
4.6
based on 64 reviews
from $31.99
Ratings Distribution
5 star
49
4 star
11
3 star
1
2 star
0
1 star
3
Category Average
4.6
$31.99 at Crucial
Find it at Amazon
Find it at Ebay
Pros
  • Easy to install (62)
  • Reliable (49)
  • Fast (27)
  • Increases speed (25)
  • Large capacity / good size (1)
See less See more
Cons
  • Hard to install (1)
  • Not compatible with dell (1)
  • Slow transfer (1)
  • Unable to utilize all (1)
  • Unreliable performance (1)
Best Uses
  • Multiple desktop applications (34)
  • Increased performance (25)
  • Multimedia (20)
  • Back-up (3)
  • Gaming (2)
  • All of above (1)
  • In 64 bit os (1)
  • Nut cracker (1)
Provided by Crucial
2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR2 PC2-6400, NON-ECC,
Crucial 2GB kit (1GBx2) Upgrade for a Dell Dimension 8400 Series System Questions
Questions and Answers
Where to Buy
$31.99
BizRate Rating Outstanding 9.3
Product Reviews
Last update: Nov 16, 2009
Crucial 2GB kit (1GBx2) Upgrade for a Dell Dimension 8400 Series System Reviews
Most helpful positive review
Most helpful negative review
5.0
Easy to order and install
"I had an old Dell computer that started to take memory errors and under windows caused many blue screens. After I bought a new dell for the family I thought about trading it in, but then a friend told me to try replacing the memory and see if that fixes the problem. I wasn't sure how to find the correct memory for it since it was an older model. He suggested going to the crucial.com web site and it would help..." Read Full Review »
Nov 16, 2009 by Rich
See more positive Crucial 2GB kit (1GBx2) Upgrade for a Dell Dimension 8400 Series System reviews
1.0
Physical Memory Dump
"I have removed this memory form my machine and returned to my single gig I had before. After installing this memory within a day my computer was giving me the "Blue Screen" stating it was dumping the Physical memory or it would simply cause my computer to restart without warning. I will be contacting Crucial for a refund or replacement with another product. I am having no issues now that it is removed...." Read Full Review »
Apr 25, 2009 by Sam
See more negative Crucial 2GB kit (1GBx2) Upgrade for a Dell Dimension 8400 Series System reviews
Displaying 1 - 5 of 64 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Install
    Cons
  • None
    Best Uses
  • Increased Performance
"I had an old Dell computer that started to take memory errors and under windows caused many blue screens. After I bought a new dell for the family I thought about trading it in, but then a friend told me to try replacing the memory and see if that fixes the problem. I wasn't sure how to find the c …"  Read Full Review »
Was this Computer Memory review on the Crucial 2GB kit (1GBx2) Upgrade for a Dell Dimension 8400 Series System helpful to you?
Nov 16 2009
Rich
Philadelphia, PA
I am:
  • Casual User
Reviewed at:
Price: $31.99
Memory Kit Exceeded Expectations
5.0
    Pros
  • Easy To Install
  • Fast
  • Reliable Performance
    Cons
  • None
    Best Uses
"[...]Installation took 5 minutes. The hardest part of the install was figuring out how to open the Dell desktop case. But once open the memory install took about 30 seconds. Closed the case, turned on the power and the system did the rest. Truely plug and play. No dip switches to set, no config …"  Read Full Review »
Nov 10 2009
Mike
Knoxville, TN
I am:
  • Casual User
Reviewed at:
Price: $31.99
I recommend this product
5.0
    Pros
  • Easy To Install
  • Fast
    Cons
  • None
    Best Uses
  • Back Up
  • Multimedia
"Setup: Home Dell Dimension 8400; Intel Pentium 4 CPU 3.20GHz (3.2 GHz); BIOS A09 version 07-07-2006; Windows XP Pro, OS version 5.1.2600; OS Service Pack 3; Network Card: Broadcom NetXtreme 57xx Gigabit Controller (if you wanted to know); ISP - DSL; Processor Speed 3.2 GHz. Okay......CPU came with 1 …"  Read Full Review »
Jan 31 2009
NaturalHaus
Mechanicsville, VA, USA
I am:
  • Power user
Reviewed at:
Price: $31.99
[2 of 2 customers found this review helpful]
Simple way to upgrade memory
5.0
    Pros
  • Easy To Install
  • Increases Speed
    Cons
  • None
    Best Uses
"Couldn't be easier. Match your machine with correct memory as guided by Crucial. With my Dell 8400 is was pop in..done.Leave the current memory in (in a four slot with two slots free). In my case(s) Windows XP recognized the change and just went about business as usual with no additional setup requi …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Mar 11 2009
DKD
Longmeadow, Massachusetts
I am:
  • Power user
Reviewed at:
Price: $31.99
2 Gigs memory for Dell Dimension 8400
4.0
    Pros
  • Easy To Install
  • Increases Speed
    Cons
  • None
    Best Uses
"Installed the 2 gig memory kit so I could run multiple applications simultaneously at a decent speed. Works well. "
Nov 9 2009
Dane
Los Angeles, CA
I am:
  • Power user
Reviewed at:
Price: $31.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
