Crucial 2GB kit(1GBx2), Ballistix Tracer 240-pin DIMM(with LEDs), DDR2 PC2-8500,
#4862
3.6
based on 11 reviews
Ratings Distribution
5 star
5
4 star
2
3 star
1
2 star
1
1 star
2
Category Average
4.6
$44.99 at Crucial
Find it at Amazon
Find it at Ebay
$44.99
from 1 store
Pros
  • Easy to install (9)
  • Reliable (6)
  • Fast (4)
  • Increases speed (4)
  • Bling (1)
  • Leds (1)
  • Superb looking (1)
  • Visual quality (1)
See less See more
Cons
  • Unreliable performance (4)
  • No increase in speed (1)
  • Poor quality (1)
  • Poor value (1)
  • Stable at 800 not 1066mhz (1)
Best Uses
  • Multiple desktop applications (7)
  • Multimedia (6)
  • Gaming (5)
  • Extreme gaming (1)
Provided by Crucial
2GB kit (1GBx2), Ballistix Tracer 240-pin DIMM (with LEDs), DDR2 PC2-8500, NON-ECC,
Crucial 2GB kit(1GBx2), Ballistix Tracer 240-pin DIMM(with LEDs), DDR2 PC2-8500, Questions
Questions and Answers
Where to Buy
$44.99
BizRate Rating Outstanding 9.3
Product Reviews
Last update: May 1, 2009
Crucial 2GB kit(1GBx2), Ballistix Tracer 240-pin DIMM(with LEDs), DDR2 PC2-8500, Reviews
Most helpful positive review
Most helpful negative review
4.0
Great!
"Runs extremely stable and cool at stock speeds: 800MHz @ 4-4-4-12 @ 2.0V 1066 @ 5-5-5-15 @ 2.2V Runs nicely at 900MHz @ 4-4-4-12 @ 2.26V At 910MHz they crash after a few hours. Fastest speed I got was 1176MHz @ 5-5-5-15 @ 2.3V, but also crashes after a few hours. I use a Gigabyte EP45-UD3P motherboard. The light show is incredible! The only problem is that I can't find another set......" Read Full Review »
May 01, 2009 by eXpander
See more positive Crucial 2GB kit(1GBx2), Ballistix Tracer 240-pin DIMM(with LEDs), DDR2 PC2-8500, reviews
1.0
Bad Experience
"I spent many weeks getting BSOD's on building a new computer, only to find one module of a matched pair was faulty and the other module would only work at default voltage (+0.1) instead of (+0.3)as the then recomended voltage was 2.2v Now awaiting RMA ! - No doubt a 2v one? Certainly NOT recomended unless you have spare modules for testing purposes..." Read Full Review »
Feb 05, 2009 by Nigel
See more negative Crucial 2GB kit(1GBx2), Ballistix Tracer 240-pin DIMM(with LEDs), DDR2 PC2-8500, reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
Great!
4.0
    Pros
  • Easy To Install
  • Fast
  • Reliable Performance
    Cons
  • None
    Best Uses
  • None
I use a Gigabyte EP45-UD3P m …"  Read Full Review »
Was this Computer Memory review on the Crucial 2GB kit(1GBx2), Ballistix Tracer 240-pin DIMM(with LEDs), DDR2 PC2-8500, helpful to you?
May 1 2009
eXpander
Romania
I am:
  • Power user
Reviewed at:
Price: $44.99
[2 of 3 customers found this review helpful]
better quality with 8 led lights
5.0
    Pros
  • Easy To Install
  • Increases Speed
  • Visual quality
    Cons
  • None
    Best Uses
  • Gaming
  • Multimedia
"*how you use the product
i use it for entertainment and high performance
*things that are great about it
the spectacular light show from led
*things that aren't so great about it
theres nothing that aren't great about it,but would be good to have maybe a indicator on ram so it monitors the curr …"  Read Full Review »
 Report Abuse  (2)  (1)  0 comments
Aug 27 2008
shaun
Ft.Riley , KS
I am:
  • Power user
Reviewed at:
Price: $44.99
[1 of 1 customers found this review helpful]
Awesome Memory
5.0
    Pros
  • Easy To Install
  • Increases Speed
    Cons
  • None
    Best Uses
  • Gaming
  • Multimedia
"Pros:
Great memory. Looks good works hard. The memory glows blue on the bottom, and green and red leds' flash around based on how much you are doing on your system.
Cons:
Memory gets hot but normal hot. Could have better heatsinks. Also wish they made the 8500 Speed in 2GB or higher mod …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 6 2008
Rob
Van, BC, Canada
I am:
  • Power user
Reviewed at:
Price: $44.99
Bad Experience
1.0
    Pros
  • None
    Cons
  • Unreliable Performance
    Best Uses
Certainly NOT recomende …"  Read Full Review »
Feb 5 2009
Nigel
Tenerife
I am:
  • Power user
[1 of 4 customers found this review helpful]
The good, the bad, the shiny
4.0
    Pros
  • Easy To Install
  • Fast
    Cons
    Best Uses
  • Multimedia
"The good:
These time really easily to a tight 4-4-4-12 without any issues and can be run under the rated 2.0v and still stay stable.
Crucial customer service is excellent.
Micron memory is always a plus.
The bad:
Purchased 4GB
Two 2x1GB 2GB kits
RMA'd first set 4 months after purchas …"  Read Full Review »
 Report Abuse  (1)  (3)  0 comments
Oct 8 2008
Supreme_Pizza
Granite City, IL
I am:
  • Power user
Reviewed at:
Price: $44.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
