Crucial 2GB kit(1GBx2), Ballistix 240-pin DIMM, DDR2 PC2-8500,
#5844
1.8
based on 38 reviews
Ratings Distribution
5 star
5
4 star
2
3 star
1
2 star
4
1 star
26
Category Average
4.6
$35.99 at Crucial
Find it at Amazon
Find it at Ebay
$35.99
from 1 store
Pros
  • Easy to install (23)
  • Reliable (6)
  • Increases speed (4)
  • Fast (3)
  • Compatibility (1)
  • Large capacity / good size (1)
  • Looks great (1)
  • Single-sided for cmd-r 1t (1)
  • The heat sinks look cool (1)
See less See more
Cons
  • Unreliable performance (27)
  • No increase in speed (6)
  • Bsod (2)
  • Bsod errors (1)
  • Data loss corruption (1)
  • Dead (1)
  • Destroyed other hardware (1)
  • I have rmaed it 3 times (1)
  • Intermittent problems (1)
  • Pc locks up (1)
Best Uses
  • Multimedia (6)
  • Multiple desktop applications (6)
  • Increased performance (3)
  • Gaming (2)
  • Autocad 2008 3d studiomax (1)
  • Back-up (1)
  • Baseball replacement (1)
  • Bookmark (1)
  • Cad-programs (1)
  • Chew toy for the dog (1)
Provided by Crucial
2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR2 PC2-8500, NON-ECC,
Crucial 2GB kit(1GBx2), Ballistix 240-pin DIMM, DDR2 PC2-8500, Questions
Questions and Answers
Where to Buy
$35.99
BizRate Rating Outstanding 9.3
Product Reviews
Last update: Oct 7, 2009
Crucial 2GB kit(1GBx2), Ballistix 240-pin DIMM, DDR2 PC2-8500, Reviews
Most helpful positive review
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
I dont see what the problem is?
"I dont understand all these negative ratings here, have any of you actually taken the time to get in touch with your motherboard or processor manufacturers? gigabyte an amd users, i have had several correspondances with both gigabyte and amd, and both shift the blame back and forth between who's fault it is that this ram can not run at 1066. I have found out that due to many quad core cpu limitations, that 1066m..." Read Full Review »
Jul 08, 2009 by Dacca
See more positive Crucial 2GB kit(1GBx2), Ballistix 240-pin DIMM, DDR2 PC2-8500, reviews
1.0
Unstable at stock, Intermittent Problems
"GA-P35-DS4 v2.1, 4 x 1GB Ballistix RAM, 8800GT, Q6600 I never expected that I would have to replace a single kit of Ballistix RAM more than once due to issues that this RAM is supposed to have been created to protect against: "The Ballistix line is specifically built for performance enthusiasts who want to push the performance envelope without worrying about data loss or corruption, mysterious intermittent erro..." Read Full Review »
Oct 11, 2008 by J
See more negative Crucial 2GB kit(1GBx2), Ballistix 240-pin DIMM, DDR2 PC2-8500, reviews
Displaying 1 - 5 of 38 Reviews
Show
Sort by
1.0
    Pros
  • Easy To Install
  • Large Capacity
    Cons
  • BSOD Errors
  • Data loss Corruption
  • Unreliable Performance
    Best Uses
  • None
I never expected that I would have to replace a single kit of Ballistix RAM more than once due to issues that this RAM is supposed to have been created to protect against: "The Ballistix line is specifically built for performance enthusiasts w …"  Read Full Review »
Was this Computer Memory review on the Crucial 2GB kit(1GBx2), Ballistix 240-pin DIMM, DDR2 PC2-8500, helpful to you?
 Report Abuse  (2)  (0)  0 comments
Oct 11 2008
J
Tucson, AZ
I am:
  • Power user
Reviewed at:
Price: $35.99
[4 of 4 customers found this review helpful]
JUnky memory
1.0
    Pros
  • None
    Cons
    Best Uses
  • None
"I installed this into my custom built system. It was not overclocked, everything was at stock settings. The computer started doing random reboots about 40 days after I purchased and installed the memory. At about 62 days after install, the computer would not even successfully boot Linux. Rand th …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Aug 31 2008
Jerry
Las Vegas, NV
I am:
  • Power user
Reviewed at:
Price: $35.99
5.0
    Pros
  • Easy To Install
  • Increases Speed
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Increased Performance
  • Multimedia
"I dont understand all these negative ratings here, have any of you actually taken the time to get in touch with your motherboard or processor manufacturers? gigabyte an amd users, i have had several correspondances with both gigabyte and amd, and both shift the blame back and forth between who's fau …"  Read Full Review »
Jul 8 2009
Dacca
United Kingdom
I am:
  • Power user
Reviewed at:
Price: $35.99
Must set to 2 volts, then A+
4.0
    Pros
  • Easy To Install
  • Fast
    Cons
  • None
    Best Uses
"If you leave your mobo set to "auto" then the ram only gets 1.8v instead of the required 2.0v. If you don't know about bios settings then how do you know you need faster ram?
If you set voltage properly, they can exceed 1100MHz at recommended timings and be stable. Best used between 980 and 1080 …"  Read Full Review »
Oct 7 2009
Member of the 4GHz overclocker's club
Bay Area, CA
I am:
  • Power user
Reviewed at:
Price: $35.99
Aweful Memory!
1.0
    Pros
  • NONE
    Cons
    Best Uses
  • Doesnt Work
"These sticks were first released model number 1065 and were then revised to 106A. Enough said. I am preparing to RMA the sticks back to Crucial for the newer versions. Hopefully those work. Though from the looks of the rest of the reviews its not helping.
The originals state to run at 2.2v and th …"  Read Full Review »
Dec 1 2008
j0k3r
FL
I am:
  • Power user
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
