Crown IT9000-HD Power Amplifier
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.3
Pros
  • Accurate controls (1)
  • Clean sound (1)
  • Easy setup (1)
  • Good power (1)
See less See more
Best Uses
  • Audiophiles (1)
  • Basic systems (1)
  • Larger rooms (1)
Provided by PSSL.com - ProSound and Stage Lighting
Crown IT9000-HD Power Amplifier I-Tech HD features a new user-inspired DSP engine co-developed with BSS called OMNIDRIVEHD. The new processing engine features Linear Phase FIR filters that offer unrivaled crossover performance for sonically pure tunings. The OMNIDRIVEHD processing engine also features an innovative new suite of limiters called LevelMAX™. Harman HiQnet™ System Architect ™ mirrors the typical browser navigation interface to provide tour sound and contracting professionals with a familiar interface to access a host of power configuration and control functions. Performance Specifications Frequency Response: (at 1 watt, 20 Hz - 20 kHz): ±0.25dB. Signal to Noise Ratio below rated full-bandwidth power, A-weighted: > 112 dB. Total Harmonic Distortion (THD) at full rated power: Intermodulation Distortion (IMD) 60 Hz and 7 kHz at 4:1, from full rated output to –35 dB: Damping Factor (20 Hz to 100 Hz at 8 ohms): > 5000. Crosstalk (below rated power, 20 Hz to 1 kHz): > 80 dB. Common Mode Rejection (CMR) (20 Hz to 1 kHz): > 70 dB typical. Latency (analog, digital inputs): 1.13 mS analog, 1.81 mS digital (96 kHz). A/D, D/A Converters: 24-bit 192 kHz Cirrus Logic. Digital Input: AES/EBU, 24-bit, 32-96 kHz. Onboard sample-rate converter. Network: Onboard TCP/IQ and HiQnet, compatible with standard 100 Mb Ethernet hardware. DSP: 24-bit conversion with 32-bit, floating-point DSP processing. World-class IIR and linear phase FIR filters. Has 64 assignable filters with 9 different filter types. Includes all-pass filters, over 2 seconds of delay available per channel, and dual uncorrelated-noise and sine-wave generators. Load Impedance: (Note: Safe with all types of loads) Stereo: 1/2/4/8/16 ohms. Bridge Mono: 2/4/8 ohms. Input Sensitivity (referenced to 8 ohm rated output): Adjustable in 0.1V steps from 1.4V to 7.75V. Required AC Mains: Universal AC input, 100-240VAC, 50/60 Hz (±10%). Maximum AC mains voltage 264VAC. AC Line Connector: Five cordsets supplied with amplifier (USA, UK, European, Australia, India). Front Panel Indicators, Controls, and Connectors Indicators: Bridge mode, Ready, Signal level, Clip, Thermal error, Fault, Network data, Power, AC mains. LCD Control Screen and Controls: These let the user adjust the amplifier’s attenuation and muting, configure the amp, set up and view error monitoring (such as temperature and load supervision), set IP and HiQnet addresses from the front panel, and recall DSP presets. The presets allow the user to quickly reconfigure the amp for various applications. Level Controls (Encoders): Speed-sensitive rotary encoders, 0.5 dB steps, range 0 to –100 dB. These two knobs affect the Channel-1 and Channel-2 output levels. They also select Menu items and adjust parameter values that are displayed on the LCD Control Screen. Power Switch: Push-on/push-off switch with built-in green AC mains present indicator. USB 2.0 Connector: Accepts a USB drive to transfer presets from the drive to the amplifier DSP, and vice versa. Back Panel Connectors, Controls, and Indicators Connectors: Balanced XLR analog inputs, balanced analog XLR loop-thru outputs, AES/EBU digital input, AES/EBU digital loop-thru output, 4-Pole Speakon output connectors, binding post output connectors, power cord, EtherCon® Ethernet connector for networking via HiQnet or CobraNet. Reset Switch/Circuit Breaker: If the current draw of the amplifier exceeds safe limits, this breaker automatically disconnects the power supply from the AC mains. The switch resets the circuit breaker. Preset Indicator: LED flashes to signal the number of the current preset if active. LED is green if the preset values have not been changed once loaded. LED is yellow if the preset values have been changed since they were loaded. Construction Cooling: Dual-zone, microprocessor controlled, continuously variable speed fans, front-to-back airflow. Dimensions: 19 in. (48.3 cm) W x 3.5 in. (8.9cm) H x 16.2 in. (41.1 cm) D. Weight: 28 lbs (12.7 kg) net Included Accessories: Rear rack ears, rack screws, operation manual, power cords, foam air filter. I-T9000 HD Power Output (Guaranteed minimum power in watts at 20 Hz-20 kHz with 0.1% THD) 4-ohm Dual (per ch): 3,500W 8-ohm Dual (per ch): 1,500W 4-ohm Bridge: 5,600W 8-ohm Bridge: 7,000W 2-ohm Dual (per ch), 20 mS BURST: 4,700W 2-ohm Dual (per ch), 20 Hz - 20 kHz: 2,800W 2-ohm Dual (per ch), 1 kHz: 2,800W
Crown IT9000-HD Power Amplifier Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: IT9000-HD Power Amplifier
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 1, 2009
Crown IT9000-HD Power Amplifier Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
is awesome!!!
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
"That is what, I was waiting for!! "
Was this Amplifier, Receiver & Equalizer review on the Crown IT9000-HD Power Amplifier helpful to you?
Aug 1 2009
chuybritto
mount pleasant, tx
I am:
  • Audiophile
  • Musically Inclined
  • Practical
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
