Corsair 8GB Survivor USB 2.0 Flash Drive
#281
4.2
based on 26 reviews
Ratings Distribution
5 star
12
4 star
10
3 star
2
2 star
0
1 star
2
Category Average
4.3
Low Price:
$27.99 at Dell
 Trusted:
$39.99 at TigerDirect
$29.99 at ClubMac
see all stores
$27.99 - $43.99
from 11 stores
More Images
Provided by ClubMac
Flash Survivor 8GB External USB 2.0 Drive Extremely durable, water resistant, drop-tested USB flash drive. By design it's perfect for transporting valuable data such as MP3's, personal files, photos presentations, applications, and more. Flash Survivor is an extremely durable, water resistant, drop-tested USB flash drive. By design it's perfect for transporting valuable data such as MP3's, personal files, photos presentations, applications, and more without having to worry about data loss or damage due to the elements.Flash Survivor is an extremely durable, water resistant, drop-tested USB flash drive. By design it's perfect for transporting valuable data such as MP3's, personal files, photos presentations, applications, and more without having to worry about data loss or damage due to the elements.Key Features:• Encased in extremely strong CNC-milled, anodized aircraft-grade aluminum.• Water resistant to 200M through the use of a EPDM waterproof seal.• Protected from vibration or impact damage through the use of a molded shock dampening &nbsp&nbsp&nbspcollar.• Works flawlessly with any USB 2.0 certified peripheral computer port (backward compatible &nbsp&nbsp&nbspwith USB 1.1).• Flash Survivor GT models provide fast data transfer using performance IC-paired memory &nbsp&nbsp&nbspand controllers.• Includes True Crypt security application (Windows Vista/XP/2000 compatible only) allowing &nbsp&nbsp&nbspfor a virtual encrypted drive using AES-256 encryption. • USB extension cable and Dog Tags included.
Specification Description
Model 2088130, CMFUSBSRVR-8GB
UPC 843591000680
Storage Capacity 8 GB
Corsair 8GB Survivor USB 2.0 Flash Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 31, 2009
Corsair 8GB Survivor USB 2.0 Flash Drive Reviews
Most helpful positive review
[32 of 32 customers found this review helpful]
Most helpful negative review
[19 of 20 customers found this review helpful]
4.0
Speedy reads, slow writes, but rock solid
"Purchased this for use with a MacBook Pro. As formatted from the factory, it was fast for reading any kind of files, and for writing large (multi-megabyte) files, but painfully slow for writing many small files. Benchmarking tools (and most online reviews) don't appear to pick up this random small file problem. Since I don't need to use it in a Windows environment, I reformatted the device as a Mac OS Journal..." Read Full Review »
May 16, 2008 by M. Terretta
See more positive Corsair 8GB Survivor USB 2.0 Flash Drive reviews
3.0
Tough, but connectivity issues surfaced
"No doubt, the case is as tough as available, and few alternatives offer the storage of 16GB - two features which may be enough for most. But, the first unit I had died on day two (Corsair replaced no questions asked), and the replacement unit I received has had intermittent connectivity issues with my USB ports. Sometimes you plug it in and the device is recognized, and sometimes you have to reset the computer o..." Read Full Review »
Dec 02, 2007 by S. Graham
See more negative Corsair 8GB Survivor USB 2.0 Flash Drive reviews
Displaying 1 - 5 of 26 Reviews
Show
Sort by
4.0
"Purchased this for use with a MacBook Pro. As formatted from the factory, it was fast for reading any kind of files, and for writing large (multi-megabyte) files, but painfully slow for writing many small files. Benchmarking tools (and most online reviews) don't appear to pick up this random small …"  Read Full Review »
Was this Flash Stick review on the Corsair 8GB Survivor USB 2.0 Flash Drive helpful to you?
 Report Abuse  (32)  (0)  0 comments
May 16 2008
M. Terretta
New York, NY
Reviewed at:
Price: $43.99
3.0
"No doubt, the case is as tough as available, and few alternatives offer the storage of 16GB - two features which may be enough for most. But, the first unit I had died on day two (Corsair replaced no questions asked), and the replacement unit I received has had intermittent connectivity issues with …"  Read Full Review »
 Report Abuse  (19)  (1)  0 comments
Dec 2 2007
S. Graham
Texas
Reviewed at:
Price: $43.99
[7 of 7 customers found this review helpful]
Excellent product backed up by an exceptional company
5.0
"This drive is by far one of the best designed USB flash drive that I have ever own or seen. I'm an architecture student and I constantly need to transfer drawing and image files rangeing from 100kbs to 1+Gbs between a series of computer; this drives size and acceptable speed deffinately enable me to …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Jun 26 2008
Austin J. Johnson
Amazon
Reviewed at:
Price: $43.99
[5 of 5 customers found this review helpful]
Nearly perfect - but watch the rubber rings
4.0
"Pros:
+ Rugged
+ Great capacity
+ Fast enough for normal usage
Cons:
- The outside rubber rings
- Minor quality issues with the labels
I bought the unit around Christmas 2007 to replace an old plastic 1GB unit that failed. I carried a flash drive im my pocket so that I always have access to my da …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
May 27 2008
John A. Schaefer
Middle Tennessee, USA
Reviewed at:
Price: $43.99
[14 of 20 customers found this review helpful]
Dreadfully slow and unacceptable
1.0
"I've been a big fan of Corsair as I have their dominator memory in my rendering rig... but this Survivor 32gig is the biggest piece of garbage I've set my hands on.
The first one I had was so dreadfully slow it was taking around 6 hours to copy 18 gigs and then crashed. It had all the symptoms tha …"  Read Full Review »
 Report Abuse  (14)  (6)  0 comments
Jul 19 2008
B. Waiss
Seattle, WA
Reviewed at:
Price: $43.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
