Coolmax Technology CoolMax V-400 ATX V2.01 400 Watts Power Supply
#73
3.9
based on 66 reviews
from $19.99 - $45.03
Ratings Distribution
5 star
29
4 star
22
3 star
5
2 star
2
1 star
8
Category Average
4.1
More Images
Provided by RitzCamera.com
400 Watt ATX 12V Ver 2.01 AC Power Supply contains specially selected components & high performance heat sink to cool down system. Cable-tube on main power cables for better cable routing and neatness. Universal connector fits most of branded motherboard. Over voltage protection, short circuit protection on all output level.
Main Features
  • Manufacturer: Coolmax Technology, Inc
  • Manufacturer Part Number: 14616
  • Manufacturer Website Address: www.coolmaxusa.com
  • Product Type: AC Power Supply
  • Fans: Single
  • Version Support: ATX 12V
  • Compatibility:
  • Intel
  • AMD
  • Input Voltage: 100V AC to 132V AC, 200V AC to 264V AC
  • Output Voltage: 3.3V DC , 5V DC , 12V DC , 12V DC , -12V DC , 5V DC Standby
  • Current: 30A @ 3.3V DC - Output Current, 28A @ 5V DC - Output Current, 14A @ 12V DC - Output Current, 15A @ 12V DC - Output Current, 1A @ -12V DC - Output Current, 2.5A @ 5V DC - StandbyOutput Current
  • Output Power: 400 W
  • Specification Description
    Model 14616
    UPC 895963146168
    Fans Single Fan
    Output Power 400 W
    Coolmax Technology CoolMax V-400 ATX V2.01 400 Watts Power Supply Questions
    Questions and Answers
    Where to Buy
    $24.99
    $19.99
    $1.99 Shipping On Orders Over $100 at TigerDirect
    BizRate Rating Outstanding 9.1
    $19.99
    $1.99 Shipping on Orders Over $75 ends 12/31/09
    Show all 15 stores
    _
    Product Reviews
    Last update: Nov 12, 2009
    Coolmax Technology CoolMax V-400 ATX V2.01 400 Watts Power Supply Reviews
    Most helpful positive review
    [3 of 3 customers found this review helpful]
    Most helpful negative review
    [5 of 7 customers found this review helpful]
    5.0
    Very Pleased
    "I purchased this power supply because I needed to upgrade my graphics card on my Intel P4 3.06GHZ w/Hyperthreading computer. My original power supply was 160W so this is a good upgrade. I wasn't sure what would happen since I've never upgraded anything on my cpu except for memory. The process was really easy; Plug and play and it's compatible with my new graphic card too. Happy Customer!..." Read Full Review »
    Jun 29, 2008 by D. Henson
    See more positive Coolmax Technology CoolMax V-400 ATX V2.01 400 Watts Power Supply reviews
    1.0
    Too noisy for desktop. Worked OK.
    "I decided to return this power supply as soon as it was installed because the fan noise was too loud. Tower pc case is near the floor and not on the desktop, and inside case is covered with sound insulation, but the fan was still noisy. Power supply worked fine and 400W is enough for my older pc with onboard sound and video and basic setup...." Read Full Review »
    Jan 05, 2008 by Keep it Simple
    See more negative Coolmax Technology CoolMax V-400 ATX V2.01 400 Watts Power Supply reviews
    Displaying 1 - 5 of 66 Reviews
    Show
    Sort by
    Very Pleased
    5.0
    "I purchased this power supply because I needed to upgrade my graphics card on my Intel P4 3.06GHZ w/Hyperthreading computer. My original power supply was 160W so this is a good upgrade. I wasn't sure what would happen since I've never upgraded anything on my cpu except for memory. The process was re …"  Read Full Review »
    Was this Battery Backup/UPS review on the Coolmax Technology CoolMax V-400 ATX V2.01 400 Watts Power Supply helpful to you?
     Report Abuse  (3)  (0)  0 comments
    Jun 29 2008
    D. Henson
    Palmdale, CA USA
    Reviewed at:
    Price: $24.99
    1.0
    "I decided to return this power supply as soon as it was installed because the fan noise was too loud. Tower pc case is near the floor and not on the desktop, and inside case is covered with sound insulation, but the fan was still noisy. Power supply worked fine and 400W is enough for my older pc wit …"  Read Full Review »
     Report Abuse  (5)  (2)  0 comments
    Jan 5 2008
    Keep it Simple
    Amazon
    Reviewed at:
    Price: $24.99
    [7 of 8 customers found this review helpful]
    Coolmax not so quiet
    4.0
    "Has worked well from a power generation standpoint but the fan is louder than I expected based on manufacturer's claims. "
     Report Abuse  (7)  (1)  0 comments
    Jan 19 2007
    S. Bronson
    Lynchburg, VA
    Reviewed at:
    Price: $24.99
    I installed it in an HP ...
    5.0
    "I installed it in an HP Pavilion PE512A. Physical installation was easy and everything fit nicely into place. I did have to bend a corner of the PC case slightly because the flange on the power supply AC recepticle was slightly larger than the original. This was no problem, however. Electrical opera …"  Read Full Review »
    Nov 11 2009
    GENE
    Undisclosed
    Reviewed at:
    Price: $19.99
    [2 of 2 customers found this review helpful]
    pleased with product
    5.0
    "I ordered this power supply hoping it would solve a problem with my computer. Unfortunately it did not. Nevertheless, it works wonderfully and is a bigger and better power supply than I had. I also installed it myself, and that is saying alot about the simplicity of installation.
    I consider mysel …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Jun 3 2008
    J. Loudermilk
    Mt. Airy, GA United States
    Reviewed at:
    Price: $24.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
