Coby HDR-650 Component HD Radio Receiver
2.9
based on 8 reviews
Ratings Distribution
5 star
2
4 star
2
3 star
0
2 star
1
1 star
3
Category Average
4.1
$64.95 - $129.00
from 10 stores
More Images
Pros
  • Easy setup (4)
  • Great sound quality (3)
  • Durable (2)
  • Accurate controls (1)
  • Good power output (1)
  • This is a tuner dudes (1)
See less See more
Cons
  • Poor reception / weak antenna (2)
  • Lack of power (1)
  • Limited functions (1)
  • Small lcd (1)
Best Uses
  • Basic systems (3)
  • Home theater (2)
  • Audiophiles (1)
  • Large rooms (1)
  • Portable (1)
  • Smaller rooms / apartments (1)
Provided by Beach Audio
Coby hdr650 component HD radio receiver
* HD radio tuner receives crystal clear digital broadcasts with no subscription fees
* Receives AM/FM analog broadcasts
* Preset station memory
* High-Contrast LCD display with backlight
* Brushed aluminum casing designed to complement other components
* Stereo rca connectors for use with home audio systems
* 3.5Mm headphone jack
* Includes full-Function remote
Specification Description
Model HDR-650, HDR650, RACB650
UPC 716829676509
Radio Frequencies AM FM HD-Radio
Type of Receiver Home Theater Surround
Coby HDR-650 Component HD Radio Receiver Questions
Questions and Answers
Where to Buy
$79.88
$99.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
$64.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
Show all 10 stores
Product Reviews
Last update: Apr 11, 2009
Coby HDR-650 Component HD Radio Receiver Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Worth the $
4.0
    Pros
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • Limited Functions
    Best Uses
  • Basic Systems
  • Home Theater
"First let me say that I am no expert in the field and this is my first HD radio; with that said, I am really happy with my purchase. The unit is small (5" X 3" X 2") and works well. I purchased this unit to replace my portable CD player/radio that I used at work. I just plugged my computer speake …"  Read Full Review »
Was this Home Theater review on the Coby HDR-650 Component HD Radio Receiver helpful to you?
 Report Abuse  (2)  (0)  0 comments
Oct 29 2008
Cheryl
Tampa, FL
I am:
  • Practical
Reviewed at:
Price: $79.88
[1 of 2 customers found this review helpful]
The COBY 650 Comptuner HD
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • This is a tuner Dudes
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"The 650 HD Coby Tuner is a special few high performance tuner you can get. Who need a radiowhen a comp tuner will do. Out of the box it exudes quality. If you own a big powered boombox with a media aux your in for an audio treet to your ears! Alot of choices out there but coby used to be known for c …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Sep 5 2008
BUCK
MUNCIE, INDIANA
I am:
  • Audiophile
  • Musically Inclined
  • Practical
  • Tech Geek Ret
  • Tech Savvy
Reviewed at:
Price: $79.88
Coby HDR-650 Bad Performer
1.0
    Pros
  • Easy To Set Up
    Cons
  • Extremely Weak AM Tuner
  • Small LCD
  • Weak FM Tuner
    Best Uses
  • Basic Systems
"The HDR-650 fails to adequately perform its only function, tuning FM and AM radio stations. The FM tuner will receive only strong signal FM stations and will decode HD FM from only very strong signal stations. It performs much worse than the least expensive component FM tuner. The AM tuner performan …"  Read Full Review »
Jan 2 2009
Dave
Akron, OH
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Price: $79.88
No connection for external antenna
1.0
    Pros
  • None
    Cons
  • Weak
    Best Uses
  • Portable
"It was not clear from the description that there is no provision to connect the tuner to an external antenna system. For FM, the unit uses a single 2 foot internally connected antenna wire. I tried the unit in the intended location using the antenna wire and while it was able to tune the base FM s …"  Read Full Review »
Jan 8 2009
John "Mr Science" aka MacGyver
Lafayette, CO
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $79.88
[0 of 1 customers found this review helpful]
Just OK basic unit
2.0
    Pros
  • Clear Sound
  • Easy To Setup
    Cons
  • None
    Best Uses
  • None
"I thought this might work good with my 5.1 computer sound system. It does okay but with limited HD station reception. Other reviews at other sites say with a good power adapter and/or FM antenna modification this unit works great. Neither solution worked for me. Disappointing, but I guess I'll k …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Apr 11 2009
Mr. Kyle
North Suburbs of Chicago
I am:
  • Practical
Reviewed at:
Price: $79.88
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
