Coby DVD937BLK 5.1 Channel Home Theater System With Digital AM/FM Tuner
3.8
based on 5 reviews
Ratings Distribution
5 star
2
4 star
2
3 star
0
2 star
0
1 star
1
Category Average
4.1
More Images
Pros
  • Great sound quality (3)
  • Attractive design (2)
  • Easy setup (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Flimsy (2)
  • No dts surround sound (1)
Best Uses
  • Audiophiles (2)
  • Large rooms (2)
  • Basic use (1)
  • Office (1)
  • Smaller rooms / apartments (1)
Provided by Beach Audio
The Coby DVD-937 5.1-Channel DVD Home Theater System with Digital AM/FM Tuner is the home theater system with everything you need. 5 full-range satellite speakers and a subwoofer with tuned port for deep bass response leaves the power of surround sound at your fingertips. Plug in the DVD player for video entertainment and support for a host of media formats including DVD, DVD+R/RW, CD, CD+R/RW and is JPEG compatible.
  • 5.1-CHANNEL DVD PLAYER with INTEGRATED AMPLIFIER
  • Progressive scan DVD player
  • Super-slim design (2" high)
  • DVD, DVDR/RW, CD, CD-R/RW, and JPEG compatible
  • Dolby digital decoder
  • Integrated digital AM/FM tuner with 50-station preset memory
  • 5.1-channel audio for surround sound systems
  • Optical, digital, and analog AV outputs for home theater use
  • NTSC/PAL compatible
  • Convenient front panel and on-screen display
  • Multiple language, subtitle, and camera angle support
  • Picture zoom function
  • Parental lock control
  • 100-240V automatic power switching
  • FCC/FDA approved & ETL listed
  • !HOME THEATER SPEAKERS!
  • 5.1-channel surround sound system with 450W total output power
  • 5 full-range satellite speakers (2.25" cone type)
  • Dedicated wooden subwoofer with tuned port for deep bass response (5.25" long-throw)
  • Convenient volume and bass level controls
  • Wall-mountable or desktop speaker design
  • Display Type: Front Panel, On-Screen
  • DTV Input Format: 480p (Component)
  • Media Support: DVD, DVDR/RW, CD, CDR/RW
  • Format Support: Video: MPEG-1, MPEG-2 (DVD); Audio: CD; Photo: JPEG
  • Video System: NTSC/PAL
  • Tuner System: Digital AM/FM with Preset Memory
  • Menu Language Support: English, Spanish, French, German, Italian
  • Audio Input: RCA Stereo Audio (x2)
  • Audio Output: RCA Component Video; RCA Composite Video; S-Video; RCA 5.1-Channel Audio;
  • RCA Stereo Audio/ Coaxial Digital Audio; Optic
  • Amplifier: Integrated
  • Speaker Output (peak): Satellites: 65W x 5; Subwoofer: 125W; Total Output: 450W
  • Power: Main Unit: AC 100-240V; Speakers: [ ]; Remote: 2 x 1.5V "AAA"
  • Unit Dimension (WHD): Main Unit: 16.93" x 2.37" x 13.55"; Sate
  • Package Dimension (WHD): 18.90" x 14.17" x 14.96"
  • AV Cable
  • Remote Control
  • 2 x 1.5V "AAA" Batteries
  • Speaker Cables
  • AM Loop Antenna
  • FM Antenna
  • Specification Description
    Model COB-DVD937BLK, DVD937BLK
    UPC 716829989371
    Disc Player DVD Player - Single
    Main Features DVD Player / Radio
    Play Modes Surround (5.1 Channels)
    Speakers 5 Satellites + Subwoofer
    Coby DVD937BLK 5.1 Channel Home Theater System With Digital AM/FM Tuner Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: DVD937BLK 5.1 Channel Home Theater System With Digital AM/FM Tuner
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Aug 5, 2009
    Coby DVD937BLK 5.1 Channel Home Theater System With Digital AM/FM Tuner Reviews
    Displaying 1 - 5 of 5 Reviews
    Show
    Sort by
    [1 of 1 customers found this review helpful]
    Definitly worth the price
    4.0
      Pros
    • Great Sound
      Cons
      Best Uses
    • Audiophiles
    "I use this product in junction with my all region DVD player, for the DTS surround sound, just hook up your existing player with a coaxial cable to aux 1 or 2 and your set to go. But I really wished that the Coby system was all region and had DTS surround sound as well, as I have a lot of movies th …"  Read Full Review »
    Was this Shelf System review on the Coby DVD937BLK 5.1 Channel Home Theater System With Digital AM/FM Tuner helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Apr 14 2009
    SkyBlade
    Belleville, New Jersey
    I am:
    • Tech Savvy
    Reviewed at:
    colby home theatre
    5.0
      Pros
    • Attractive Design
    • Easy Controls
    • Easy To Set Up
    • Great Sound
      Cons
    • None
      Best Uses
    • Basic Use
    • Larger Rooms
    • Offices
    • Smaller Rooms
    "I loved getting the box and being able to open the box and put everything together. I didnt have to spend time reading, and returning to the product. The sound is great. I couldnt have been more pleased. "
    May 20 2009
    holly
    Reno, NV
    I am:
    • Practical
    • Tech Savvy
    Reviewed at:
    [2 of 2 customers found this review helpful]
    Good for home
    4.0
      Pros
    • Great Sound
      Cons
    • Flimsy
      Best Uses
    • Larger Rooms
    "its a good product. i have it "
     Report Abuse  (2)  (0)  0 comments
    Aug 5 2009
    abbey
    Barbados
    I am:
    • Professional
    Reviewed at:
    [5 of 9 customers found this review helpful]
    Which is wrong?
    1.0
    "The product title states "with Digital AM/FM Tuner." But the product description clearly states "No Tuner."
    Which is wrong? Please correct this and delete my rating. "
     Report Abuse  (5)  (4)  0 comments
    May 30 2009
    Enquiring Mind "Tim N."
    Pensacola, FL, USA
    Reviewed at:
    good
    5.0
      Pros
    • Attractive Design
      Cons
    • Flimsy
      Best Uses
    • Audiophiles
    "good "
    Mar 27 2009
    abbey
    barbados
    I am:
    • Technically Challenged
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
