Coby 7" Portable DVD Player
4.4
based on 58 reviews
from $69.41 - $109.00
Ratings Distribution
5 star
31
4 star
21
3 star
4
2 star
1
1 star
1
Category Average
3.9
More Images
Pros
  • Great picture quality (43)
  • Simple / intuitive controls (38)
  • Lightweight (37)
  • Portable (37)
  • Nice sound (36)
  • Durable (24)
  • Good battery life (16)
  • Easy setup (2)
  • Easy to use (2)
  • Well built / quality construction (2)
See less See more
Cons
  • Short battery life (7)
  • Heavy / bulky (2)
  • Poor sound quality (2)
  • Cables not provided (1)
  • Display (1)
  • Flimsy (1)
  • No battery life indicator (1)
  • No cable plug-ins to tv (1)
Best Uses
  • Home (34)
  • In the car (29)
  • Travel (29)
  • Office (5)
  • Upgrade (1)
Provided by drugstore.com
DVD Player Portable 7, Model TFDVD7006
Specification Description
Model 716829997062, ABCDF352, CBYTFDVD7006, TF-DVD7006
UPC 716829997062
Boy Girl Boy,Girls
color null
Country Of Origin China
Disc Capacity 1
Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
DiVX Play Compatible Not Applicable
DVD Dual Layer Play Compatible Not Applicable
Manufacturer’s Warranty 90 Days
Memory Card Slot Not Applicable
Power Supply Battery / 110-220 Volts AC / 12V DC Car
Product Details Features: Compact Portable Design 7" Widescreen (16:9) TFT Color Display DVD, DVD+/-R, DVD+/-RW, CD, CD-R/RW, JPEG and MP3 Compatible Anti-Skip Circuitry Dolby Digital Decoder Digital and Analog AV Outputs allow for use with Home Theater Systems Headphone Jack for Private Listening Multiple Language, Subtitle, and Camera Angle Support; Parental Lock Control. Please Note: This item has been built to U.S. electronics specifications and may need additional modifications or converters to be used in countries other than the U.S. and Canada.
Screen Size 7"
Screen Size (Inches/Diagonal) 7
Select Size 7" Screen
size null
sku 107813
skuprice 108.9900
style TFDVD7006
taxable Y
TRU Age Filter Big Kids
TV Broadcast Compatibility NTSC
Type of DVD Unit Portable DVD Player
Coby 7" Portable DVD Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
Coby 7" Portable DVD Player Reviews
Most helpful positive review
[15 of 15 customers found this review helpful]
Most helpful negative review
[39 of 41 customers found this review helpful]
4.0
Good product
"I am not sure what happened with the other reviewer but we have had ours about a yr and a half and I have 2 grandkids 4 and 6 that pass it back and forth all the time, have dropped it and not exactly been real careful with it but it has been great for us. The ONLY negative I can say is it seems to not hold a charge for a full 2 hr movie so we plug it in the car adapter and at home for use. But other than than it..." Read Full Review »
Nov 27, 2008 by grandma J
See more positive Coby 7" Portable DVD Player reviews
1.0
Terrible product & customer service
"I bought this DVD player and it broke after two weeks (and maybe 3 movies). I sent it back under their 90 day warranty and got a replacement [...] Then to our surprise (hah!) the 2nd machine broke on us after just two uses. [...] both machines broke within a total of 5 uses. I highly recommend going with a different brand...." Read Full Review »
Apr 27, 2008 by J. Mitchell
See more negative Coby 7" Portable DVD Player reviews
Displaying 1 - 5 of 58 Reviews
Show
Sort by
1.0
"I bought this DVD player and it broke after two weeks (and maybe 3 movies). I sent it back under their 90 day warranty and got a replacement [...] Then to our surprise (hah!) the 2nd machine broke on us after just two uses. [...] both machines broke within a total of 5 uses. I highly recommend going …"  Read Full Review »
Was this Portable DVD Player review on the Coby 7" Portable DVD Player helpful to you?
 Report Abuse  (39)  (2)  0 comments
Apr 27 2008
J. Mitchell
Highlands Ranch, CO United States
Good product
4.0
"I am not sure what happened with the other reviewer but we have had ours about a yr and a half and I have 2 grandkids 4 and 6 that pass it back and forth all the time, have dropped it and not exactly been real careful with it but it has been great for us. The ONLY negative I can say is it seems to n …"  Read Full Review »
 Report Abuse  (15)  (0)  0 comments
Nov 27 2008
grandma J
Cape Gir. Mo
[5 of 5 customers found this review helpful]
SMALLER THAN I THOUGHT
3.0
"I BOUGHT THIS ITEM AND WAS A LITTLE SURPRISED TO FIND IT TO BE SMALLER THAN I THOUGHT. IT IS NICE TO HAVE AS A BACKUP TO YOUR TV. I WAS VERY DISAPOINTED TO FIND THAT THE VOLUME IS NOT AS LOUD AS I HAD HOPED. TO HEAR IT THE ROOM HAS TO BE QUIET. MY HEADPHONES BROKE THE SAME DAY I GOT MY ITEM. I WAS H …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Apr 18 2009
SHORTY "CLOVIA H."
SAN FRANCISCO, CA
Not Exciting - Not weird - okay
3.0
    Pros
  • Good Picture
  • Good Sound
  • Lightweight
  • Portable
    Cons
  • Display
    Best Uses
  • In The Car
"The Coby DVD player is okay for the money, [$], i paid, but for the small screen!! When I ordered I did'nt see widescreen, it is a 7" widescreen screen which I think is not good!! This is my second product from Coby & JR and the previous one, a digital photo frame, also had the same small screen!! W …"  Read Full Review »
Sep 15 2009
RAM
Rockville, MD
I am:
  • Frequent Traveler
Reviewed at:
Big Bang for the Buck
5.0
    Pros
  • Easy Controls
    Cons
  • Bulky
    Best Uses
  • At Home
  • In The Car
  • Travel
"I purchased two of these. I have opened one to check it out. I started a movie quickly. Video controls were easy. I was surprised a remote came with it. I bought one for my kids and one as a give away at work. They are thick and not the best looking, but I only paid [$] each! One thing I real …"  Read Full Review »
Sep 20 2009
Kingman
Stansbury Park, UT
I am:
  • Practical
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
