Coby 7-Inch TFT Portable Media Player with 40GB Hard Disc
2.8
based on 9 reviews
Ratings Distribution
5 star
2
4 star
1
3 star
2
2 star
1
1 star
3
Category Average
4.1
More Images
Pros
  • Great sound quality (5)
  • Lots of storage (5)
  • Easy setup (4)
  • Good battery life (2)
  • Reliable (2)
  • Simple controls (2)
  • Sleek/compact (2)
  • Battery last long (1)
  • Easy to use (1)
  • Nice screen resolution (1)
See less See more
Cons
  • Confusing / difficult controls (3)
  • Heavy / bulky (3)
  • Difficult to set up (2)
  • A bit on the heavy side (1)
  • Can not update codec (1)
  • Choppy video playback (1)
  • Didnt even start (1)
  • Few build in codecs (1)
  • Freezes up (1)
  • Hard to set up (1)
Best Uses
  • Travel (6)
  • Good for commuting (2)
  • Anywhere (1)
  • Daily usage (1)
  • Garbage (1)
  • Gym / working out (1)
  • Large clear lcd (1)
  • Paper weight (1)
Provided by RitzCamera.com
Main Features
  • Manufacturer: Coby Electronics Corporation
  • Manufacturer Part Number: PMP7040
  • Manufacturer Website Address: www.cobyusa.com
  • Product Type: Digital Multimedia Device
  • Product Features: Audio Player, Video Player, Video Recorder, Voice Recorder, Photo Viewer
  • Storage Media: Hard Drive (Integrated)
  • Storage Capacity: 40GB Hard Drive
  • Display Screen: 7" 336960 Pixels
  • Image Formats: JPEG , BMP
  • Playback Duration: 10000 Song(s) @ 128Kbps MP3, 20000 Song(s) @ 64Kbps WMA
  • Audio Formats: MP3 Playback, WMA Playback
  • Video Storage: 160 Hour(s) MPEG-4 @ 500Kbps
  • Video Formats: MPEG-4 Playback, AVI Playback
  • Interfaces/Ports: 1 x Mini-phone Headphone, 1 x USB 2.0 USB, 1 x DC Power Input, 1 x Composite Video Out, 1 x Composite Video In
  • Dimensions: 4.76" Height x 7.8" Width x 1.26" Depth
  • Standard Warranty: 90 Day(s)
  • Specification Description
    Model PMP-7040, PMP7040
    UPC 716829957400
    Audio Video Store and Play Audio and Video
    Battery Type Rechargeable Battery
    Power AC/DC
    Screen Size (Approximate Diagonal) 7
    Storage Capacity (GB) 40
    Storage Expansion SD Memory Card
    Storage Type Hard Drive
    Coby 7-Inch TFT Portable Media Player with 40GB Hard Disc Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: 7-Inch TFT Portable Media Player with 40GB Hard Disc
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Jun 29, 2009
    Coby 7-Inch TFT Portable Media Player with 40GB Hard Disc Reviews
    Displaying 1 - 5 of 9 Reviews
    Show
    Sort by
    Great PMP for the price
    5.0
      Pros
    • Battery last long
    • Easy to Use
    • Very good sound quality
      Cons
    • Some avi's don't work
      Best Uses
    • Travel
    "The player works very well. We are expats and travel 3 times a year, so we have used it for travel. We have also just played around with it at home before we went on a trip to make sure we could rely on it. It is a very cool little machine. We can get over 3 movies in one battery charge. Have looked …"  Read Full Review »
    Was this MP3 Player & iPod review on the Coby 7-Inch TFT Portable Media Player with 40GB Hard Disc helpful to you?
    Jun 20 2008
    Tina
    Reside in Kuwait - From Visalia, Ca.
    I am:
    • Frequent Traveler
    Reviewed at:
    [1 of 1 customers found this review helpful]
    Don't bother
    1.0
      Pros
    • Lots of Storage
      Cons
    • Bulky
    • Confusing Controls
    • Difficult to Set Up
      Best Uses
    • Travel
    "I had two of them. In both the battery got jammed upon install, [*] It doesn't freely move even with the battery out, and it gets jammed halfway through, and you can't remove it afterwards. I mean how hard is it to design a normal battery latch? I've never had that problem even with the cheapest of …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jul 17 2008
    George
    Spokane WA
    I am:
    • Casual Listener
    Reviewed at:
    Not as good as it seems...
    1.0
      Pros
    • Easy To Set Up
    • Great Sound
    • Lots of Storage
    • Solid construction
    • Tough
      Cons
      Best Uses
    • Commuting
    • Large Screen
    • Travel
    "If you want good video, do no buy.
    Choppy playback at best, even with files it reocorded. No S-video in or out as stated above, it only has composite. Choppieness of video gives me headaches. Otherwise a good unit for sound or pictures but too expensive if you have to give up video. Solid feel, see …"  Read Full Review »
    Jan 16 2008
    Transistorhead
    Minneapolis Minnesota
    I am:
    • Avid Listener
    Reviewed at:
    Above Average Media Player
    5.0
      Pros
    • Easy To Set Up
    • Great Sound
    • Long Battery Life
    • Lots of Storage
    • Reliable Performance
      Cons
      Best Uses
    • Commuting
    • Travel
    "I've purchased this from JR about a month ago. So far it's been great, showing no problems and plays great videos. I purchased this mainly for viewing videos. The colors and sound are excellent. Nextar made a similar product, however the firmware that Coby developed is far more superior. Grab this c …"  Read Full Review »
    Apr 4 2009
    badlegs
    Milwaukee, WI
    I am:
    • Casual Listener
    Reviewed at:
    Lack of Accessories
    3.0
      Pros
    • Sturdy
    • Stylish
      Cons
    • Bulky
    • Few build in Codecs
    • Hard to Set Up
      Best Uses
    • Daily Usage
    • Travel
    "You offered a discount on any add-ons associated with this product but few were show on your product page. I went to Coby's product page and noticed an image of accessories and attempted to get information on the carrying case but no data was given on this and a couple of others. I would like the …"  Read Full Review »
    Jun 20 2008
    Willie Dee
    Glendale, AZ
    I am:
    • Audiophile
    • Music Video Lover
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
