Coby 19" Widescreen LCD HDTV/Monitor (Model #TFTV1923)
#590
3.3
based on 14 reviews
Ratings Distribution
5 star
2
4 star
5
3 star
4
2 star
1
1 star
2
Category Average
4.4
$174.99 - $249.99
from 16 stores
More Images
Pros
  • Attractive design (9)
  • Fast setup (9)
  • Good connection options (7)
  • Great picture quality (7)
  • High resolution (7)
  • Simple controls (3)
  • Wide viewing angle (3)
See less See more
Cons
  • Bad interface (2)
  • Difficult to set up (2)
  • Low resolution (2)
  • Poor sound quality (2)
  • Poor color controls (1)
  • Poor connection options (1)
  • Poor image quality (1)
  • Remote control (1)
Best Uses
  • Bedroom (6)
  • Home (5)
  • Wall mounting (5)
  • Computer monitor (1)
  • Games (1)
  • Garage (1)
  • Great children's tv (1)
  • Home office (1)
  • Kitchen (1)
  • Office (1)
Provided by Sears
This 19"Widescreen LCD Color Display HDTV is the perfect size for any room in the house. Use the convenient VESA (75mmx75mm) for wall mounting. Dual ATSC/NTSC timers for Digital&Standard TV broadcast reception (DTV-ready). HDMI digital connection perfect AV signal. HDCP Compliant.Full Range stereo speakers.Digital comb filter & noise reduction. Other features include V-Chip parental control, closed caption,&Electronic Program Guide support. VGA interface for computers. Input Jacks for media play
Specification Description
Model TFTV1923, TVCB1923
UPC 716829921937
16:9 Mode Yes
Battery Type Remote
Benefits 19" (diagonal) LCD display delivers great high-definition-quality images (1440x900)HDMI™, component, composite and VGA inputs fo
Brightness 250 cd/m2
Capacity UOM mAh
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.7 million colors
Connections Antenna (1)HDMI (1)VGA (1)RCA composite video (1)S-Video (1)RCA analog audio (1)1/8" PC
Country Of Origin China
Description Header High-definition that fits anywhere.
Display Catalog Number 55032295
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 19 inches
Enclosure Color Black
End Product Indicator Yes
Included in the Box Coby® TFTV1923 19" LCD HDTVRemote control"AAA" batteries (2)User's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number TFTV1923
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model TFTV1923
Operating Temperature UOM ° F
Output Power / Total 10 watts
Parental controls Yes
Pixel Response Time 6 ms
Product Depth 2.5
Product Dimensions UOM inches
Product Height 16.5
Product Type Flat-panel TVs
Product Weight 10
Product Weight UOM pounds
Product Width 17.93
Reception System ATSC/QAM/NTSC
Screen Size Range 10-20"
Size AAA
Sound Output Mode Stereo
Speakers Included 2 Speakers
Stereo Reception System MTS
Supported Languages English, Spanish, French
TV Diagonal Size 19 inches
TV Image Contrast Ratio 500:1
TV Resolution 1440x900
TV Technology LCD
Type LCD
V-Chip Control Yes
Voltage 1.5
Voltage Required 100-240V 50/60Hz
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i
Coby 19" Widescreen LCD HDTV/Monitor (Model #TFTV1923) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
Coby 19" Widescreen LCD HDTV/Monitor (Model #TFTV1923) Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
Good TV for the money
"This is a good little TV for the money. The remote is very cheap. Buttons need to be pushed several times before action. The picture is much better than expected. There is some work to do if you need to remove the base for wall mounting. Money well spent for my purpose of a small office TV...." Read Full Review »
Mar 17, 2009 by None
See more positive Coby 19" Widescreen LCD HDTV/Monitor (Model #TFTV1923) reviews
1.0
Turns out, size DOES matter...
"Boy, I wish I had done more research before settling on this size and make/model HDTV. I was taken in by the low price. Turns out, size DOES matter, even in a small living room like ours. The screen really isn't big enough to see well. Also, the sound quality is tinny and not loud enough, especially when computer and AC are running in the room, too. Additionally, the color controls don't provide for realistic co..." Read Full Review »
Jul 25, 2009 by Mom2Three
See more negative Coby 19" Widescreen LCD HDTV/Monitor (Model #TFTV1923) reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
Decent inexpensive 19" TV
2.0
    Pros
  • Attractive Design
    Cons
  • Difficult To Set Up
  • Dull Image
  • Poor Resolution
    Best Uses
  • Home
"This 19" Coby LCD TV has a decent picture, but it is uneven (one channel looks OK, another doesn't). I am sorry I didn't spend a few dollars more and get a name brand like Samsung or Panasonic. The picture is sometimes washed out, sometimes overbright, always inconsistent. "
Was this LCD TV review on the Coby 19" Widescreen LCD HDTV/Monitor (Model #TFTV1923) helpful to you?
Nov 11 2009
Rich
Maryland
I am:
  • Casual User
Reviewed at:
Price: $189.99
1.0
    Pros
  • Fast Setup
    Cons
  • Bad Interface
  • Poor Sound
    Best Uses
  • Small Living Room
"Boy, I wish I had done more research before settling on this size and make/model HDTV. I was taken in by the low price. Turns out, size DOES matter, even in a small living room like ours. The screen really isn't big enough to see well. Also, the sound quality is tinny and not loud enough, especially …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Jul 25 2009
Mom2Three
Dearborn, MI
I am:
  • Power User
Reviewed at:
Price: $189.99
Good picture, Reception not so good
3.0
    Pros
  • Bright Image
  • Fast Setup
  • Good Resolution
    Cons
  • None
    Best Uses
  • Computer monitor
  • Home Office
"I got TV to watch baseball playoffs over the air on FOX. The picture is really nice when it comes in. However, it is difficult to get good reception in near-in Washington DC suburbs. I am using a RadioShack powered antenna. Perhaps another antenna would provide better reception, but right now it …"  Read Full Review »
Oct 20 2009
Cat Snatcher
Takoma Park MD (Outside Washington DC)
I am:
  • Casual User
Reviewed at:
Price: $189.99
Great for little kids
1.0
    Pros
  • None
    Cons
  • Poor Resolution
  • Poor Sound
    Best Uses
  • Garage
"This TV is pure JUNK!
The picture can be viewed ONLY if you are sitting directly in front of the thing and it's sound is like my dog's squeeky toy.
We have it on the kitchen counter and if cannot be viewed unless you bend over to the same height as the kitchen counter.
I'm surprised the ABT …"  Read Full Review »
Oct 5 2009
Dean
Atherton, CA
I am:
  • Enthusiast
Reviewed at:
Price: $199.00
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Connection Options
  • Good Resolution
    Cons
  • Remote Control
    Best Uses
  • Games
  • Office
"This is a good little TV for the money. The remote is very cheap. Buttons need to be pushed several times before action. The picture is much better than expected. There is some work to do if you need to remove the base for wall mounting. Money well spent for my purpose of a small office TV. "
Mar 17 2009
None
AR
I am:
  • Enthusiast
Reviewed at:
Price: $189.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
